I don't have an aviation background. What is the typical angle of
landing/approach for commercial airliners? There's an illusion for novices, and it seems like the angle is much greater, even 30 degrees or more, but I remember hearing it is much less, like under 10. At what angle would the passengers complain of a rough landing. |
It is typically 3 to 3.5 degrees.
Rod "Tim923" wrote in message ... I don't have an aviation background. What is the typical angle of landing/approach for commercial airliners? There's an illusion for novices, and it seems like the angle is much greater, even 30 degrees or more, but I remember hearing it is much less, like under 10. At what angle would the passengers complain of a rough landing. |
Tim923 wrote:
I don't have an aviation background. What is the typical angle of landing/approach for commercial airliners? There's an illusion for novices, and it seems like the angle is much greater, even 30 degrees or more, but I remember hearing it is much less, like under 10. At what angle would the passengers complain of a rough landing. Unless the terrain or noise considerations require otherwise, the standard approach glide angle is 3 degrees (about 1 to 20). -- Tauno Voipio tauno voipio (at) iki fi |
Tim923 wrote: I don't have an aviation background. What is the typical angle of landing/approach for commercial airliners? There's an illusion for novices, and it seems like the angle is much greater, even 30 degrees or more, but I remember hearing it is much less, like under 10. At what angle would the passengers complain of a rough landing. They follow a three degree glideslope to landing. They do, however, flare for landing, which raises the deck angle at touchdown. |
![]() "Orval Fairbairn" wrote in message news ![]() In article , Tim923 wrote: I don't have an aviation background. What is the typical angle of landing/approach for commercial airliners? There's an illusion for novices, and it seems like the angle is much greater, even 30 degrees or more, but I remember hearing it is much less, like under 10. At what angle would the passengers complain of a rough landing. They follow a three degree glideslope to landing. They do, however, flare for landing, which raises the deck angle at touchdown. Hi Orval; My airliner experience is somewhat limited to say the least. I did put a stretch DC8 down once as a "guest of the line", but that's about it :-)) Although the glide slope angle is correct, the deck angle for a normal approach should be somewhat higher than the 3 degree glide slope and will be related to angle of attack on the wing, which for an airliner should be a function of the GW, airspeed, and configuration for the approach. In a fighter like the Viper for example, on approach, the Hud will show a difference between the FPM (flight path marker....the extension of the velocity vector or where the airplane is actually going) and the GC (gun cross.....the actual line through the airplane's nose or longitidudinal axis.) The difference between these two indicators is the AOA on the wing. Normal approach AOA for the Viper is on speed between 12.75 and 13.25 degrees. You fly the approach at 13 max. For an airliner using GW and a computed airspeed for that GW on approach, I would be looking for the deck angle to be somewhat higher and stabilized above that 3 degree glide slope. Dudley |
"Dudley Henriques" wrote in message
My airliner experience is somewhat limited to say the least. I did put a stretch DC8 down once as a "guest of the line", but that's about it :-)) Although the glide slope angle is correct, the deck angle for a normal approach should be somewhat higher than the 3 degree glide slope and will be related to angle of attack on the wing, which for an airliner should be a function of the GW, airspeed, and configuration for the approach. Most airliner pax will feel their seats tipped back between 2 and 10 degrees on downwind, -1 to 6 degrees on final, and 2 to 10 degrees at touchdown. Airspeed is usually adjusted to maintain a similar deck angle for each approach, however, individual techniques of pilots and/or autopilots will vary. If you land a stretch -8 and hit anywhere near the runway environment, you are doing good ;-) D. |
![]() "Capt.Doug" wrote in message ... "Dudley Henriques" wrote in message My airliner experience is somewhat limited to say the least. I did put a stretch DC8 down once as a "guest of the line", but that's about it :-)) Although the glide slope angle is correct, the deck angle for a normal approach should be somewhat higher than the 3 degree glide slope and will be related to angle of attack on the wing, which for an airliner should be a function of the GW, airspeed, and configuration for the approach. Most airliner pax will feel their seats tipped back between 2 and 10 degrees on downwind, -1 to 6 degrees on final, and 2 to 10 degrees at touchdown. Airspeed is usually adjusted to maintain a similar deck angle for each approach, however, individual techniques of pilots and/or autopilots will vary. If you land a stretch -8 and hit anywhere near the runway environment, you are doing good ;-) I have to admit; that bird was about the laziest airplane on approach I've ever been in :-)) About halfway down the slope I managed to get ahead of it somewhere in the vicinity of where I had to be to satisfy the FD109. It was the flattest touchdown I've ever made. Had the chief pilot of the line in the right seat. (Just a crew on board for a ferry flight) At least he didn't seem all that scared :-)) Dudley Henriques |
I have to admit; that bird was about the laziest airplane on approach I've ever been in :-)) About halfway down the slope I managed to get ahead of it somewhere in the vicinity of where I had to be to satisfy the FD109. It was the flattest touchdown I've ever made. Had the chief pilot of the line in the right seat. (Just a crew on board for a ferry flight) At least he didn't seem all that scared :-)) I got to watch some sim evaluations for job interview candidates once. It was wonderfully entertaining. The candidates came from regionals flying glass cockpit CRJs. They were used to sprightly performance with good power. Their scanning skills were diminished because of the glass and the autothrottles. The evals took place in the stretch DC-8 sim. One of candidates actually landed close to the runway. All of them went out of box with a ghostly shade of gray. Very humbling. D. |
Orval Fairbairn wrote:
In article , Tim923 wrote: I don't have an aviation background. What is the typical angle of landing/approach for commercial airliners? There's an illusion for novices, and it seems like the angle is much greater, even 30 degrees or more, but I remember hearing it is much less, like under 10. At what angle would the passengers complain of a rough landing. They follow a three degree glideslope to landing. They do, however, flare for landing, which raises the deck angle at touchdown. The deck angle isn't the same as the glideslope during a lot of the approach (and the same goes for takeoff). That's a common misconception that non-pilots have...that the airplane is always flying along it's longitudinal axis. |
Ron Natalie wrote: Orval Fairbairn wrote: In article , Tim923 wrote: I don't have an aviation background. What is the typical angle of landing/approach for commercial airliners? There's an illusion for novices, and it seems like the angle is much greater, even 30 degrees or more, but I remember hearing it is much less, like under 10. At what angle would the passengers complain of a rough landing. They follow a three degree glideslope to landing. They do, however, flare for landing, which raises the deck angle at touchdown. The deck angle isn't the same as the glideslope during a lot of the approach (and the same goes for takeoff). That's a common misconception that non-pilots have...that the airplane is always flying along it's longitudinal axis. I wasn't sure what the poster wanted -- whether he meant glide angle (as seen from an observer on the ground) or the deck angle (as seen by a passenger aboard). I think that he meant deck angle. |
Check this Approach & Landing out! | nmg175 | Naval Aviation | 5 | September 27th 06 02:07 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Wow - heard on the air... (long) | Nathan Young | Piloting | 68 | July 25th 05 06:51 PM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
