Does the elevator/stabilator generate upward force?
Old December 5th 06, 05:33 AM posted to rec.aviation.piloting
Dan[_1_]
Default Does the elevator/stabilator generate upward force?
Ok, this is a followup to the previous discussion about forward control
pressure during the landing rollout. Can someone tell me if the
elevator/stabilator can actually generate an _upward_ force, or does it
simply generate a downward force for climbing and less downward force
for a decent?
Does the nose fall due to the CG being forward of the center of lift,
or does the elevator actually push the tail up?
We are talking about tricycle gear planes, not taildraggers... The PA28
series specifically.
--Dan
Old December 5th 06, 05:49 AM posted to rec.aviation.piloting
BT
You tell me...
Next time you are doing your run up.. hold the brakes and move the control
foward and aft.. is the nose rising and falling because of action of wind
(prop wash) over the elevator position? Granted in a heavy PA28, it may not
be very noticable, but try it in a Cessna 152/172.
you are mixing apples in oranges when talking about "the nose falling due to
CG and center of lift".
IIRC the original thread was concerned with pushing the nose down to put
more weight on the nose wheel for cross wind control,
in the example you mention, it involves the nose falling forward because the
elevator/wings combination cannot generate enough "lift" in their respective
direction to keep the nose up.
Now.. lets expand on that a bit.. when performing an outside loop maneuver,
is the nose being pushed around the loop because the elevator is creating
less "lift" or because the elevator is forcing the nose around.
Why would a tricycle gear airplane behave any differently than a tail wheel
as far as elevator effectiveness. Other than possible physical limits
allowed to elevator travel.
In the only Piper POH I have avalible to be right now, On landing... ""After
ground contract hold the nose wheel off as long as possible. Braking is most
effective when back pressure is applied to the control wheel. In high wind
conditions, particularly in strong crosswinds, it may be desirable to
approach the ground at highter than normal speeds with partial or no flaps."
Funny, it says nothing about pushing forward on the stick for directional
control.
B
"Dan" wrote in message
for a decent?
--Dan
Old December 5th 06, 06:02 AM posted to rec.aviation.piloting
Jim Macklin
"you are mixing apples in oranges when talking about "the
nose falling due to
nose down to put
| more weight on the nose wheel for cross wind control,"
Increased weight on the nose wheel makes the nose wheel the
pivot point and is guaranteed to cause loss of direct
WHEELBARROWING
Page 8-32
http://www.faa.gov/library/manuals/a...lane_handbook/
chap 7-9
When a pilot permits the airplane weight to become
concentrated about the nosewheel during the takeoff or
landing roll, a condition known as wheelbarrowing will
occur. Wheelbarrowing may cause loss of directional
control during the landing roll because braking action is
ineffective, and the airplane tends to swerve or pivot on
the nosewheel, particularly in crosswind conditions.
One of the most common causes of wheelbarrowing
during the landing roll is a simultaneous touchdown
of the main and nosewheel, with excessive speed,
followed by application of forward pressure on the
elevator control. Usually, the situation can be corrected
by smoothly applying back-elevator pressure.
However, if wheelbarrowing is encountered and
runway and other conditions permit, it may be advisable
to promptly initiate a go-around. Wheelbarrowing will
not occur if the pilot achieves and maintains the correct
landing attitude, touches down at the proper speed, and
gently lowers the nosewheel while losing speed on
rollout. If the pilot decides to stay on the ground rather
than attempt a go-around or if directional control is
lost, the throttle should be closed and the pitch attitude
smoothly but firmly rotated to the proper landing
attitude. Raise the flaps to reduce lift and to increase
the load on the main wheels for better braking action.
"BT" wrote in message
| You tell me...
move the control
action of wind
PA28, it may not
nose falling due to
nose down to put
forward because the
in their respective
around.
than a tail wheel
physical limits
landing... ""After
wheel. In high wind
desirable to
for directional
| control.
| B
forward control
me if the
force, or does it
downward force
| for a decent?
center of lift,
| --Dan
Jim Macklin
The tail can produce forces in either direction, although in
flight forces are mostly in the down direction at the tail.
The wing lift is concentrated aft of the CG so that there is
a nose down moment when the airplane becomes stalled. This
is for static stability. The initial movement for
statically stable airplanes must be toward a unstalled angle
of attack and flying speed. This happens with the tail
moment leveraging the turning moments to a balanced dynamic
position, which will decrease at lower speeds, causing the
static pitching moment downward.
But it can produce an upward force if the airplane is aft of
the CG range, in order to balance the airplane in flight.
But if you stall, the nose will pitch up into a deeper
stalled condition.
On landing the airplane will rotate [pitch] around the main
wheel axles and even the nose wheel which is wheel
barrowing.
The magnitude all depends on the center of gravity in
relation to the CG range and the amount of travel exerted.
Normal flight is very small movements and acrobatics, and
control forces below stall speed on the ground use control
displacements for gross changes.
The issue is not tail draggers, but tail or canard, the
location of the wheels in relation to the CG [wing chord]
only has to do with finer details, like rolling.
forward control
if the
force, or does it
downward force
| for a decent?
center of lift,
| --Dan
Old December 5th 06, 05:50 AM posted to rec.aviation.piloting
Jim Macklin
Think loop: outside or inside.
forward control
if the
force, or does it
downward force
| for a decent?
center of lift,
| --Dan
Old December 5th 06, 06:04 AM posted to rec.aviation.piloting
Peter Duniho
Where the landing gear is mounted has nothing to do with the forces that the
elevator creates. Several designs are basically identical, except for the
position of the landing gear (Pacer and Tri-Pacer, for example).
And yes, the elevator can create an upward force.
Old December 5th 06, 06:41 AM posted to rec.aviation.piloting
I'm kind of alarmed to hear that an instructor didn't explain to you
that the elevator generates lift.
Old December 5th 06, 07:28 AM posted to rec.aviation.piloting
Peter Duniho
ps.com...
To whom are you replying? If me, I have no idea what you're talking about.
Your reply has nothing to do with what I wrote.
If you're not replying to me, then I suggest you learn how to reply to the
message to which you intend to reply, or at a minimum learn how to *quote*
the text to which you're replying, so that people can tell what the heck
Pete
Old December 5th 06, 08:46 AM posted to rec.aviation.piloting
Peter Duniho wrote:
ps.com...
Pete
Not you... Dan.
Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue Mike Naval Aviation 26 July 11th 06 11:38 PM
Air Force FB-22 Bomber Concept - CRS Mike Naval Aviation 2 June 18th 06 09:32 PM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
