I wonder if someone could help me identify and aircraft I saw several
times on a reason visit to Reno? The plane is has twin pusher props, the tail is delta shaped and the aircraft canard . . . it looked a little like one that Beechcraft made . . . I can't remember the name but the wing and tail wing configuration was completely different. There were two of these planes flying out of RNO. Thank you, Tim |
Did it look like this?
http://tinyurl.com/yzh389 Karl N185KG "timothy" wrote in message ups.com... I wonder if someone could help me identify and aircraft I saw several times on a reason visit to Reno? The plane is has twin pusher props, the tail is delta shaped and the aircraft canard . . . it looked a little like one that Beechcraft made . . . I can't remember the name but the wing and tail wing configuration was completely different. There were two of these planes flying out of RNO. Thank you, Tim |
![]() karl gruber wrote: Did it look like this? http://tinyurl.com/yzh389 Karl N185KG "timothy" wrote in message ups.com... I wonder if someone could help me identify and aircraft I saw several times on a reason visit to Reno? The plane is has twin pusher props, the tail is delta shaped and the aircraft canard . . . it looked a little like one that Beechcraft made . . . I can't remember the name but the wing and tail wing configuration was completely different. There were two of these planes flying out of RNO. Thank you, Tim That's it! Thanks for the help. TM |
It needs to be painted a dark grey on top with blue
highlights, medium blue on the sides with a white bottom. That way it can look like a beached whale. Or a catfish. "timothy" wrote in message ups.com... | | karl gruber wrote: | Did it look like this? | http://tinyurl.com/yzh389 | | Karl | N185KG | | "timothy" wrote in message | ups.com... | I wonder if someone could help me identify and aircraft I saw several | times on a reason visit to Reno? The plane is has twin pusher props, | the tail is delta shaped and the aircraft canard . . . it looked a | little like one that Beechcraft made . . . I can't remember the name | but the wing and tail wing configuration was completely different. | There were two of these planes flying out of RNO. Thank you, Tim | | | That's it! Thanks for the help. TM | |
I think that somebody already answered you, but just in case:
It's a Piaggio Avanti P.180. (http://www.piaggioaero.com/) Reno is one of our mx bases. 12,100 lb T/O weight 395 knots at 28,000 feet. It's the worlds fastest business turboprop. Hope this helps. On Dec 14, 12:49 pm, "timothy" wrote: I wonder if someone could help me identify and aircraft I saw several times on a reason visit to Reno? The plane is has twin pusher props, the tail is delta shaped and the aircraft canard . . . it looked a little like one that Beechcraft made . . . I can't remember the name but the wing and tail wing configuration was completely different. There were two of these planes flying out of RNO. Thank you, Tim |
![]() wrote in message ps.com... I think that somebody already answered you, but just in case: It's a Piaggio Avanti P.180. (http://www.piaggioaero.com/) Reno is one of our mx bases. 12,100 lb T/O weight 395 knots at 28,000 feet. It's the worlds fastest business turboprop. Hope this helps. How are the wings de-iced? I've looked at one up close and can't see anything obvious. Karl N185KG |
![]() "karl gruber" wrote in message ... wrote in message ps.com... I think that somebody already answered you, but just in case: It's a Piaggio Avanti P.180. (http://www.piaggioaero.com/) Reno is one of our mx bases. 12,100 lb T/O weight 395 knots at 28,000 feet. It's the worlds fastest business turboprop. Hope this helps. How are the wings de-iced? I've looked at one up close and can't see anything obvious. Karl N185KG From their Website Main wing leading edge anti-ice is accomplished by directing engine bleed air through a diffuser duct installed in the main wing leading edge. The forward wing contains an electrically activated de-icing blanket on the aluminum alloy leading edge. Nacelle inlets are de-iced by pneumatic boots. To avoid ice ingestion, an inertial separator is installed inside each nacelle. Moreover, the cycling of the nacelle boots is automatically controlled by the Ice Detector System in its primary mode of operation. A timer is provided to cycle the boots for secondary operations. Electric heating of the windshield on both pilot and co-pilot sides is used to guard against or alleviate icing and fogging. No ice protection is provided or required on the horizontal and the vertical tail. |
That's a sweet post; I probably should have read a little farther
before I ended up repeating everything that you said. |
The front wing (NOT a canard) is electric heat, the engine intakes are
pneumatic boots, and the main wing is heated from engine bleed air. The props are "always heated" from the exhaust, and the empennage is cold. On Dec 14, 4:52 pm, "karl gruber" wrote: wrote in glegroups.com... I think that somebody already answered you, but just in case: It's a Piaggio Avanti P.180. (http://www.piaggioaero.com/) Reno is one of our mx bases. 12,100 lb T/O weight 395 knots at 28,000 feet. It's the worlds fastest business turboprop. Hope this helps.How are the wings de-iced? I've looked at one up close and can't see anything obvious. Karl N185KG |
Contact Approach -- WX reporting | [email protected] | Instrument Flight Rules | 64 | December 22nd 06 01:43 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
