GPT (Gulfport MS) ILS 14 question
Old January 26th 05, 03:58 AM
A Lieberman
Default GPT (Gulfport MS) ILS 14 question
About to take a trip down to Gulfport MS (GPT) tomorrow morning.
Ceilings are forecasted to be 300 broken, so I really doubt that I will be
mucking around with full procedure approaches in the clag, but while I was
studying the approaches into GPT, I am kinda figuring on expecting vectors
for the ILS 14 approach based on forecasted winds.
Looking at the approach, the IAF is CAESA. Outside the 10 NM ring, it says
2000 no PT, so, I would take it that no procedure turn is authorized, yet,
I see the procedure turn barbs just inside the 10 NM ring. Am I reading
this correctly that no procedure turns for the ILS is authorized outside
this 10NM ring, and if I was to do a full procedure approach that it must
be inside the the 10 NM ring??? Or what am I missing?
This question is coming up, as when I got my flight briefing, the briefer
said, no procedure turn at CAESA from Victor 552 which in my opinion agrees
with the approach chart, yet I see the procedure turn barbs outbound 268
and inbound 088 to intercept the localizer.
Any assistance in clearing up my question really appreciated.
Allen
Old January 26th 05, 04:10 AM
John Clonts
"A Lieberman" wrote in message ...
I'm looking at the naco chart at http://204.108.4.16/d-tpp/0501/00576IL14.PDF
The procedure turn is applicable only if you start the approach at the BAYOU IAF. The "2000 noPT" designation
applies only if you start the approach at the CAESA IAF. The barb being inside or outside the 10nm ring is not
significant itself (though it shows outside the 10nm ring on the naco chart), but the profile view clearly
indicates that you must remain within 15nm on the procedure turn.
I expect that most FSS briefers know very little about approaches
Have a great flight!
Cheers,
John Clonts
Temple, Texas
N7NZ
Old January 26th 05, 04:33 AM
A Lieberman
Hey John,
Thanks for your quick reply. What you say makes perfect sense!!! (I am
using the NACO chart as well) However....
I should have said that the FSS gave me the following FDC.
FDC 5/0505 GPT FI/T GULFPORT-BILOXI INTL, GULFPORT, MS.
ILS OR LOC RWY 14, AMDT 14...
CHANGE PLANVIEW NOTE: PROCEDURE NA FOR ARRIVALS
AT CAESA VIA V552 WESTBOUND VICE V522 WESTBOUND.
IF and only IF I was wanting to do a full procedure approach coming from
any other direction then westbound, would a procedure turn be authorized
based on the above FDC? If not, what is this FDC about?
Tops are forecasted to be 5000, filed 5000 for starters as I am expecting
higher tailwinds at a lower altitude. Should be real good, but short
(almost too short!) *smile*.
Allen
Old January 26th 05, 04:36 AM
A Lieberman
DUH, Stan Prevost, cleared this question up! I think I was combining
procedure and procedure turn together, rather then two different "terms".
Thanks to all for clearing this up!
Allen
Old January 26th 05, 10:07 PM
CKonikoff
Sorry for not seeing the original posting, but this is all I had. Your display
of the NOTAM says to change V522 to V552. Since the enroute chart shows no
V522, only V552, is it possible that they simply made a typo on the original
and were trying to change the approach chart to say not to make the PT on V552
instead of V522. Just a thought.
Charles
Old January 28th 05, 01:15 AM
CKonikoff
Sorry, but I missed the original posting. I believe that at GPT there is no
V522, only V552. Maybe they charted something wrong and the NOTAM was to
change the error, V522, to the correct airway, V552.
Old January 29th 05, 03:18 PM
They made a mistake on the airway number. What the NOTAM clarifies is that you
cannot do the procedure at all arriving on V552 from the east, because it
exceeds the 120-degree course change limitation of TERPs Paragraph 220. CAESA is
on V552, so it is not possible to do the procedure turn arriving on that route.
Arriving on V-552 from the west results in less than a 120-degree course change
at CAESA, and because "NoPT" is authorized after CAESA, it's straight-in from
that direction on V-552.
It's only been in the past three years or so that they have started adding these
course change limitation notes to IAPs, although the requirement has always
existed in TERPS (subparagraph "b" below):
220. FEEDER ROUTES. When the IAF is part of the enroute structure there may be
no need to designate additional routes for aircraft to proceed to the IAF. In
some cases, however, it is necessary to designate feeder routes from the enroute
structure to the IAF. Only those feeder routes which provide an operational
advantage shall be established and published. These should coincide with the
local air traffic flow. The length of the feeder route shall not exceed the
operational service volume of the facilities which provide navigational guidance
unless additional frequency protection is provided. Enroute airway obstacle
clearance criteria shall apply to feeder routes. The minimum altitude
established on feeder routes shall not be less than the altitude established at
the IAF.
a. Construction of a feeder route connecting to a course reversal segment. The
area considered for obstacle evaluation is oriented along the feeder route at a
width appropriate to the type of route (VOR or NDB). The area terminates at the
course reversal fix, and is defined by a line perpendicular to the feeder course
through the course reversal fix.
b. The angle of intersection between the feeder route course and the next
straight segment (feeder/initial) course shall not exceed 120°.
c. Descent Gradient. The OPTIMUM descent gradient in the feeder route is 250
feet per mile. Where a higher descent gradient is necessary, the MAXIMUM
permissible gradient is 500 feet per mile. The OPTIMUM descent gradient for high
altitude penetrations is 800 feet per mile. Where a higher descent gradient is
necessary, the MAXIMUM permissible is 1,000 feet per mile.
Old January 29th 05, 07:53 PM
Jepp chart is posted at alt.binaries.pictures. aviation
Old January 30th 05, 01:00 AM
Bill J
I think a lot of folks may not know what "VICE" really means!
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
