We are getting a brand new ILS 26 at KANE and I just downloaded the plate. The
miss is what I expected to see and is a hold at the GEP "Gopher" VOR a few miles to the west. But there is also a hold depicted at the PNM NDB, which is a long ways away. That hold is not mentioned on the plate. I am wondering why it is there. My only guess is that it might be an alternate hold that ATC could assign if things were busy at GEP. GEP is the FAF for at least two other approaches and is on at least one STAR into KMSP. Anyone? |
Mitty wrote:
We are getting a brand new ILS 26 at KANE and I just downloaded the plate. The miss is what I expected to see and is a hold at the GEP "Gopher" VOR a few miles to the west. But there is also a hold depicted at the PNM NDB, which is a long ways away. That hold is not mentioned on the plate. I am wondering why it is there. My only guess is that it might be an alternate hold that ATC could assign if things were busy at GEP. GEP is the FAF for at least two other approaches and is on at least one STAR into KMSP. Anyone? Where the procedure has two missed approach procedures (only the primary one is charted) there is a fairly recent policy change to chart the holding pattern at the end of the second/alternate missed approach procedure. Jeppesen lables them as such. I have no idea whether NACO does. They certainly didn't with this one. I'll get ahold of the Jepp chart soon and let you know. |
![]() On 1/9/2007 6:13 PM, Sam Spade wrote the following: Mitty wrote: We are getting a brand new ILS 26 at KANE and I just downloaded the plate. The miss is what I expected to see and is a hold at the GEP "Gopher" VOR a few miles to the west. But there is also a hold depicted at the PNM NDB, which is a long ways away. That hold is not mentioned on the plate. I am wondering why it is there. My only guess is that it might be an alternate hold that ATC could assign if things were busy at GEP. GEP is the FAF for at least two other approaches and is on at least one STAR into KMSP. Anyone? Where the procedure has two missed approach procedures (only the primary one is charted) there is a fairly recent policy change to chart the holding pattern at the end of the second/alternate missed approach procedure. Jeppesen lables them as such. I have no idea whether NACO does. They certainly didn't with this one. I'll get ahold of the Jepp chart soon and let you know. That's probably it then. The charted hold at GEP is at 2700, so having someone there would make both the KANE VOR 9 and the KMIC VOR-A unusable. PNM is a pretty good haul but it is out in the weeds, trafficwise. |
Mitty wrote:
ahold of the Jepp chart soon and let you know. That's probably it then. The charted hold at GEP is at 2700, so having someone there would make both the KANE VOR 9 and the KMIC VOR-A unusable. PNM is a pretty good haul but it is out in the weeds, trafficwise. Here is the source document for the procedu http://tinyurl.com/y39o4b |
![]() On 1/10/2007 5:13 AM, Sam Spade wrote the following: Here is the source document for the procedu http://tinyurl.com/y39o4b Slick. Where does one find those pages? & the more I look at it, the screwier it seems to be. First, there is no ADF requirement on the plate, so I guess ATC would have to ask before assigning the alternate miss. Then, there is little hope of being able to actually navigate to the NDB without getting vectors (or having a GPS) due to the 30 mile distance and the fact that you are starting from 200 feet AGL. And ... there is a perfectly good NDB at CBG which is 5 miles closer and _not_ on an airway as is the PNM NDB. So now I wonder why we aren't going there? ... All that being said, it is mostly irrelevant to real operations anyway because MSP Approach assigns an initial heading and altitude for the miss before you get handed off and then provides vectors when you check back in. |
Mitty wrote:
On 1/10/2007 5:13 AM, Sam Spade wrote the following: Here is the source document for the procedu http://tinyurl.com/y39o4b Slick. Where does one find those pages? The FAA posts them on their IAP coordination web site during coordination. Sometimes they forget to remove them after coordination is completed. That is the case with this one. http://www.avn.faa.gov/acifp.asp |
Here is the Jepp chart:
http://tinyurl.com/y4q777 Note Jepp is more descriptive about the "dangling NDB." So, I guess the astute pilot would infer "ADF Required" when flight planning because it is unkown when the unkown alternative missed approach might be assigned. The NACO chart user wouldn't know the NDB hold is for an alternate missed approach, though. Goofy or what? |
Looks like this is another of those ILS or LOC/DME procedures. Is
there no requirement for an outer marker or equivalent these days? Without DME there is no way to check the glideslope over BOKYA. Sam Spade wrote: Here is the Jepp chart: http://tinyurl.com/y4q777 Note Jepp is more descriptive about the "dangling NDB." So, I guess the astute pilot would infer "ADF Required" when flight planning because it is unkown when the unkown alternative missed approach might be assigned. The NACO chart user wouldn't know the NDB hold is for an alternate missed approach, though. Goofy or what? |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Tent Buying Guide (long, print it out) | john smith | Piloting | 24 | August 5th 05 06:12 PM |
Extra Kollsman Altimeter Poimters | [email protected] | Piloting | 34 | July 15th 05 11:56 AM |
Extra bracing | Lou | Home Built | 9 | April 24th 05 01:37 AM |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
