DIY antenna for handheld transceiver
Old November 9th 06, 09:38 PM posted to rec.aviation.homebuilt
Brad Lewandowski
Default DIY antenna for handheld transceiver
I'm going to try and make an antenna as shown in Kitplanes MAR 2006
("Rubber Duckie, Your'e the One..).
Does it matter if the copper foil is 1/4 or 1/2 inch wide?
Does the balun have to be right in the middle (if I want to put in
a PVC tube it wouldn't fit with a balun in the middle) or can it be at
the bottom of the dowel with longer leads?
Anybody make one of these successfully?
Thanks!
Brad
Old November 10th 06, 06:16 PM posted to rec.aviation.homebuilt
RST Engineering
"Brad Lewandowski" wrote in message
It works surprisingly well for such a simple little rascal.
The wider the foil, the wider the "goodness" of the bandwidth. Goodness is
purely a subjective term, and for a receiver you'd probably be OK with #12
or #14 copper wire stripped from a piece of romex if that's what you've got
on hand. I've built dozens of field-stripped antennas from house wiring
that was laying around and they all worked passaably well. The only reason
I used foil is that it lays flat against the dowel and is easy to work with
(besides the aforementioned bandwidth).
The balun has to be in the middle if a dipole is what you are going after.
There is a design for an end-fed coil-loaded vertical dipole, but it
requires some special tiny coax (RG-174) and a fairly critical number of
turns around a fairly critical diameter dowel.
Having said that, you can solder the coax to the dipole copper elements on
the dowel, slide the dowel into a PVC Tee until the center of the dipole
lets you run the coax out the third arm of the Tee, and then attach the
balun as close to the antenna as you can. You can then glue as long an
arm(s) as you need onto the Tee to weatherproof the antenna.
Other than the one I did for the article? {;-)
Thanks!
Brad
Old December 1st 06, 05:03 AM posted to rec.aviation.homebuilt
Brad Lewandowski
One last question Jim,
I looked up the digi-key 240-2325-ND you reference in the article,
but the hole in the ferrite is only .043" high. The 174 coax appears to
be .103" OD. It doesn't seem like it would fit. Should I be looking for
a different balun? How about the 240-2337-ND with an .108" opening?
Thanks for your help.
Brad
On Nov 10, 1:16 pm, "RST Engineering" wrote:
"Brad Lewandowski" wrote in ooglegroups.com...
("Rubber Duckie, Your'e the One..).It works surprisingly well for such a simple little rascal.
Does it matter if the copper foil is 1/4 or 1/2 inch wide?The wider the foil, the wider the "goodness" of the bandwidth. Goodness is
the bottom of the dowel with longer leads?The balun has to be in the middle if a dipole is what you are going after.
Anybody make one of these successfully?Other than the one I did for the article? {;-)
Thanks!
Brad- Hide quoted text -- Show quoted text -
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 06:59 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
LS-4 Transponder antenna location? Matt Herron Soaring 3 February 25th 04 03:45 PM
