just from a non-pilots angle, whats the reason for the hangar doors to
be the way they are? I mean the 2 part folding types. Is there some advantage to them? why dont we make car garages the same way? |
"Tater" wrote in message
oups.com... just from a non-pilots angle, whats the reason for the hangar doors to be the way they are? I mean the 2 part folding types. Is there some advantage to them? why dont we make car garages the same way? I've seen all sorts of hangar door designs. If you're talking about a door that has a horizontal hinge half-way up, and which rises vertically on tracks, folding in half lengthwise as it does so, then a) this design is simple and allows for maximal use of the space within the hangar (ie doesn't consume vertical room within the hangar), and b) there *are* car garages designed the same way (just as there are hangar doors designed in other ways). |
The main advantage of a bi-fold door is that the header of the door and the
vertical steal beams on each side of the door opening support the door when it is raised, this makes abnormally wide doors without tracks or track extensions possible. I think the motor, gearbox, cables, steal header and beams would make it rather cost prohibitive when compared to a traditional overhead type garage door which, due to it's light weight can be suspended from the underside of roof trusses when raised. Jim "Tater" wrote in message oups.com... just from a non-pilots angle, whats the reason for the hangar doors to be the way they are? I mean the 2 part folding types. Is there some advantage to them? why dont we make car garages the same way? |
The Bi-fold also has no tracks to fill and freeze in the winter, and it makes a good canopy when it is raining...
"Jim Burns" wrote in message ... : The main advantage of a bi-fold door is that the header of the door and the : vertical steal beams on each side of the door opening support the door when : it is raised, this makes abnormally wide doors without tracks or track : extensions possible. I think the motor, gearbox, cables, steal header and : beams would make it rather cost prohibitive when compared to a traditional : overhead type garage door which, due to it's light weight can be suspended : from the underside of roof trusses when raised. : Jim : : "Tater" wrote in message : oups.com... : just from a non-pilots angle, whats the reason for the hangar doors to : be the way they are? I mean the 2 part folding types. Is there some : advantage to them? why dont we make car garages the same way? : : : |
".Blueskies." wrote: The Bi-fold also has no tracks to fill and freeze in the winter, and it makes a good canopy when it is raining... You do, however, have to inspect the cables regularly to make sure that they are not fraying. Racing driver Mark Martin almost lost his Citation when the cables broke just after he had wheeled the jet into his hangar. "Jim Burns" wrote in message ... : The main advantage of a bi-fold door is that the header of the door and the : vertical steal beams on each side of the door opening support the door when : it is raised, this makes abnormally wide doors without tracks or track : extensions possible. I think the motor, gearbox, cables, steal header and : beams would make it rather cost prohibitive when compared to a traditional : overhead type garage door which, due to it's light weight can be suspended : from the underside of roof trusses when raised. : Jim : : "Tater" wrote in message : oups.com... : just from a non-pilots angle, whats the reason for the hangar doors to : be the way they are? I mean the 2 part folding types. Is there some : advantage to them? why dont we make car garages the same way? : : : |
"Orval Fairbairn" wrote in message
news ![]() You do, however, have to inspect the cables regularly to make sure that they are not fraying. Racing driver Mark Martin almost lost his Citation when the cables broke just after he had wheeled the jet into his hangar. In a previous hangar, one of the cables came loose and the door dropped... Jumped the track and swung inwards... I had my boat parked in from of my wing and I was crossing behind the boat... It pushed the boat backwards and the swim platform pinned me against the wall... When they fall, they make a pretty damn loud sound though... I've decided that if I ever build my own hangar, I'm going to go with the sliding multi-fold fiberglass panel doors instead... They are light enough that you don't need a motorized opener, so they're perfect if you ever lose power and still want to go flying... They're translucent, so they let a lot of light in also... |
"Grumman-581" wrote in message ... : "Orval Fairbairn" wrote in message : news
: You do, however, have to inspect the cables regularly to make sure that: they are not fraying. Racing driver Mark Martin almost lost his Citation : when the cables broke just after he had wheeled the jet into his hangar. : : In a previous hangar, one of the cables came loose and the door dropped... : Jumped the track and swung inwards... I had my boat parked in from of my : wing and I was crossing behind the boat... It pushed the boat backwards and : the swim platform pinned me against the wall... When they fall, they make a : pretty damn loud sound though... I've decided that if I ever build my own : hangar, I'm going to go with the sliding multi-fold fiberglass panel doors : instead... They are light enough that you don't need a motorized opener, so : they're perfect if you ever lose power and still want to go flying... : They're translucent, so they let a lot of light in also... I watch the cables and they look fine. The latest doors are using nylon straps which looks pretty good... Good point about the power issue. I have wondered what I would do to open the door if the power was out... |
".Blueskies." wrote in message
... The Bi-fold also has no tracks to fill and freeze in the winter, and it makes a good canopy when it is raining... The apparently it doesn't rain hard enough up where you're at... Down here in Texas, I can get wet standing at the back of my hangar if I have the door all the way up... When we get some good storms coming through here, the rain comes down nearly sideways... |
"Grumman-581" wrote in message ... : ".Blueskies." wrote in message : ... : The Bi-fold also has no tracks to fill and freeze in the winter, and it : makes a good canopy when it is raining... : : The apparently it doesn't rain hard enough up where you're at... Down here : in Texas, I can get wet standing at the back of my hangar if I have the door : all the way up... When we get some good storms coming through here, the rain : comes down nearly sideways... : : Well, I did say raining, not Texas raining. Of course rains harder there. Probably have rain drops the size of a swimming pool! ;-) |
"Tater" wrote in message oups.com... just from a non-pilots angle, whats the reason for the hangar doors to be the way they are? I mean the 2 part folding types. Is there some advantage to them? why dont we make car garages the same way? Caution, boys and girls. It has been a few months since the last Tater sighting, but if you remember, this one has the characteristic makings of trolldom; do you really want to go down this road again, with one already consuming and dominating the discussions? It's up to you. Answer at your own risk. -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| An Erudite Discourse on the Relative Merits and Demerits of the Various Styles of Hangar Doors | jls | Home Built | 1 | October 1st 04 02:52 AM |
| Sailplane Hangar Doors | TOM RENT | Soaring | 2 | April 21st 04 04:40 AM |
| The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Naval Aviation | 0 | April 6th 04 01:58 AM |
| The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Military Aviation | 0 | April 6th 04 01:58 AM |
| The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Aviation Marketplace | 0 | April 6th 04 01:57 AM |
