I know this has been discussed here before but I'm still not able to
connect my Garmin III Pilot to the Jeppesen FliteStar program I have on my laptop. The problem of course is the serial-USB adapter which I have to use since modern laptops do not have old style serial connections anymore. If someone has been successful, what exactly was the configuration (COM, baud rate, format [Garmin or NMEA for example] etc.) and which was the *exact* serial-USB adapter being used? Thanks, Gerd |
gwengler wrote:
I know this has been discussed here before but I'm still not able to connect my Garmin III Pilot to the Jeppesen FliteStar program I have on my laptop. The problem of course is the serial-USB adapter which I have to use since modern laptops do not have old style serial connections anymore. If someone has been successful, what exactly was the configuration (COM, baud rate, format [Garmin or NMEA for example] etc.) and which was the *exact* serial-USB adapter being used? Don't know about FliteStar, but I emailed Garmin tech support and they told me what I needed to do to connect using my USB/serial adapter. It seemed to be a FAQ for them. |
My modern Toshiba still has a serial port. I have several Garmin GPSes
and they all drive FliteDeck just fine. I think with USB it is especially important that the GPS be connected and running before you open FliteDeck. Once the GPS is connected make sure it appears as a USB device in Device Manager. Without that, there isn't a chance it will work. gwengler wrote: I know this has been discussed here before but I'm still not able to connect my Garmin III Pilot to the Jeppesen FliteStar program I have on my laptop. The problem of course is the serial-USB adapter which I have to use since modern laptops do not have old style serial connections anymore. If someone has been successful, what exactly was the configuration (COM, baud rate, format [Garmin or NMEA for example] etc.) and which was the *exact* serial-USB adapter being used? Thanks, Gerd |
Garmin Specials ADV | Michael Coates | Home Built | 0 | March 18th 04 12:24 AM |
who moved SAV, forgot to tell Jepp? | Dave Butler | Instrument Flight Rules | 15 | November 9th 03 02:16 AM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
"Stand Alone" Boxes (Garmin 430) - Sole means of navigation - legal? | Richard | Instrument Flight Rules | 20 | September 30th 03 02:13 PM |
Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 09:04 PM |
