All,
When touching down in a crosswind, after the mains and the nosewheel have all touched down firmly and are rolling, would it be proper procedure to apply slight forward pressure to get better steering from the nosewheel? Often, noseweel steering seems ineffective, and this seems to have helped my control on rollout. Any cautions? I have heard about "wheelbarrowing" but is that more of a takeoff issue than landing issue? Under what circumstances would "wheelbarrowing" occur? --Dan |
Use the rudder not the wheel... it would be very bad practice to put
pressure on the nose-wheel. Your concern is slowing the plane down to get it to a speed where the nose wheel will be effective, for that you need back pressure and brakes, which is why the mains need to be firmly on the ground to give them the best grip. Dan wrote: All, When touching down in a crosswind, after the mains and the nosewheel have all touched down firmly and are rolling, would it be proper procedure to apply slight forward pressure to get better steering from the nosewheel? Often, noseweel steering seems ineffective, and this seems to have helped my control on rollout. Any cautions? I have heard about "wheelbarrowing" but is that more of a takeoff issue than landing issue? Under what circumstances would "wheelbarrowing" occur? --Dan |
I would not apply forward pressure to the stick. I would apply heavier than
normal braking to get more weight on the wheels, and apply back pressure at the same time so the decelleration does not throw more weight onto the nose tire/strut. Heavier than normal braking tends to flat spot tires if the weight is not fully on the mains. Wheel barrowing is a common occurance on landing when a pilot forces the airplane to land before it is ready. Common evidence of wheel barrowing in Cessna's is damage to the lower fire wall, sometimes to the point that day light is seen through the seperation. BT "Dan" wrote in message ups.com... All, When touching down in a crosswind, after the mains and the nosewheel have all touched down firmly and are rolling, would it be proper procedure to apply slight forward pressure to get better steering from the nosewheel? Often, noseweel steering seems ineffective, and this seems to have helped my control on rollout. Any cautions? I have heard about "wheelbarrowing" but is that more of a takeoff issue than landing issue? Under what circumstances would "wheelbarrowing" occur? --Dan |
So, this damage is a result of slamming the nosewheel down, or applying
forward pressure after the wheels are firmly on the ground? It would seem that forward pressure on the stick would not actually _push_ the nosewheel down, but simply allow the weight of the engine to settle onto the nosewheel sooner.. Does pushing actually apply more downward force on the nosewheel than when the plane is sitting on the ramp? I think that getting the flaps up immediately will help my technique also. (PA28s w/ manual flaps.) --Dan Wheel barrowing is a common occurance on landing when a pilot forces the airplane to land before it is ready. Common evidence of wheel barrowing in Cessna's is damage to the lower fire wall, sometimes to the point that day light is seen through the seperation. BT "Dan" wrote in message ups.com... All, When touching down in a crosswind, after the mains and the nosewheel have all touched down firmly and are rolling, would it be proper procedure to apply slight forward pressure to get better steering from the nosewheel? Often, noseweel steering seems ineffective, and this seems to have helped my control on rollout. Any cautions? I have heard about "wheelbarrowing" but is that more of a takeoff issue than landing issue? Under what circumstances would "wheelbarrowing" occur? --Dan |
ups.com... So, this damage is a result of slamming the nosewheel down, or applying forward pressure after the wheels are firmly on the ground? It would seem that forward pressure on the stick would not actually _push_ the nosewheel down, but simply allow the weight of the engine to settle onto the nosewheel sooner.. Does pushing actually apply more downward force on the nosewheel than when the plane is sitting on the ramp? No, it doesn't, but when travelling at speed down the runway, pushing the stick forward increases the angle of attack of the tail plane, (obviously), and in effect, transfers more weight to the front of the a/c by making the rear lighter. (I think I'm explaining this right!) Oz Lander |
My impression that the elevator applied varying levels of downward
force to balance the plane about the center of lift. I am not aware that the elevator could even produce _upward_ force on the tail. If it can't produce upward force, then the rear of the plane could be made no lighter than when it is standing still, therefore it could transfer no _additional_ weight to the nosewheel no matter what the control inputs. Where is this logic flawed (seriously, I want to understand if this is wrong...) --Dan Crash Lander wrote: "Dan" wrote in message ups.com... So, this damage is a result of slamming the nosewheel down, or applying forward pressure after the wheels are firmly on the ground? It would seem that forward pressure on the stick would not actually _push_ the nosewheel down, but simply allow the weight of the engine to settle onto the nosewheel sooner.. Does pushing actually apply more downward force on the nosewheel than when the plane is sitting on the ramp? No, it doesn't, but when travelling at speed down the runway, pushing the stick forward increases the angle of attack of the tail plane, (obviously), and in effect, transfers more weight to the front of the a/c by making the rear lighter. (I think I'm explaining this right!) Oz Lander |
