Hi,
Could anyone give me a good explanation for OCA/OCH. I know it has something to do with the minimums of ILS-approaches and it should always be lower than or equal to the DA/DH. I assume it provides you with a certain obstacle clearance at DA/DH. But how is it determined???? Best regards, Tim |
"Tim" wrote in message
om... Hi, Could anyone give me a good explanation for OCA/OCH. I know it has something to do with the minimums of ILS-approaches and it should always be lower than or equal to the DA/DH. I assume it provides you with a certain obstacle clearance at DA/DH. But how is it determined???? [ICAO version, YMMV, particularly if you use different sized miles.] Obstacle clearance altitude OCH is the height on an IAP with the minimum permitted clearance above obstacles on the final approach. It does not take account the limitations associated with the navaid (system minimum). Thus the DH or MDH is the higher of the OCH or the system minimum. The OCA is obviously the altitude corresponding to the OCH. For non-precision approaches the OCH is the height of the highest obstacle on the final approach segment plus a speed-dependent margin. Precision approach OCHs are more complex, I think. Most Cat I ILSs are limited by the system minimum of 200 ft rather than the OCH. Julian Scarfe |
Thanks a lot.
Happy landings, Tim |
Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 02:34 PM |
Q about lost comms on weird clearance | Paul Tomblin | Instrument Flight Rules | 34 | February 2nd 04 09:11 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
Picking up a Clearance Airborne | Brad Z | Instrument Flight Rules | 30 | August 29th 03 01:31 AM |
