must have 350hp above FL250?
Old December 1st 06, 07:46 PM posted to rec.aviation.piloting
buttman
Default must have 350hp above FL250?
According to the Aerostar's specification sheet, it says "Must have
350hp engines above FL250". Is this a regulation thing, or just a
limitation of the type? I tried searching through any kind of e-FAR I
could find, but came up with squat.
http://www.aerostaraircraft.com/specs.pdf
Come to think of it, there are a bunch of altitude restrictions based
on equipment, that are spread throughout the FARs, such as the Mode C
rule above 10,000; oxygen starting at 12.5; and DME above FL240.
I also remember a King Air pilot saying in order to fly above a certain
altitude (something like in the FL3XX range) you had to have a
specially certified altimeter (which costs an arm-and-a-leg)
Is there one place that has all of these altitude restrictions listed?
Old December 1st 06, 07:51 PM posted to rec.aviation.piloting
Mxsmanic
buttman writes:
Perhaps he was thinking of RVSM flight?
Old December 1st 06, 08:12 PM posted to rec.aviation.piloting
Jim Macklin
Part 23 and 25 is where you find aircraft certification.
Part 91 has requirements for flight in airspace, such as
reduced vertical separation [ what the King Air pilot was
talking about].
Revisions to Part 23 have included increased requirements
for stability above 25,000 feet.
Other requirements for pressurization and or oxygen systems
have included altitude limits.
The Type Certificate Data Sheet for each make, model and
serial number is where the limits, such as you cited will be
found.
"buttman" wrote in message
s.com...
"Must have
just a
of e-FAR I
restrictions based
the Mode C
FL240.
above a certain
have a
arm-and-a-leg)
Old December 1st 06, 11:58 PM posted to rec.aviation.piloting
john smith
In article m,
At FL250, those 350hp engines will not be putting out much of their
rated power.
Old December 2nd 06, 02:46 AM posted to rec.aviation.piloting
Jim Macklin
If they are turbo-charged using bug turbos, they may put out
nearly full power at 20,000 feet and normal high cruise
power at higher altitude. It all depends on the way the
system is put together.
"john smith" wrote in message
| In article
m,
"Must have
or just a
kind of e-FAR I
of their
| rated power.
Old December 2nd 06, 05:35 AM posted to rec.aviation.piloting
GDBholdings
"Jim Macklin" wrote in message
| In article
m,
| "buttman" wrote:
(snip)
Well does anyone know what the critical altitude of the superstar 700 is?.
