I want to get current on my VFR Single Engine Land license but my eyes
are not what they used to be. The strength I need for good far vision makes it so I can't read charts in the cockpit without taking them off. I figured I would try a progressive lens because I thought it would eliminate the extra task of taking my glasses off to look at a chart (less work load is good right?), but I'm concerned about a few things: 1) the distortion of my peripheral vision for the top part of the lens, let alone the bottom part. 2) the narrowness of the "corridor" that forces me to turn my head for every single thing I want to look at... flight instruments and radios are far enough apart to require a head turn. 3) can't view the entire width of a 81/2 piece of paper. I can only get good focus on about 1/3 of it. The beginning and ends of the sentence will be out of focus. 4) how much of my attention will be on getting my glasses to work vs. looking out the window or at my instruments. Any thoughts, ideas or personal experience you would care to relate would be very much appreciated. Thanks in advance. |
![]() "skyfish" wrote in message 0... I want to get current on my VFR Single Engine Land license but my eyes are not what they used to be. The strength I need for good far vision makes it so I can't read charts in the cockpit without taking them off. I figured I would try a progressive lens because I thought it would eliminate the extra task of taking my glasses off to look at a chart (less work load is good right?), but I'm concerned about a few things: 1) the distortion of my peripheral vision for the top part of the lens, let alone the bottom part. 2) the narrowness of the "corridor" that forces me to turn my head for every single thing I want to look at... flight instruments and radios are far enough apart to require a head turn. 3) can't view the entire width of a 81/2 piece of paper. I can only get good focus on about 1/3 of it. The beginning and ends of the sentence will be out of focus. 4) how much of my attention will be on getting my glasses to work vs. looking out the window or at my instruments. Any thoughts, ideas or personal experience you would care to relate would be very much appreciated. Thanks in advance. I don't leave home without them. Haven't since they became available. They beat the bi/tri focal alternative all to heck. I have none of the problems you mention. Sounds like you have a lousy set of optics. |
You say you "want to try" progressives, then you list a series of disadvantages
that are of concern to you. It is not clear (to me) whether you already use progressives, and you want to try them in flying, or if the disadvantages you list are simply things you have heard, or are wondering about. You will hear many opinions for and against, so it's a personal issue. For my part, I use them in flying and driving, and I find them to be a good solution to the near/far requirement of VFR flying (charts/distant view). I am not bothered by any of the specific concerns you list. Two things though : Apparently there are significant differences in quality of products available, and this affects the size of the "useful" area. Get good progressives, and don't go for tiny little sliver lenses to look cool - it's impossible to make good progressives with these lens shapes. Secondly, it does not appear to be your case, but it's probably not a good idea to learn to fly and to learn to wear progressives at the same time. This will slow down the expensive training, because progressives take a significant amount of getting used to. Just WALKING the first time can be an experience! I am moderately myopic. I don't wear glasses for reading, and I read the instrument panel comfortably without glasses. I need glasses to drive or fly safely (though I do practice landings, with safety pilot, without glasses as well). For me, progressives are an excellent solution, because, like you I would otherwise have to take my glasses of to easily read a chart on my knee. GF |
![]() "Greg Farris" wrote in message ... snip Two things though : Apparently there are significant differences in quality of products available, and this affects the size of the "useful" area. Get good progressives, and don't go for tiny little sliver lenses to look cool - it's impossible to make good progressives with these lens shapes. snip GF I've been using progressives for close to 20 years (pilot for 23 years). I tried bifocals about 10 years ago (bought a set of progressives and a set of bifocals with the same hi-lo focal lengths). I wore the bifocals for about 2 hours and went back to the progressives immediately. I do agree with Greg: It is impossible to get good progressive performance if the lenses are small in the vertical dimension. The change in focal length over the diameter of the pupil is just too great....and my eyes cannot adjust. So just avoid the short vertical lenses. My 2cents, John Severyn @KLVK |
0... I want to get current on my VFR Single Engine Land license but my eyes are not what they used to be. The strength I need for good far vision makes it so I can't read charts in the cockpit without taking them off. I figured I would try a progressive lens because I thought it would eliminate the extra task of taking my glasses off to look at a chart (less work load is good right?), but I'm concerned about a few things: 1) the distortion of my peripheral vision for the top part of the lens, let alone the bottom part. 2) the narrowness of the "corridor" that forces me to turn my head for every single thing I want to look at... flight instruments and radios are far enough apart to require a head turn. 3) can't view the entire width of a 81/2 piece of paper. I can only get good focus on about 1/3 of it. The beginning and ends of the sentence will be out of focus. 4) how much of my attention will be on getting my glasses to work vs. looking out the window or at my instruments. Any thoughts, ideas or personal experience you would care to relate would be very much appreciated. My personal experience: After almost 48 years, I finally had to get glasses. I can see at distance fine but anything closer than about 3 feet, I can't focus on. I tried the no-line bifocals (progressives?) for about a month but couldn't get use to them. The field of view (in focus) was narrow and I had to turn my head more than I was use to. I did try flying with them and didn't have any problems with reading charts, gauges, scanning for traffic or landing... I took the no-line bifocals back and got regular tri-focals now and they work great, for me, for reading, working on the computers, driving and flying. The top major part of these trifocals is mostly clear. The first magnification works well for reading the computer monitors at about arms length. The bottom is for reading closer up. -Greg B. |
