propane preheater
Old December 23rd 06, 03:07 AM posted to rec.aviation.owning
dave
Default propane preheater
Another thread made me think about using the portable propane heater I
use in my garage to preheat my airplane. It's the standard metal tube
type with the fan from Home Depot or Lowes. I've seen people simply
attach a flex duct to the end of this type heater and blow the hot air
into the cabin - poor man's red dragon. Any drawbacks?
Thanks
Dave
Old December 23rd 06, 04:35 AM posted to rec.aviation.owning
Stan Prevost
If this is blowing the warm combustion gases into the cabin, plenty of
drawback. The combustion products are primarily carbon dioxide and water
vapor. Lots of water vapor. The moisture can fog all the windows, or
create frost on the inside of the windows if it is below freezing. OK on
the engine, bad in the cabin.
"dave" wrote in message
Another thread made me think about using the portable propane heater I use
in my garage to preheat my airplane. It's the standard metal tube type
with the fan from Home Depot or Lowes. I've seen people simply attach a
flex duct to the end of this type heater and blow the hot air into the
Thanks
Dave
Old December 23rd 06, 04:42 AM posted to rec.aviation.owning
Jim Carter[_1_]
-----Original Message-----
Posted At: Friday, December 22, 2006 10:35 PM
Posted To: rec.aviation.owning
Conversation: propane preheater
Subject: propane preheater
water
on
I
use
type
attach
a
Thanks
Dave
It may also render your CO detector completely useless. Aren't the
combustion products are CO and H2O, not CO2 and H2O?
Old December 23rd 06, 05:11 AM posted to rec.aviation.owning
Dave S
Complete combustion results in only C02 and H20.
Incomplete combustion, such as that in an (relatively) oxygen starved
environment, results in the formation of CO (carbon monoxide).
The trick is knowing wether or not you are having complete combustion.
People have died as a result.
Dave
Old December 24th 06, 02:44 PM posted to rec.aviation.owning
Ron Natalie
Those cheesy garage heaters generate CO. The instructions even warn
you not to use them in non vented spaces. I couldn't even use mine
in the garage with the door open without getting headaches.
Old December 23rd 06, 05:40 AM posted to rec.aviation.owning
Blanche
I've got a little ($15) ceramic heater that I put on the floor of the
cabin when I arrive at the airport -- and turn it on, of course. By the
time I've finished preflight and such, the cabin is comfy.
Old December 25th 06, 09:06 AM posted to rec.aviation.owning
Roger[_4_]
I think mine was about $20 but it has a nice thermostat, fan, and tilt
switch to turn it off if it tips over. OTOH they are probably
available cheaper. I set it on the floor in front of the seats and a
bit under the instrument panel. Works great and no smell or after
effects.
www.rogerhalstead.com
Old December 23rd 06, 01:08 PM posted to rec.aviation.owning
dave
I'm not planning on using it to preheat the cabin. I'm wondering how
this is any different than a red dragon or the large pre-heaters that
the FBO's use.
Dave
Thanks
Dave
Old December 23rd 06, 01:17 PM posted to rec.aviation.owning
Bob Noel
the FBO's use.
Are you thinking about blowing the hot air into the cabin or into
the engine compartment?
Bob Noel
Looking for a sig the
lawyers will hate
Old December 23rd 06, 01:42 PM posted to rec.aviation.owning
dave
Bob,
I'm really only interested in using it to heat the engine.
Dave
the FBO's use.
Engine preheater on ebay?? skym Owning 20 December 14th 05 04:10 AM
Ballooning propane hot air Instruction manual FA LindaBeynon General Aviation 0 March 12th 05 01:24 AM
Engine PreHeater In The Plane [email protected] Owning 4 February 24th 05 03:59 PM
Engine Preheater - any good? Bob Chilcoat Owning 26 January 31st 05 02:58 PM
Preheater Tony Roberts Owning 64 December 2nd 03 01:47 AM
