A relative is working on a PPL using a Diamond DA20. The FBO has a
policy of no student solos with more than 5 knots crosswind component. Do other FBOs do this? As a result he is having trouble scheduling his solo cross countries. |
"nrp" wrote in message
ps.com... A relative is working on a PPL using a Diamond DA20. The FBO has a policy of no student solos with more than 5 knots crosswind component. Do other FBOs do this? As a result he is having trouble scheduling his solo cross countries. A limit of 5 knots might be unusual, but the general idea of imposing limits of that sort on students isn't. FBOs and instructors both do regularly place restrictions on their students, especially with respect to weather conditions. In my experience though, a 5 knot limit is a bit on the low side. Perhaps the FBO would be willing to up the limit a bit (even getting it up to 7 or 8 knots would put it more in line with what I've seen at some other FBOs) if the student were to spend some extra time on crosswind practice with his instructor. If the weather conditions are such that a 5 knot limit is causing problems flying solo XC flights (I assume you mean "flying", and not "scheduling"...weather shouldn't affect scheduling, unless the student is waiting until an hour or so before the flight to schedule ![]() should not be hard for the student and instructor to go out and find some good crosswinds to practice in. Of course, there is also the possibility of just being patient and trying to work around the existing limit. This could mean keeping one's schedule open, so that when good conditions show up the student is ready to fly. Or it could be adjusting the XC plan so that the intended airports of landing have prevailing winds that are more commonly straight (or at least straighter) down the runway, so that the crosswind component is minimized. Pete |
Have you flown a DA20? it has glider wings.. 5knts for first solo may be prudent.. up to 10knts when ready for the check ride. BT |
"BT" wrote in message
... In my experience though, a 5 knot limit is a bit on the low side. Have you flown a DA20? it has glider wings.. What's the maximum demonstrated crosswind for the DA20? I realize that the DA20 has a higher aspect ratio wing than similar airplanes, but with a wing span just under 36' it doesn't have "glider wings". 5knts for first solo may be prudent.. up to 10knts when ready for the check ride. Unless the maximum demonstrated crosswind for the DA20 is significantly lower than that for other airplanes, I see no reason that lower limits applied to students should not be comparable to those for other airplanes. Pete |
On Mon, 6 Nov 2006 19:16:48 -0800, "Peter Duniho"
wrote: "BT" wrote in message ... In my experience though, a 5 knot limit is a bit on the low side. Have you flown a DA20? it has glider wings.. What's the maximum demonstrated crosswind for the DA20? Which is normally a meaningless figure. I realize that the DA20 has a higher aspect ratio wing than similar airplanes, but with a wing span just under 36' it doesn't have "glider wings". 5knts for first solo may be prudent.. up to 10knts when ready for the check ride. I'd hate to tell you what the cross winds were at my first landing on my first long cross country.:-)) That was a long time ago and I was not given any limits, but even today, you may be given limits and the weather may not cooperate. Unless the maximum demonstrated crosswind for the DA20 is significantly lower than that for other airplanes, I see no reason that lower limits I would agree. Demonstrated is only 12 knots on the Deb and it's good for 25 applied to students should not be comparable to those for other airplanes. Student cross wind components are a different animal. Pete Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
"Roger (K8RI)" wrote in message
... What's the maximum demonstrated crosswind for the DA20? Which is normally a meaningless figure. It is never a "meaningless" figure. It always means *something*, and the more effort the aircraft manufacturer puts into it, the more it means. Curious, I did a quick bit of research. I found that early models (maybe the Katana? I wasn't looking that closely at the exact model number here) had a demonstrated crosswind of 15 knots, while the DA20 has a demonstrated crosswind of 20. Both numbers are very respectable, and indicate that there is no problem whatsoever landing the airplane with a crosswind. [...] Unless the maximum demonstrated crosswind for the DA20 is significantly lower than that for other airplanes, I see no reason that lower limits I would agree. Demonstrated is only 12 knots on the Deb and it's good for 25 applied to students should not be comparable to those for other airplanes. Student cross wind components are a different animal. Different animal than what? My point was that the student limits ought to scale just as the demonstrated limits do. For example, if a limit of 8 knots is appropriate for a student flying an airplane with a demonstrated crosswind of 16 knots, then 10 knots might be appropriate as a limit for a student flying an airplane with a demonstrated crosswind of 20 knots. The DA20's demonstrated crosswind *exceeds* that of the 172, and I saw one reference that said that the 150 has a demonstrated crosswind of 12 knots. Granted, that 12 knots is sure to be *well* below what the 150 is actually capable of. But even so, with a demonstrated crosswind of 20 knots for the DA20, there's absolutely no reason to think that one needs to be *more* conservative with that airplane than with others. Being less conservative might not be warranted either, but I see no reason to restrict students more in the DA20 than in other trainers. Pete |
Bt,
Have you flown a DA20? Yes. it has glider wings.. So? (And it doesn't) 5knts for first solo may be prudent.. up to 10knts when ready for the check ride. BS. -- Thomas Borchert (EDDH) |
BT schrieb:
Have you flown a DA20? it has glider wings.. Have *you* flown a DA20? And you obviously never flew a glider. (Besides, we routinely and successfully land our gliders with considerable amounts of crosswind.) Stefan |
On 2006-11-07, BT wrote:
In my experience though, a 5 knot limit is a bit on the low side. Have you flown a DA20? it has glider wings.. 5knts for first solo may be prudent.. up to 10knts when ready for the check ride. I've flown both the DA-20 and the DA-40. The -20 was no more difficult to handle than a Cessna 150. I thought it had very good habits. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
In article om,
"nrp" wrote: A relative is working on a PPL using a Diamond DA20. The FBO has a policy of no student solos with more than 5 knots crosswind component. Do other FBOs do this? As a result he is having trouble scheduling his solo cross countries. A college buddy of mine might not have had a fatal solo if the FBO had, and enforced, a crosswind limit. -- Bob Noel Looking for a sig the lawyers will hate |
Crosswind Landings... But airspeed? | Jmarc99 | Soaring | 21 | October 4th 05 07:54 PM |
Rental Hull Insurance - for a week or just for a day? | Ekim | Piloting | 8 | August 9th 05 12:01 PM |
A new direction for an old thread: Crosswind landings | [email protected] | Soaring | 96 | March 4th 05 01:22 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
CBS Newsflash: Rental trucks pose imminent and grave danger to national security | Ron Lee | Piloting | 4 | January 15th 04 03:07 PM |
