Status of CVW-17
Old December 18th 06, 01:55 PM posted to rec.aviation.military.naval
Ralph_S
Default Status of CVW-17
I bought a copy of Air Forces Monthly last weekend, that includes an
overview of the current USN carrier wing compositions. To my amazement
I saw that CVW-17 currently doesn't seem to have _any_ Hornet squadrons
assigned to it. Until recently it had four:
VFA-103 Jolly Rogers is part of CVW-7, as is VFA-83 Rampagers. The two
other squadrons have been assigned to West Coast Air wings, although
they are still home-based at Oceana:
VFA-34 Blue Blasters is part of CVW-2 and VFA-81 Sunliners is assigned
to CVW-11.
So, what's going on? Will other Hornet squadrons be assigned to CVW-17
by the time that it deploys again?
Cheers,
Ralph
Old December 18th 06, 08:12 PM posted to rec.aviation.military.naval
Mike Weeks
to CVW-11.
That's the $64 question. CVW-17, having been assigned to JFK is
currently *assigned* to a deck (GW) which is in the yards for about a
year, and then she's to move to Japan. So the shortfall in Hornet
squadrons in other CVWs are being made up, no so much as from USMC
VMFAs, but by VFAs from CVW-17.
The real question is; what's to happen to CVW-17? Because there's not
another deck available given the decision to axe JFK without a 1-for-1
replacement.
Fun times ahead, as indicated in another posting about the new
challenges facing NavAir.
MW
Old December 18th 06, 10:28 PM posted to rec.aviation.military.naval
Ralph_S
to CVW-11.
replacement.
MW
Thanks Mike,
I read that post, and considered adding my question regarding CVW-17 to
that thread since I thought the underlying problem was probably the
same: a shortage of aircraft. However, if I understand you correctly
this seemingly is also coupled to a decrease in the number of
carriers. With carriers undergoing refuelling and major refits (Carl
Vinson) or shorter yard periods (GW), there seem to be more wings than
available carriers, unless CVW-17 is axed.
Cheers,
Ralph
Old December 18th 06, 11:03 PM posted to rec.aviation.military.naval
Mike Weeks
to CVW-11.
replacement.
MW
Thanks Mike,
That appears to be the bottom line.
The situation with aircraft "life" is one situation, and the withdraw
of JFK (i.e., one deck) is another; related to a degree with the other.
With the on-going situation of a CVN in the yard for a 3-year refueling
& major refit, the situation of mis-matched CVWs-to-deck will switch
between those based on the east and west coast -- if there isn't a CVW
axed.
As has been the case for the pass 15 or so years, it's like jello when
attempting to see how it all will play out ... g
Old December 21st 06, 03:01 PM posted to rec.aviation.military.naval
Nice to join a discussion like this again;-)
As far as I can catch the idea, CVW-17 is not going to be deactivated,
but stays there to serve as a warehouse of "spare" squadrons, to be
assigned to other wings if needed. I even heard the rumours that
someday (in 2009?) it deplys again, with a set of FOUR Super Hornet
squadrons assigned.
I'd be also curious of the current status of other units, like CVW-2 or
CVW-8. CVW-2 should be in a maintenance phase (Lincoln is in the
yards), so I wonder if VFA-34 are still with them. CVW-8 makes some FRP
training, but it must be missing a squadron (VFA-31 is not yet
operationally capable, starting their transition to F/A-18Es).
Remember - now it is the "Pool" philosophy, what means squadrons are no
longer permanently assigned to particular air wings, so every move may
generate the others.
Best regards,
Jacek Zemlo
(superhornet at go2 dot pl)
Old December 24th 06, 10:59 PM posted to rec.aviation.military.naval
Lazyike
to CVW-11.
replacement.
MW
With the Chinese sub that got way too close I think ASW needs to be
better rethought.
IMHO al CVs would become ASW platforms. I have Harpoon classic & often
create scenarios where an old CV performs this role. the US forces win
EVERY time. I even launched Los Angeles Class subs at my CTF & they
are busted. I tend to run Short Med & Long range so the Osprey takes
LR missions, EH101 for MR/LR Missions & Seahawks for SR/MR missions.
Fixed wing consist of 2-4 Harriers, & 4-6 Vikings for XLR/LR missions.
I may vary this on several carriers.
Ike
Panel to review Speicher's status [email protected] Naval Aviation 0 April 6th 05 03:31 AM
c133 cargomaster returned to flight status...true? w.a. manning Military Aviation 4 August 20th 04 09:43 PM
