![]() Is anyone aware of a source for changes in airport identifiers? I flew into Hilton Head twice years ago and the first time I listed the ID as 49J and the second time as HXD. The first flight was in 1994 and the second in 1996. I did a decode on 49J and it shows as a non-existent identifier. HXD is current for Hilton Head. I found a few sites that say the ID changed with airline service was added, but I've not found any site that contains such history in general. Matt |
It is most likely due to a a weather station being installed at the
airport. I believe ICAO does not allow numbers in airport codes. Matt Whiting wrote: Is anyone aware of a source for changes in airport identifiers? I flew into Hilton Head twice years ago and the first time I listed the ID as 49J and the second time as HXD. The first flight was in 1994 and the second in 1996. I did a decode on 49J and it shows as a non-existent identifier. HXD is current for Hilton Head. I found a few sites that say the ID changed with airline service was added, but I've not found any site that contains such history in general. Matt |
Andrew Sarangan wrote:
It is most likely due to a a weather station being installed at the airport. I believe ICAO does not allow numbers in airport codes. Interesting. I just noticed that another airport I flew into years ago has disappeared (well the ID disappeared). 7I7 no longer exists. I'm finding all sorts of neat things as I enter my old logbook into logshare! Matt |
![]() Andrew Sarangan wrote: It is most likely due to a a weather station being installed at the airport. I believe ICAO does not allow numbers in airport codes. Canandaigua has an AWOS, but its code is D38. However the AWOS does not get reported if you ring flight service, or look up the METARS on ADDS. Saratoga, NY 5B3 is another example of this. Matt Whiting wrote: Is anyone aware of a source for changes in airport identifiers? I flew into Hilton Head twice years ago and the first time I listed the ID as 49J and the second time as HXD. The first flight was in 1994 and the second in 1996. I did a decode on 49J and it shows as a non-existent identifier. HXD is current for Hilton Head. I found a few sites that say the ID changed with airline service was added, but I've not found any site that contains such history in general. Matt |
![]() Matt Whiting wrote: Is anyone aware of a source for changes in airport identifiers? I flew into Hilton Head twice years ago and the first time I listed the ID as 49J and the second time as HXD. The first flight was in 1994 and the second in 1996. I did a decode on 49J and it shows as a non-existent identifier. HXD is current for Hilton Head. I found a few sites that say the ID changed with airline service was added, but I've not found any site that contains such history in general. Happens quiet frequently. I think its when AWOS is added. -Robert |
In a previous article, Matt Whiting said:
Is anyone aware of a source for changes in airport identifiers? I flew into Hilton Head twice years ago and the first time I listed the ID as 49J and the second time as HXD. The first flight was in 1994 and the As others have already mentioned, this is due to the need for weather reporting stations to have ICAO-compatible identifiers. The ICAO codes are 4 letters long, and start with a country code, and cannot have non-alphabetic characters in them (ie. no numbers). It is FAA practice to give airports in the continental US an FAA code that is just the ICAO code with the country prefix (K) stropped off if they have an ICAO code, so when an airport that has an FAA identifier that has digits in it gets weather, it changes identifier to match its new ICAO code. Unfortunately, when you're talking about FAA airports outside of the lower 48, like Alaska, Hawaii, Puerto Rico, or other US protectorates, the mapping between FAA code and ICAO code is much less easy. I've never found a good source of mappings between ICAO and FAA codes except in the DAFIF file, and that's gone the way of the Dodo bird. -- Paul Tomblin http://blog.xcski.com/ ....if you squeeze a MS product into a small enough memory footprint there may not be sufficient space for it to fall over, thus giving the impression it's reliable. -- Geoff Lane |
Some time ago one of the local airports here changed its ID from Q99
to E16. Anyone has any clue as to why would such a change occur? The airport has no weather station, the new ID also has digits in it. ... Are there any rules or guidelines out there specifying how to assign IDs to airports? Happy Holidays - Tom On Tue, 26 Dec 2006 19:41:43 +0000 (UTC), (Paul Tomblin) wrote: In a previous article, Matt Whiting said: Is anyone aware of a source for changes in airport identifiers? I flew into Hilton Head twice years ago and the first time I listed the ID as 49J and the second time as HXD. The first flight was in 1994 and the As others have already mentioned, this is due to the need for weather reporting stations to have ICAO-compatible identifiers. The ICAO codes are 4 letters long, and start with a country code, and cannot have non-alphabetic characters in them (ie. no numbers). It is FAA practice to give airports in the continental US an FAA code that is just the ICAO code with the country prefix (K) stropped off if they have an ICAO code, so when an airport that has an FAA identifier that has digits in it gets weather, it changes identifier to match its new ICAO code. Unfortunately, when you're talking about FAA airports outside of the lower 48, like Alaska, Hawaii, Puerto Rico, or other US protectorates, the mapping between FAA code and ICAO code is much less easy. I've never found a good source of mappings between ICAO and FAA codes except in the DAFIF file, and that's gone the way of the Dodo bird. |
![]() "Tom L." wrote in message ... Are there any rules or guidelines out there specifying how to assign IDs to airports? FAA Order 7350.7 LOCATION IDENTIFIERS http://www.faa.gov/airports_airtraff.../CH1.htm#1-2-7 |
![]() Matt Whiting wrote: Is anyone aware of a source for changes in airport identifiers? Check this out: http://www.airnav.com/airports/id-changes-all.html. It supposedly goes back to 1995. While on the subject, I'll comment that keeping one's GPS database current is a good idea - even if you only use it for VFR situational awareness. If you don't you are likely to see identifiers appear on your moving map that don't agree with your charts (assuming that they are current as well). Been there, done that (with a borrowed GPS). David Johnson |
Dave wrote:
Matt Whiting wrote: Is anyone aware of a source for changes in airport identifiers? Check this out: http://www.airnav.com/airports/id-changes-all.html. It supposedly goes back to 1995. While on the subject, I'll comment that keeping one's GPS database current is a good idea - even if you only use it for VFR situational awareness. If you don't you are likely to see identifiers appear on your moving map that don't agree with your charts (assuming that they are current as well). Been there, done that (with a borrowed GPS). David Johnson Thanks, just what the doctor ordered. Matt |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
WI airport closure | Mike Spera | Owning | 0 | March 9th 05 01:53 PM |
Q: Airport Identifiers | [email protected] | Piloting | 6 | December 23rd 04 01:28 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