ps.com... My impression that the elevator applied varying levels of downward force to balance the plane about the center of lift. I am not aware that the elevator could even produce _upward_ force on the tail. If the elevator couldn't generate an _upward_ force, then you couldn't pick up the tail on an taildragger, right? Let me assure you, you can pick up the tail on a taildragger. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On 3 Dec 2006 21:52:57 -0800, Dan wrote:
My impression that the elevator applied varying levels of downward force to balance the plane about the center of lift. I am not aware that the elevator could even produce _upward_ force on the tail. If it can't produce upward force, then the rear of the plane could be made no lighter than when it is standing still, therefore it could transfer no _additional_ weight to the nosewheel no matter what the control inputs. Where is this logic flawed (seriously, I want to understand if this is wrong...) Airplanes are normally trimmed (and loaded within limits) so the horizontal stabilizer provides a relatively small downward force. This gives positive pitch stability without a major increase in drag. If your model of how the elevator works was valid, it would be impossible for an aircraft to fly inverted since even full down elevator wouldn't be enough to counteract the nose-down pitch moment. You also have to consider that an aircraft on the ground would pitch around an axis passing through the main landing gear, not through the wing's center of lift. ljd |
BT wrote:
I would not apply forward pressure to the stick. I would apply heavier than normal braking to get more weight on the wheels, and apply back pressure at the same time so the decelleration does not throw more weight onto the nose tire/strut. Heavier than normal braking tends to flat spot tires if the weight is not fully on the mains. Wheel barrowing is a common occurance on landing when a pilot forces the airplane to land before it is ready. Common evidence of wheel barrowing in Cessna's is damage to the lower fire wall, sometimes to the point that day light is seen through the seperation. I don't think wheelbarrowing will damage the firewheel. It takes a landing on the nosewheel to do that. This isn't quite the same as wheelbarrowing. Matt |
Wheel barrowing will cause loss of directional control and
the accident will damage the airplane. Many Cessna airplane are used for student instruction, as are Piper and Beech, all are often landed on the nose wheel by student pilots (and other too) and damage is not uncommon. Transport category airplanes are often designed with a negative angle of attack when the nose wheel is on the ground and they also have ground spoilers. Some GA light twins, such as the Duke, have a negative lift with the nose on the ground, but most light aircraft have enough tail area to lift a major portion of the weight from the main wheels with full down elevator. Land, hold the nose off and then reduce back pressure and lower the nose wheel into contact with the ground. Some airplanes, such as the Piper singles may need to have the nose wheel steering straightened before the wheel is allowed to touch down. Some airplanes disconnect nose wheel steering until the wheel has weight applied. Once the nose wheel is firmly on the ground, apply brakes and smoothly apply aft pressure again until the control is fully aft. Be sure to use the ailerons, elevator and brakes to control the airplane. Some differential power on a twin can be used, but on a slick runway, be careful. If you have reverse thrust, be extra careful about directional control. "Matt Whiting" wrote in message ... | BT wrote: | | I would not apply forward pressure to the stick. I would apply heavier than | normal braking to get more weight on the wheels, and apply back pressure at | the same time so the decelleration does not throw more weight onto the nose | tire/strut. Heavier than normal braking tends to flat spot tires if the | weight is not fully on the mains. | | Wheel barrowing is a common occurance on landing when a pilot forces the | airplane to land before it is ready. | Common evidence of wheel barrowing in Cessna's is damage to the lower fire | wall, sometimes to the point that day light is seen through the seperation. | | I don't think wheelbarrowing will damage the firewheel. It takes a | landing on the nosewheel to do that. This isn't quite the same as | wheelbarrowing. | | | Matt |
Best place for CG along roll axis | Mxsmanic | Piloting | 42 | September 28th 06 04:40 AM |
Crosswind landing | Ron Webb | Home Built | 23 | June 10th 06 03:43 AM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
Tailwheel Crosswind Landing | Piloting | 32 | December 6th 04 02:42 AM | |
Strong crosswind landings! | Toks Desalu | Piloting | 12 | April 19th 04 07:43 PM |
