I am aware that in real planes most commands are made through the
conventional flight controls - however there are some operations that simply *require* a keyboard. Fuel management, for example. Let's say I want to fly my Baron from Boisie, Idaho to Khartoum. I have done in-depth calculations, involving complex algorithms and in my estimation, even if I start with full fuel, I may run out before I get to Sudan. In this case, without a keyboard to re-establish a given fuel level, the flight cannot continue. Looking at pictures of real planes, I do not see any dedicated button on the panel to accomplish this function, so I can only assume there must be a keyboard input *somewhere* - but WHERE? I cannot see it anywhere! Another example - on a short hop from Los Angeles (LAX) to Chicago (ORD). Obviously fuel is no problem on this short distance, but there is a long, boring section, after crossing the Rockies at FL370 - the terrain levels out, and it seems to take forever to get up to the Midwest plains and make my approach to O'hare. I would like to just skip this whole section, but once again I find no function in the real plane allowing me to do this. So there must be a keyboard input . . . Please be so kind as to enlighten me. In return I will challenge everything you say and tell you you are simply not smart enough to grasp my algorithms. . . |
Stuff $100 bills into the CD Drive and fuel comes out the USB port?
"Greg Farris" wrote in message
... In article .com, says... Stuff $100 bills into the CD Drive and fuel comes out the USB port? The cemeteries of the US are overflowing with the corpses of dangerous pilots like yourself! The Baron is too old to have a USB port - they certainly had their keyboards connected through RS-232 serial ports. I have designed many such aircraft, and I must say I would feel a lot safer if I didn't have to share the skies with people like you. Your attitude shows you have little respect for the truth. You are correct. The correct procedure is to use a Sinclair ZX-81, enter the program, and save it to tape. If you'll notice, this uses the same 1/8" jack as the line-in or music-in on your intercom. If you don't have a newer intercom, you'll need to enter the commands four bits at a time using the Fuel Pump, Nav lights, landing light, rotating beacon switches. ( see http://home.att.net/~n6480r/IMG_1340.JPG ) When you have the correct arrangements of switches, depress the starter button. |
Steve,
The correct procedure is to use a Sinclair ZX-81 Which is the last safe computer for flying, too. I know since I worked as cleaning personal in a Sinclair shop before they outsourced my job to Bangalore. -- Thomas Borchert (EDDH) |
"Steve Foley" wrote You are correct. The correct procedure is to use a Sinclair ZX-81, enter the program, and save it to tape. If you'll notice, this uses the same 1/8" jack as the line-in or music-in on your intercom. If you don't have a newer intercom, you'll need to enter the commands four bits at a time using the Fuel Pump, Nav lights, landing light, rotating beacon switches. ( see http://home.att.net/~n6480r/IMG_1340.JPG ) When you have the correct arrangements of switches, depress the starter button. NO! Don't do that. That is the back door way to fire the ejection seat! -- Jim in NC |
pilots like yourself! The Baron is too old to have a USB port That's why it's important to get a floppy. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
The new Baron's come with special dilithium crystal fuel
conversion units that use the Earth's static electrical fields as a power source to synthesize gasoline in the fuel tanks by converting the coffee as the second step in the process. The pilot and passengers all drink a lot of coffee in order to extend the range. One cup of coffee makes 24 gallons of gasoline. "Greg Farris" wrote in message ... |I am aware that in real planes most commands are made through the | conventional flight controls - however there are some operations that | simply *require* a keyboard. Fuel management, for example. | | Let's say I want to fly my Baron from Boisie, Idaho to Khartoum. I have | done in-depth calculations, involving complex algorithms and in my | estimation, even if I start with full fuel, I may run out before I get to | Sudan. In this case, without a keyboard to re-establish a given fuel | level, the flight cannot continue. Looking at pictures of real planes, I | do not see any dedicated button on the panel to accomplish this function, | so I can only assume there must be a keyboard input *somewhere* - but | WHERE? I cannot see it anywhere! | | Another example - on a short hop from Los Angeles (LAX) to Chicago | (ORD). Obviously fuel is no problem on this short distance, but there is | a long, boring section, after crossing the Rockies at FL370 - the | terrain levels out, and it seems to take forever to get up to the Midwest | plains and make my approach to O'hare. I would like to just skip this | whole section, but once again I find no function in the real plane | allowing me to do this. So there must be a keyboard input .. . . | | Please be so kind as to enlighten me. In return I will challenge | everything you say and tell you you are simply not smart enough to grasp | my algorithms. . . | |
I believe that our Aztec used to have it's keyboard in a "map tray" located
under the co-pilots panel, but since previous owners removed the map tray, I can only assume that they discarded the keyboard. Obviously this decreased the value of our aircraft tremendously. I have noticed remnants of the previous "map tray/keyboard" install such as the tray rails and the power connection and I'm hoping to one day find a replacement keyboard and data cable on ebay. It sure would be nice to have that "auto-fuel" button. Because our plane has injected low compression engines, we can't get the auto fuel STC, so my only hope is to find a keyboard with the factory installed auto fuel function. I don't think our plane came with the "fast forward" function, I believe that was only available in the turbo models. If you have a Baron, you might try calling Jet-Prop Conversions, I think they sell an STC'd Fast Forward package for the Baron. Jim |
| Obit: Jack Laister - Soaring Pioneer - November 19th 2006 | [email protected] | Soaring | 0 | November 21st 06 03:44 PM |
| Garmin GMA 340 Music Input | O. Sami Saydjari | Instrument Flight Rules | 16 | April 28th 05 01:51 AM |
| Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 02:54 AM |
| Cobra jack warning | Andy Durbin | Soaring | 8 | June 30th 04 03:32 AM |
| Red Baron vs. Rickenbacker? | Gregorso | Military Aviation | 28 | October 13th 03 08:26 PM |
