clearance delivery question
Old November 17th 04, 01:59 PM
PaulH
Default clearance delivery question
If I file an IFR flight plan 2 hours in advance from departure from a
towered airport and then leave really early or really late:
1. Is the FP normally available to my local tower about half an hour
after filing?
2. How long does it remain in the "system" if I get delayed?
Old November 17th 04, 02:44 PM
Dave Butler
after filing?
In my experience, typically within 10 minutes or so.
I think typically 2 hours, but I don't think there's any guarantee or
specification. Your mileage may vary.
Old November 17th 04, 02:50 PM
Michelle P
It is supposed to be available -30 minutes to +2 hours. It can be
longer. It is not supposed to be shorter.
Michelle
after filing?
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old November 17th 04, 03:19 PM
Roy Smith
after filing?
Flight Plans tend to be available almost immediately after filing. I
suppose this depends on where you are, but that's been my experience
around New York.
If you're going to be delayed, just call up clearance delivery and ask
the controller to modify the P-time to be whenever you think you'll be
ready to leave. That'll make sure it doesn't time out and disappear.
Old November 17th 04, 03:27 PM
Newps
after filing?
The FP is there 30 minutes prior to your P time. When you file is not
relavant. If you want to leave earlier than 30 minutes before your P
time the controller will go into the computer and type in this...AM
N12345 tim Pxx00 That tells the computer to change the P time to the
current time, thus generating the strip for the controller so he can
read you your clearance.
The default is two hours after the P time. In some very busy locations
they may shorten this up to free up some more transponder codes.
Old November 19th 04, 08:50 PM
OtisWinslow
newps,
Do you work for ATC? You pass on good info to us .. thanks.
Old November 19th 04, 09:19 PM
Newps
Yes.
OtisWinslow wrote:
newps,
Old November 17th 04, 03:34 PM
Steven P. McNicoll
"PaulH" wrote in message
om...
after filing?
The flight plan will be available at your local tower as soon as it's
entered in the ATC computer. A strip won't be printed until 30 minutes
prior to your proposed departure time. If you call before that time the
controller can amend the proposed departure time so that the strip will
print immediately.
Normally two hours after your proposed departure time. The flight plan drop
interval can be extended and that normally is done when weather delays
departures.
Old November 17th 04, 04:15 PM
Ali Ghorashi
I think the AIM (see 5-1-11) says that flight plans will stay in the ATC
computer 1 hour after departure. Also, AIM paragraph 5-1-7 says that: "
Pilots should file IFR flight plans at least 30 minutes prior to estimated
time of departure to preclude possible delay in receiving a departure
clearance from ATC.".
There's a lot of good information in that "little" book.
-Ali
om...
after filing?
Old November 17th 04, 04:35 PM
Newps
After you depart the flight plan stays active until you land or cancel it.
I wouldn't worry about this. If you call AFSS on the radio and tell
them you want to depart now the strip comes up immediately in front of
the controller.
Pop-up IFR from Clearance Delivery Andrew Sarangan Instrument Flight Rules 43 March 28th 04 07:20 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
AFSS clearance delivery Dan Luke Instrument Flight Rules 7 February 9th 04 12:56 AM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
