Well, my friend said 'I had it, but gave it away years
ago. Not sure where it went.' So, here is what I would do. Visit: http://www.faa.gov/licenses%5Fcertif...5Fcertificatio n/aircraft%5Fregistry/ The link will probably not come over complete, so you will need to finish it up. Look down a ways and under Records and Reports, you will find 'Request Copies of Records' and 'online'. You can enter the Registration Number and Serial Number. They will then ask for your address, etc. You can order it on CD for about $6.25 Or, you can call the Registration Branch of the FAA at 405-954-3116. Be prepared to be on hold for 5-10 minutes. Give them the registration number, and when they tell you it is something other than the plane you are looking for, tell them it was something else before that. Give them the model number or some other details, and they can narrow down on your airplane of interest. I have gotten records of airplanes that went off the registry in the late 1920s, so I am sure they will have something for you. Serial Number with the FAA was SHK-100. It was registered to Robert Kirby of Santa, Ynez, California. FAA's Make and Model Code was 05603V9. According to the Mircofiche records I have. From what I have seen in the past, it got de-registered sometime before 1986 (my earliest microfiche), most likely due to failure to return the trienial report (that was a major sin against humanity and the FAA back then!). Oh, and the contact was Ron Tabery. I still have not found the copies of the Used Sailplane List to get the date. If it was only 15 years ago, it might have returned to California after its trek to Texas. Keep searching. It is fun, and pretty cheap to find out what happened to some of these neat planes. Steve Leonard Wichita, KS |
From what I have seen in the past, it got de-registered sometime before 1986 (my earliest microfiche), most likely due to failure to return the trienial report (that was a major sin against humanity and the FAA back then!). Failure to respond now, or bounced addresses, will get your N-number suspended also. This happened earlier this year. I notified more than one pilot to contact the FAA when the N-number list and deadline came out. Frank Whiteley |
| Thread Tools | |
| Display Modes | |
| Where is the Matteson M-1? | Steve Leonard | Soaring | 2 | November 27th 06 09:11 PM |
| Where is the Matteson M-1? | Pete Startup | Soaring | 2 | November 26th 06 05:40 PM |
| Where is the Matteson M-1? | Pete Startup | Soaring | 0 | November 23rd 06 02:16 PM |
