RNP .3 Without GPS
Old December 23rd 04, 12:04 PM
Default RNP .3 Without GPS
Most RNAV approaches have the notations:
"GPS or RNP - 0.3 required", and
"DME/DME RNP - 0.3 not authorized"
1. The "or RNP .3" seems to imply some navigation unit other than gps
can have rnp .3 Any idea what?
2. If an FMS with rnp .3 is able to conduct this approach, wouldn't
it need a gps input to be that accurate? Surely IRS with dme updating
can't be used for any non prec approach?
2. Any approaches where dme/dme rnp .3 IS authorized?
Stan
Old December 24th 04, 05:53 AM
Gene Whitt
Y'All,
The following is just a small sample of a mix of need to know, nice to know
and what to know. The fact that there is also a diagram in the book makes
it more understandable. I believe that the .3 RNP level and lower can only
be reached with WAAS or LAAS still in the works.
RNP stands for Required Navigational Performance. This is described and
illustrated on Page 1-13 of the
2004 FAA-H8261-1 Instrrument Procedures Handbook. What follows is just the
INTRODUCTION. Test
questions will be based on material from subsequent chapters.
---.3RPN is the 3/10 of a nautical mile to each side of the final approach
course center line required for aircraft and equipment certification. This
is both a performance and functional requirement.for IFR certification
---The total system error (TSE) allowed in the final approach airspace due
to navigational system errors (NSE) includes computation errors, display
errors and flight technical errors (FTE) must not exceed .3 of a nautical
mile to either side of the final approach course center line.as laid out in
the ICAO Manual (Doc 9613). These .3 RNP on the final approach course (FAC)
and for the following air route areas must be both repeatable and
predictable to the declared levels of accuracy. For departure (1.0 RNP),
RNP 2.0.enroute, RNP 1.0 termina arrival and RNP 0.3 approach.
---The International Civil Aviation Organization (ICAO) uses RNP type for
airspace known as RNP-.0, RNP-4.0,
RPN-5.0 and RNP-10.0 The required performance is obtained through a
combination of aircraft capability and level of service provided by the
navigation infrastructor
---The following equation applies: Aircraft Capability + Level of Service =
Access
---RPN 0.3 is the lowest U.S. normal RNAV operation but special procedures
procedures use lower RNP levels.
Sample questions
1.What parts of the NAS have the same RPN?
2. What factors are included in finding the TSE due to NSE besidesFTE?
3. What part does the air route play in RNAV RNP levels?
4. Where do the ICAO and NAS have common RNPs?
5. How does the RNP 2.0 relate to airway width?
Old December 24th 04, 09:56 PM
Mike Rapoport
Why do you think that .3nm RNP can only be achieved with WAAS or LAAS?
MIke
MU-2
"Gene Whitt" wrote in message
nk.net...
Y'All,
know and what to know. The fact that there is also a diagram in the book
makes it more understandable. I believe that the .3 RNP level and lower
can only be reached with WAAS or LAAS still in the works.
the INTRODUCTION. Test
This is both a performance and functional requirement.for IFR
certification
in the ICAO Manual (Doc 9613). These .3 RNP on the final approach course
(FAC) and for the following air route areas must be both repeatable and
= Access
Sample questions
Old December 25th 04, 12:53 AM
Gene Whitt wrote:
Y'All,
That is incorrect. Today's RNAV IAPs are considered RNP 0.3 procedures but they
don't use linear containment areas.
Draft criteria for linear RNP containment area procedures to values as low as
0.10 and optionally using RF/TF legs has been completed by the FAA/Industry PARC
(performance-based advanced procedures group) and is awaiting signature from the
head shed.
WAAS will be required on these procedures only if an LPV glide path is to be
designed into the procedure. With BARO VNAV, no WAAS requirement.
Old December 25th 04, 04:21 AM
Gene Whitt
Y'All,
Tim and Mike are correct in that I was making an assumption as to the
accuracy of the GPS RNP-0.3 Minimum Aviation System Performance
Specifications (MASPS). As with practically all FAA
standards they only establish minimums. The .3 minimums need exist
only 95% of the time and they may not be linear but the diagrams
used to illustrate the RNPs use lises. (Figure 1-11 on page 1-13)
I am not a great believer in the validity of FAA minimums when my
flying life is at risk.
Gene Whitt
Old December 25th 04, 08:48 AM
Gene Whitt
Minimum standards are minimums, such as MDAs and DAs?
RNP takes a lot of the determination of system performance away from the
FAA and into the hands of the operator. With a well-trained crew in the
latest Falcons or Gulfstreams, for instance, it's accurate, has abundant
integrety, and far better than anything the FAA has ever offered, except
for the better instrument landing systems.