On Fri, 17 Nov 2006 00:01:29 -0600, Greg B wrote:
I took the no-line bifocals back and got regular tri-focals now and they work great, for me, for reading, working on the computers, driving and flying. The top major part of these trifocals is mostly clear. The first magnification works well for reading the computer monitors at about arms length. The bottom is for reading closer up. It kind of depends upon your prescription and what your typical viewing tasks might be... I had the progressives on my last prescription... The problem that I encountered was that the prescription needed for looking at a computer monitor was down towards the bottom of the lenses and as such, I would spend most of the day with my head tilted back... For me, this tended to result in a strain in the neck muscles towards the rear of the head near the shoulders... I had a large set of lenses, so I had plenty of glass to work with for the variation in the prescription as it goes from the top of the lense to the bottom... When you first get them, you will find your head going up and down as you try to find the sweet spot for focus... After awhile, you don't notice yourself doing it anymore -- that doesn't mean that you don't do it, but it gets more automatic so you don't notice it... These days, I have two prescriptions for two sets of glasses... For one, it is a moderate prescription that is best for computer monitor distances... For the other, it is for far vision... For really close vision, I can just take my glasses off and see ok... My eyesight hasn't gotten so bad that I need a '+' diopter for my near vision at least... Sometimes I forget and wear the wrong glasses when I'm driving... Things are a bit more blurry at a distance, but it's better than not having any glasses on... One additional thing that I have noticed though is that the older glasses were better for riding a motorcycle since the larger lenses blocked more of the wind from hitting your eyes... My new glasses have lenses that are probably half as high as the previous glasses... -- "Is it possible for the voices in my head to use email from now on?" |
I have progressives, but they are for reading. My far vision is fine, but my
arms have gotten shorter over the years. ;-) The only problem I had at first was, since the bottom of my glasses magnify, my view of the runway on landing appeared closer than it actually was. I was flaring too high. Not much, but enough to make a bumpy landing. I also feel about a foot taller when I take them off. Yours might be a little more problematic, but I think you will adapt over time. My brother-in-law has progressive trifocals. Talk about a PITA. You get used to them after a while. mike "skyfish" wrote in message 0... I want to get current on my VFR Single Engine Land license but my eyes are not what they used to be. The strength I need for good far vision makes it so I can't read charts in the cockpit without taking them off. I figured I would try a progressive lens because I thought it would eliminate the extra task of taking my glasses off to look at a chart (less work load is good right?), but I'm concerned about a few things: 1) the distortion of my peripheral vision for the top part of the lens, let alone the bottom part. |
mike regish wrote:
Yours might be a little more problematic, but I think you will adapt over time. My brother-in-law has progressive trifocals. Talk about a PITA. You get used to them after a while. He either has trifocals or progressives, but not both. Trifocals have three distinct lens whereas progressives blend continuously and thus have theoretically an infinite range of powers. Matt |
OK. They are progressives with 3 different focal lengths.
Now do you know what I meant? I'm not a freakin' optician. mike "Matt Whiting" wrote in message ... mike regish wrote: Yours might be a little more problematic, but I think you will adapt over time. My brother-in-law has progressive trifocals. Talk about a PITA. You get used to them after a while. He either has trifocals or progressives, but not both. Trifocals have three distinct lens whereas progressives blend continuously and thus have theoretically an infinite range of powers. Matt |
skyfish wrote:
I want to get current on my VFR Single Engine Land license but my eyes are not what they used to be. The strength I need for good far vision makes it so I can't read charts in the cockpit without taking them off. I figured I would try a progressive lens because I thought it would eliminate the extra task of taking my glasses off to look at a chart (less work load is good right?), but I'm concerned about a few things: 1) the distortion of my peripheral vision for the top part of the lens, let alone the bottom part. 2) the narrowness of the "corridor" that forces me to turn my head for every single thing I want to look at... flight instruments and radios are far enough apart to require a head turn. 3) can't view the entire width of a 81/2 piece of paper. I can only get good focus on about 1/3 of it. The beginning and ends of the sentence will be out of focus. 4) how much of my attention will be on getting my glasses to work vs. looking out the window or at my instruments. Any thoughts, ideas or personal experience you would care to relate would be very much appreciated. Thanks in advance. I got my progressive lens three years ago. Yes, they are a pain for all of the reasons you mention, but you get used to them and they aren't a big limitation for flying. I find them more annoying for general reading where you are constantly scanning lines in a book or magazine. Keep in mind that your peripheral vision is typically not very high acuity anyway and is mostly motion sensitive. I haven't found the distortion in the periphery to be a big handicap in that regard. I can still pick up motion in the periphery and then turn to view it. I do find reading approach charts at night to be more difficult with these glasses, but then I can still read up close reasonably well without my glasses so I usually just look over or under them to read the find details. It took me several weeks to adapt to the progressives and I still don't like them much, but I think they are better than the alternatives. Matt |
line vs progressive lenses for sunglasses | Kevin Anderson | Soaring | 22 | September 20th 06 08:23 AM |
Speaking of Vision -- How 'bout Progressive Bifocals? | Jay Honeck | Piloting | 91 | June 13th 06 09:38 PM |
Prescription Lenses (sorta OT) | John | Home Built | 22 | January 3rd 05 03:05 PM |
Prescription Lenses (sorta OT) | John | Piloting | 20 | January 3rd 05 03:05 PM |
