My fuel servo is coming back from the shop. I wish I better understood
how they work. One day my plane just stated running so rich that I could almost not keep the engine runnnig. I was pulling about 7GPH at 1500 (normal is about 3). However, if I shutdown and restarted it would run correctly about 10% of the time. So the fuel shop received it and noticed the FF was too high. They replaced a spring and got the flows in line. However, now I'm worried that they fixed the 90% case and not the 10% case (which was normal). If they replaced a spring with a lighter spring, how would that solve the issue? Why did this happen all of the sudden? Why isn't it consistant? My plane has been down for 3 weeks now and I fear I'll get the unit back and it won't work and I'll be down even longer (with a full FF overhaul). The fuel servo has 900 SFNEW. Is there an on-line diagram of a fuel servo? I'd like to better understand how the springs, diaphrams, etc work. I'm told there are only a few moving parts, but not sure what they are. -Robert, M20F |
Google for "Bendix fuel flow divider" and you'll find pages
such as http://www.dgsupply.com/trouble.html and especially http://www.precisionairmotive.com/rsasupport.htm For a full description get FAA AC 65-12A, which is on-line. Chapter 3 has what you want. "Robert M. Gary" wrote in message oups.com... | My fuel servo is coming back from the shop. I wish I better understood | how they work. One day my plane just stated running so rich that I | could almost not keep the engine runnnig. I was pulling about 7GPH at | 1500 (normal is about 3). However, if I shutdown and restarted it would | run correctly about 10% of the time. | So the fuel shop received it and noticed the FF was too high. They | replaced a spring and got the flows in line. However, now I'm worried | that they fixed the 90% case and not the 10% case (which was normal). | If they replaced a spring with a lighter spring, how would that solve | the issue? Why did this happen all of the sudden? Why isn't it | consistant? My plane has been down for 3 weeks now and I fear I'll get | the unit back and it won't work and I'll be down even longer (with a | full FF overhaul). The fuel servo has 900 SFNEW. | | Is there an on-line diagram of a fuel servo? I'd like to better | understand how the springs, diaphrams, etc work. I'm told there are | only a few moving parts, but not sure what they are. | | -Robert, M20F | |
![]() Jim Macklin wrote: Google for "Bendix fuel flow divider" and you'll find pages such as http://www.dgsupply.com/trouble.html and especially http://www.precisionairmotive.com/rsasupport.htm For a full description get FAA AC 65-12A, which is on-line. Chapter 3 has what you want. I didn't see a diagram of the servo in the above link. I found the AC (which was very interesting) but it seemed to only talk about carbs. -Robert |
It talks about all types of systems, scroll further.
"Robert M. Gary" wrote in message oups.com... | | Jim Macklin wrote: | Google for "Bendix fuel flow divider" and you'll find pages | such as | http://www.dgsupply.com/trouble.html and especially | http://www.precisionairmotive.com/rsasupport.htm | | For a full description get FAA AC 65-12A, which is on-line. | Chapter 3 has what you want. | | I didn't see a diagram of the servo in the above link. I found the AC | (which was very interesting) but it seemed to only talk about carbs. | | -Robert | |
![]() Jim Macklin wrote: It talks about all types of systems, scroll further. Cool, thanks! It looks like all the movable parts are part of the spring. I guess its possible the spring was hanging up or something. The shop said the mixture control is a moving part but that its a very simple ball that turns and doesn't cause problems. I'll cross my fingers that its fixed. If so, I got of easy. $160 plus R&R. If not, I'll be looking at $1500 plus R&R. -Robert |
Glad to help. The FAA manuals, 65-9, 65-12, and 65-15 are
on-line as is 43-13. You can also find a lot of manufactures stuff if you search well and pick the proper terms. "Robert M. Gary" wrote in message oups.com... | | Jim Macklin wrote: | It talks about all types of systems, scroll further. | | Cool, thanks! It looks like all the movable parts are part of the | spring. I guess its possible the spring was hanging up or something. | The shop said the mixture control is a moving part but that its a very | simple ball that turns and doesn't cause problems. I'll cross my | fingers that its fixed. If so, I got of easy. $160 plus R&R. If not, | I'll be looking at $1500 plus R&R. | | -Robert | |
Jet fuel A-1 specific gravity | [email protected] | Piloting | 7 | May 20th 06 04:39 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 02:50 AM |
