Also instrument needles go crazy.
Aircraft is a Lancair with antenna hidden in the horizontal stab. How 'bout directing us to some reading material about how to stop it. Our local avionics guy says we may have to live with it, or install external antennas, which will dirty up a Lancair in a hurry. Jim Weir? Thanks and happy holidays. |
![]() jls wrote: Also instrument needles go crazy. Aircraft is a Lancair with antenna hidden in the horizontal stab. How 'bout directing us to some reading material about how to stop it. Our local avionics guy says we may have to live with it, or install external antennas, which will dirty up a Lancair in a hurry. Jim Weir? Thanks and happy holidays. Check your com antenna connections. Sounds like a bad cable shield ground allowing RF to escape and disturb sensitive circuitry. Dan |
Google "ferrite balun". You could have saved us some time telling us a
little bit about what sort of antenna was hidden in the horizontal stabilizer. Second question is why you put it in the HORIZONTAL stabilizer when com antennas were meant to live their lives VERTICAL. Jim "jls" wrote in message ps.com... Also instrument needles go crazy. Aircraft is a Lancair with antenna hidden in the horizontal stab. How 'bout directing us to some reading material about how to stop it. Our local avionics guy says we may have to live with it, or install external antennas, which will dirty up a Lancair in a hurry. Jim Weir? Thanks and happy holidays. |
'bout directing us to some reading material about how to stop it. A friend of ours had this exact problem in his SX-300. I helped him troubleshoot it ("OK, key the mike!" for hours on end...) while he stood on his head fiddling with antenna wires. He found that the culprit was the antenna wiring going up into the tail. Since replacing that wiring would have required opening up the vertical stab, he found that he could stop it from happening by shielding it with strategically placed pieces of aluminum foil. He also minimized it by re-routing the cable, and replacing some of the connectors that were "leaking". By doing this he was able to eliminate the porpoising on one of the two frequencies it was happening on, and he minimized it dramatically on the other. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"jls" wrote:
Also instrument needles go crazy. Aircraft is a Lancair with antenna hidden in the horizontal stab. How 'bout directing us to some reading material about how to stop it. Our local avionics guy says we may have to live with it, or install external antennas, which will dirty up a Lancair in a hurry. Jim Weir? The easiest thing to try would be to clamp ferrite cores around the input leads to the AP computer (even better if there's enough slack to loop the cables through a larger core a couple times). Next might be to use antenna cable that's more shielded (assuming that the cable runs quite a bit closer to the autopilot cabling than the antenna). Might be easier (and certainly cheaper) to just re-route the antenna cable away from all other cables as much as possible. And I'm sure Jim's gonna want to know a bit more about that horizontal dipole (?) antenna you're running. Mark "RF stands for Random Fluctuations" Hickey |
![]() jls wrote: Also instrument needles go crazy. Aircraft is a Lancair with antenna hidden in the horizontal stab. How 'bout directing us to some reading material about how to stop it. Our local avionics guy says we may have to live with it, or install external antennas, which will dirty up a Lancair in a hurry. Jim Weir? Thanks and happy holidays. I'll take a completely different tack. Since your instrument needles move when you key the mike, I suspect a ground loop. I would be interested in knowing if you engine needles move when you turn on and off other consumers like the strobes or nav lights. I just finished working on a Lancair that had a similar problem. You could turn the nav lights on and off and the CHT's would go up and down. Keying the mic caused the trim indicators to change. We ended up pulling out most of the wiring and redoing it for the plane's new owner. Not cheap, but everything works now. Rick Pellicciotti Belle Aire Aviation |
![]() rpellicciotti wrote: jls wrote: Also instrument needles go crazy. Aircraft is a Lancair with antenna hidden in the horizontal stab. How 'bout directing us to some reading material about how to stop it. Our local avionics guy says we may have to live with it, or install external antennas, which will dirty up a Lancair in a hurry. Jim Weir? Thanks and happy holidays. I'll take a completely different tack. Since your instrument needles move when you key the mike, I suspect a ground loop. I would be interested in knowing if you engine needles move when you turn on and off other consumers like the strobes or nav lights. I just finished working on a Lancair that had a similar problem. You could turn the nav lights on and off and the CHT's would go up and down. Keying the mic caused the trim indicators to change. We ended up pulling out most of the wiring and redoing it for the plane's new owner. Not cheap, but everything works now. Rick Pellicciotti Belle Aire Aviation Thanks so much and thanks to all the others who responded with help. I'm going to advise hangarmate to rewire his airplane.* The com antenna is in the vertical stab, at least one of them. The airplane was built by one of those shops that the owner sends the kit to. We're trying to get in touch with the builder to find out where the other com antenna, if any, is. *Just kidding. We'll try all the other avenues first, but fact is the more troublesome of the two radios does do a number on the egt and cht readouts, as well as the autopilot and some of the other instruments. Top o' the season to you. It's summer here in WNC at 70 deg. F. and warm sunshine. |
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga | Jay Honeck | Home Built | 1 | December 3rd 04 09:16 PM |
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga | Jay Honeck | Owning | 0 | December 3rd 04 08:25 PM |
PA28-181 - Stuck Mike - King Silver Crown | Roy Page | Owning | 2 | October 29th 04 03:36 AM |
Bendix King KMA20 - Stuck mike open. | Roy Page | Owning | 2 | October 12th 04 03:40 PM |
We always used the throat mike. | ArtKramr | Military Aviation | 9 | March 30th 04 04:07 PM |
