So far, every time I come out of ROG and request flight following to it
doesn't matter where, I get a discrete squawk that allows departure to hand me off to Memphis Center, or Dallas, or Kansas City. Coming out of LIT however I've never been given anything except a local code and then about 15 miles out the familiar "radar advisories terminated, squawk VFR, have a nice day". I specifically tested this twice on Friday, making sure that when I called up clearance delivery and then ground that I made it very plain that I was requesting flight following. Both times, again they dumped me from the system between 15 and 20 miles out. The second time, I forced the issue and stated that I was requesting flight following for the enroute segment if able. I was then given a Memphis enroute code and handed off within about 10 miles. My question for the group is: is there a special terminology that should be used when requesting full-enroute flight following? Or, why do some controllers provide that service automatically and others seemingly only under duress? (I don't think it is a controller issue, however it might be a facility policy issue). |
"Jim Carter" wrote in
news:000801c71c01$25c5bf10$4b01a8c0@omnibook6100: So far, every time I come out of ROG and request flight following to it doesn't matter where, I get a discrete squawk that allows departure to hand me off to Memphis Center, or Dallas, or Kansas City. Coming out of LIT however I've never been given anything except a local code and then about 15 miles out the familiar "radar advisories terminated, squawk VFR, have a nice day". VFR flight following is on a workload permitted basis. If approach doesn't give you a hand off, just call center servicing the area and pick up flight following through them. If you know you have been given a local code, you may want to contact LIT approach and ask if VFR flight following is available outside their airspace. They can answer accordingly or advise you what frequency to contact for continuation of VFR flight following. Allen |
![]() -----Original Message----- From: A Lieberma ] Posted At: Saturday, December 09, 2006 8:48 PM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question "Jim Carter" wrote in news:000801c71c01$25c5bf10$4b01a8c0@omnibook6100: So far, every time I come out of ROG and request flight following to it doesn't matter where, I get a discrete squawk that allows departure to hand me off to Memphis Center, or Dallas, or Kansas City. Coming out of LIT however I've never been given anything except a local code and then about 15 miles out the familiar "radar advisories terminated, squawk VFR, have a nice day". VFR flight following is on a workload permitted basis. Yep, I'm aware of that which is why I expected maybe that was the issue. Last Friday however, when I decided to "test" that theory I got handed off to Memphis and the sector controller seemed very chatty - with almost nothing else going on. Little Rock (Adams Field) has instituted a non-IFR pre-taxi clearance delivery frequency. First you pick up ATIS, then call non-IFR clearance, then finally you get to talk to ground control for a VFR departure. It's almost like they are trying to justify some positions rather than improve safety or efficiency on the ground. I would think that encouraging flight following would help their numbers, but since they tend to work as an isolated little unit with VFR traffic very few of the guys I fly with use them for that purpose. That can't help their numbers. |
"Jim Carter" wrote in news:000401c71c0e$aadf0190
$4b01a8c0@omnibook6100: Little Rock (Adams Field) has instituted a non-IFR pre-taxi clearance delivery frequency. First you pick up ATIS, then call non-IFR clearance, then finally you get to talk to ground control for a VFR departure. It's almost like they are trying to justify some positions rather than improve safety or efficiency on the ground. Is there a NOTAM on that somewhere for a non IFR pretaxi clearance frequency? Just checked DUATS, and they only have the following frequencies: UNICOM 122.950 JONESBORO FSS (JBR) 1-800-WX-BRIEF NOTAM FILE LIT APCH/P DEP/P CLASS C 119.5(222-041) APCH/P DEP/P CLASS C IC 135.4(042-221) ATIS 125.65(501-324-2618) CD/P PTC 118.95 EMERG 121.5 GND/P 121.9 IC 135.4 LCL/P 118.7 What you describe above *almost* sounds normal for me as I would do the following for departing Little Rock based on my DUATS briefing: Get ATIS 125.65 Contact Clearance and Delivery for my VFR intentions (or IFR) 118.95 Contact ground for taxiing 121.9 Contact Tower 118.7 for departure Contact departure frequency 119.5 or 135.4 Allen |
