GPS clearance puzzle
Old December 1st 04, 03:39 AM
Roy Smith
Default GPS clearance puzzle
Apparently, if you file IFR HPN - MMU, you get a clearance which starts
"CMK CMK275R SAX039R SAX" (i.e. fly outbound on the CMK 275 until you
intercept the SAX 039, then fly that inbound to SAX). In the good old
days of 2 VOR receivers, this is trivial to fly; the radios don't know
or care that the cross-radial fix you're going to doesn't have a name.
But, how would you fly that with a GPS?
I've been puzzling over that one for a week or so now, and the best I
can come up with is to use the GPS's OBS mode to track outbound on the
CMK 275, and set up a VOR receiver to indicate the crossing radial.
Can anybody figure out a way to set it up purely on the GPS? I'm using
a CNX-80, but it might be interesting to see how other units would do it
too.
Old December 1st 04, 04:21 AM
Andrew Gideon
Interesting. I flew from BVY to CDW this past Monday. My clearance ended
... CMK V? SAX Direct
As I was approaching the CMK VOR, I was told to depart on the 275 radial.
When I acknowledged that, I was told: "Oh, let's make this easy" and was
told to follow the airway to SAX (I forget which V that was at the moment).
The difference between the airway and the 275R is pretty slight. Extra room
for EWR or TEB departures (the wind was from the northeast)? Something
else?
Either way, I appreciated sticking with the airway. It saved me from having
to find the CDI button on the 430 grin.
- Andrew
Old December 1st 04, 06:06 AM
Steven P. McNicoll
"Roy Smith" wrote in message
too.
Determine the point of intersection of the radials and fly direct to that
point from CMK then direct to SAX.
Old December 1st 04, 11:45 AM
too.
If you get it a lot, set up a user waypoint.
If you know the distance off one of the VOR's, it should be easy.
If you fly it repeatedly, push the MARK button (or equivalent) the
next time you fly over it.
Old December 1st 04, 02:13 PM
Ron Rosenfeld
too.
The only way I know of to due it "purely" with the GPS mode would be to set
up a user waypoint at the intersection of those two radials.
But what I would do with my CNX80, assuming that was not worthwhile, would
be to also use it's VOR mode. I would set up an OBS track to SAX on the
039R. That should give a display on the screen. I would then use the VOR
mode to fly direct CMK and outbound on the CMK 275 until I intercepted the
course to SAX. Then I would switch back to GPS mode.
--ron
Old December 1st 04, 03:40 PM
gwengler
Roy Smith wrote in message ...
too.
Use the GPS's OBS mode to fly outbound on the radial from the first
VOR. Then call up the second VOR on the GPS (for example through the
Nearest function or the VOR page or on any other information page).
There you will see the actual radial/bearing from or to the second VOR
depending on how you have set it up. Once you reach the required
radial from the second VOR you go direct to or continue using the OBS
mode with the second VOR as a new waypoint.
Gerd, ATP
T182 C-FDOW
Old December 1st 04, 05:06 PM
Roy Smith
Sounds like a good plan, thanks!
Old December 2nd 04, 08:13 PM
Andrew Gideon
Yes, thanks! I was going over the 430 manual last night trying to find
something of this sort, but I missed it.
Those flying behind the navcoms in newer Cessnas have a similar/easier
option. The nav side can be set to display the to/from radial instead of
the standby frequency. I liked the awareness that provided, given that I
could see "how close I was" to some chosen radial even before the needle
had "come alive".
- Andrew
Old December 2nd 04, 09:26 PM
Roy Smith
had "come alive".
You can do that on the CNX-80 too. In NAV mode, hit the MON soft-key
to put it in monitor mode. It then shows you the from radial of the
VOR in the standby slot.
Old December 1st 04, 03:45 PM
Mike Rapoport
On a 430/530 you can create a user waypoint based on radials from waypoints
in the database. I created someof these user waypoints when I was given the
same clearance often. Most of the time I use the method you described with
OBS and a VOR reciever to locate the crossing radial.
Mike
MU-2
too.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 12:40 AM
