Looking for experiance with airport web-cams
Old January 14th 07, 07:28 PM posted to rec.aviation.soaring
DNewill
Default Looking for experiance with airport web-cams
I am looking for any club or airport that has installed a (set of) web
cam(s) for online viewing of the airport and weather. It would seem that
with webcams becoming so very low cost, and used computers nearly free, that
other than the cost per month of the connection ( aprt of phone line costs?
DSL =~ $20 / month) this would be a good investment for clubs to have.
Members could see hangers for security, activity on airport ( "is anyone
else out at the field?") and local actual weather - especially important
when you have to drive over an hour to get to the field.
SO... if your club has experiance with this sort of thing, please contact me
[ Remove NOSPAM ]
Old January 14th 07, 10:33 PM posted to rec.aviation.soaring
Check the Williams soaring site in California. They have a web cam
pointed at the runway and another at the nearby mountain range.
[ Remove NOSPAM ]
Old January 15th 07, 12:56 PM posted to rec.aviation.soaring
Maxime Lemeunier
[ Remove NOSPAM ]
In angers (France) we have a webcam :
http://www.planeur-angers.net/page.php?page=webcam
Old January 15th 07, 02:30 PM posted to rec.aviation.soaring
Dan G
[ Remove NOSPAM ]
To get the best image of the weather conditions, you want a cam
pointing north (assuming northern hemisphere) with the horizon just in
view. This will minimise the camera being washed out by sunlight or
over-exposing the sky due to dark ground being in the frame, while
still giving viewers a reference. A second cam pointing at a distant
landmark (for daylight) or an outside lamp (for darkness) can be useful
for assessing visibility.
Make sure your cam puts 640x480 images on the web, I still see lots of
websites with 320x240 images which are just too small and
low-resolution to be useful.
Dan
Old January 15th 07, 04:59 PM posted to rec.aviation.soaring
J. Nieuwenhuize
http://cvvmc.free.fr/
Ask La Motte du Caire, they have a fine camera hanging outside of their
building.
[ Remove NOSPAM ]
Dan
Old January 17th 07, 11:11 PM posted to rec.aviation.soaring
Eric Greenwell
I recently installed a web accessible camera at our airport. You can see
it at
http://rldcloudcam.viewnetcam.com:50000
The ideal location will be in a heated/cooled indoor location with
Internet access and a window looking in the desired direction. A $30
webcam and a minimal computer puts you in business. You can connect
another webcam looking in a different direction, too. I didn't do it
this way, so I can't help with the details of getting the pictures onto
the web, but the camera software might take care of that.
Unless it's an expensive camera, it will need protection if the sun will
enter it's field of view. My experience and analysis is a number 3
welding filter (~12% visible light transmission) is more than adequate.
The camera's automatic exposure and white balance seem to handle the
loss of light and green tint well.
No good window? Mounting it outside means you need weather protection.
There are nice boxes with heaters, fans, sun shields, and adjustable
direction mounts for $50-$100. They won't fit every camera you might
choose, and they don't do any cooling below the ambient air temperature.
The cameras typically have a max operating temperature of 105 F, but
they will go somewhat above that before they stop working
(temporarily/permanently - depends on the camera and temperatures). You
also need to get power and the Internet to the camera. Wireless access
eliminates the network cable, but you still need the power cable for the
camera, heaters, and fan.
Another approach is to use a "network camera", like the one I use: it's
a Panasonic BL-C10A (info at http://tinyurl.com/hkvfa). ThIt's less than
$200 and connects directly to the Internet without needing a computer.
It produces the web page you see when you access it, and all the
settings are done over the Internet or a local network. Panasonic
provides a free service (viewnetcam.com) lets you connect using a name
("rldcloudcam" for mine), instead of needing to know the IP number, and
there are also other similar services, some free.
The network cameras are more costly, but having a computer at the
location I used wasn't practical. The Panasonic is very easy to set up,
unless your DSL/Cable/whatever modem has a built-in router, then you
have to disable that - not hard if you know it's there.
The unit I use pans and tilts (a "PT" camera), so I could cover a 160
degree swath with one camera instead three. You can connect several
network cameras to your Internet connection through a router and put
therm in different locations. You can also get cameras with
pan/tilt/zoom (a "PTZ" camera), but these seem to start about $400, and
one acceptable to me is over $600. Cheap zoom = lousy image, I found.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Palo Alto airport, potential long-term problems... [email protected] Piloting 7 June 6th 05 11:32 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Piloting 16 January 20th 04 04:02 PM
