$ means maintenance required on a METAR (and some people thank that the FAA
has no sense of humor) Anyway, if a $ appears in the METAR, does it mean that: 1. No METAR info should be trusted 2. All METAR info should be trusted but some might be missing 3. It is guaranteed to be VFR anyway Thanks, Hilton |
Hilton wrote:
$ means maintenance required on a METAR (and some people thank that the FAA has no sense of humor) Anyway, if a $ appears in the METAR, does it mean that: 1. No METAR info should be trusted 2. All METAR info should be trusted but some might be missing 3. It is guaranteed to be VFR anyway So what does $$ or $$$ mean? And what about the level/quality of service? Hours of operation? Dinner only or lunch & dinner? Open on Mondays? How about weekend brunch? (*sorry, couldn't resist*) |
Hilton wrote:
$ means maintenance required on a METAR (and some people thank that the FAA has no sense of humor) The "ASOS User's Guide", http://www.nws.noaa.gov/asos/pdfs/aum-toc.pdf (linked from http://www.nws.noaa.gov/asos/ ), says that "The $ is used to indicate that maintenance may be needed but does not necessarily mean that the data are erroneous." (pg. 2, PDF page 9) Report pages 19, 26, and 31 (PDF pages 26, 33, and 38) list some conditions under which the $ will appear for problems with various sensors. Chapter 7 of the AIM tells you how to read a METAR, but doesn't mention the $ indicator. http://www.faa.gov/airports_airtraff...7/aim0701.html Matt Roberds |
If the METAR says (among other things) "SKC P6SM $" - is it VFR?
Right now I bet most pilots won't even see the "$" and/or know what the implications are. Hilton wrote in message ... Hilton wrote: $ means maintenance required on a METAR (and some people thank that the FAA has no sense of humor) The "ASOS User's Guide", http://www.nws.noaa.gov/asos/pdfs/aum-toc.pdf (linked from http://www.nws.noaa.gov/asos/ ), says that "The $ is used to indicate that maintenance may be needed but does not necessarily mean that the data are erroneous." (pg. 2, PDF page 9) Report pages 19, 26, and 31 (PDF pages 26, 33, and 38) list some conditions under which the $ will appear for problems with various sensors. Chapter 7 of the AIM tells you how to read a METAR, but doesn't mention the $ indicator. http://www.faa.gov/airports_airtraff...7/aim0701.html Matt Roberds |