![]() -----Original Message----- From: A Lieberma ] Posted At: Saturday, December 09, 2006 10:16 PM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question .... Is there a NOTAM on that somewhere for a non IFR pretaxi clearance frequency? Just checked DUATS, and they only have the following frequencies: Nope, it's on the ATIS announcement. UNICOM 122.950 JONESBORO FSS (JBR) 1-800-WX-BRIEF NOTAM FILE LIT APCH/P DEP/P CLASS C 119.5(222-041) APCH/P DEP/P CLASS C IC 135.4(042-221) ATIS 125.65(501-324-2618) CD/P PTC 118.95 EMERG 121.5 GND/P 121.9 IC 135.4 LCL/P 118.7 What you describe above *almost* sounds normal for me as I would do the following for departing Little Rock based on my DUATS briefing: Get ATIS 125.65 Contact Clearance and Delivery for my VFR intentions (or IFR) 118.95 Contact ground for taxiing 121.9 Contact Tower 118.7 for departure Contact departure frequency 119.5 or 135.4 Allen I'm typically used to calling CD only for special VFR or IFR clearances. I found it unusual for a VFR CD requirement, especially when the same voice seems to answer both CD and GND. |
![]() Jim Carter wrote: I'm typically used to calling CD only for special VFR or IFR clearances. I found it unusual for a VFR CD requirement, especially when the same voice seems to answer both CD and GND. If it's the same guy it doesn't matter what frequncy you use. |
"Jim Carter" wrote:
My question for the group is: is there a special terminology that should be used when requesting full-enroute flight following? This exact situation happens routinely here in the Phoenix area. If I request flight following, even when I state a destination outside Phoenix tracon's airspace, they will normally just give me a local squawk code and terminate services when outside their airspace. I've found that the magic words that seem to work are, "... request flight following with a center hand-off", sometimes with an "if able" or "time permitting" thrown in for good measure. The controller will then get a center squawk code from Albuquerque center, and hand me off. My impression is that it's just a workload thing. Flight following is on a workload permitting basis, and they can minimize their effort by just getting a local squawk with no coordination, and no hand-off. It is mildly annoying, I must agree. If I tell them my VFR destination which is clearly in center's airspace, it would seem that they could make the effort to coordinate it. Mike |
![]() -----Original Message----- From: Mike Adams ] Posted At: Saturday, December 09, 2006 9:24 PM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question "Jim Carter" wrote: My question for the group is: is there a special terminology that should be used when requesting full-enroute flight following? .... are, "... request flight following with a center hand-off", I'll try that next time I'm down there. Good idea. |
Flight Following questionJim, as others have indicated, it can be variable.
I have had most luck with "Request flight following to destination" or "Request to be put into the system for flight following to destination". Or you can just file an ATC flight plan for VFR flight following. That automatically puts you into the system. Stan "Jim Carter" wrote in message news:000801c71c01$25c5bf10$4b01a8c0@omnibook6100.. . So far, every time I come out of ROG and request flight following to it doesn't matter where, I get a discrete squawk that allows departure to hand me off to Memphis Center, or Dallas, or Kansas City. Coming out of LIT however I've never been given anything except a local code and then about 15 miles out the familiar "radar advisories terminated, squawk VFR, have a nice day". I specifically tested this twice on Friday, making sure that when I called up clearance delivery and then ground that I made it very plain that I was requesting flight following. Both times, again they dumped me from the system between 15 and 20 miles out. The second time, I forced the issue and stated that I was requesting flight following for the enroute segment if able. I was then given a Memphis enroute code and handed off within about 10 miles. My question for the group is: is there a special terminology that should be used when requesting full-enroute flight following? Or, why do some controllers provide that service automatically and others seemingly only under duress? (I don't think it is a controller issue, however it might be a facility policy issue). |
"Stan Prevost" wrote in
: Or you can just file an ATC flight plan for VFR flight following. That automatically puts you into the system. Filing VFR flight plan DOES NOT put you in the system. It's only for search and rescue, nothing more. You don't activate the flight plan with ATC, but with FSS on a VFR flight plan. Allen |
IFR use of handheld GPS | [email protected] | Instrument Flight Rules | 251 | May 19th 06 02:04 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
