intake air filter choices
Old January 18th 07, 01:07 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default intake air filter choices
After using a lawn tractors slightly oiled, green foam filter on my
experimental with C-85, a fellow remarked that it was much too thick (about
1") as I replaced it.
Just wondering what non-certified (read cheap G) alternatives that others
are using. Seems like most guys use a pleated paper-like filter...
Thanks Dick
Old January 18th 07, 02:13 PM posted to rec.aviation.homebuilt
jls
"Dick" wrote in message
news:GiKrh.2487$jG1.88@trnddc04...
(about
others
Thanks Dick
A Brackett filter for a certified aircraft with C-85 would be about
the same thickness. You don't want to suck anything, such as a part
of the filter, up into the carburetor.
Even Bracketts have had their problems with AD's because of parts of
the filter migrating into the venturi.
Old January 18th 07, 03:42 PM posted to rec.aviation.homebuilt
Maxwell
(about 1") as I replaced it.
others are using. Seems like most guys use a pleated paper-like filter...
Thanks Dick
Check with the K&N filter folks. They have a lot of high performance filters
to choose from.
Old January 18th 07, 07:04 PM posted to rec.aviation.homebuilt
Dan Youngquist
filters to choose from.
Amsoil makes an oiled foam filter that flows as good as K&N, and filters a
lot better. (And last I looked, they're cheaper.) They have them for
most automotive applications.
-Dan
Old January 18th 07, 03:48 PM posted to rec.aviation.homebuilt
Maxwell
Thanks Dick
http://www.knfilters.com/
Old January 18th 07, 09:57 PM posted to rec.aviation.homebuilt
john smith
Thanks Dick
Foam filters have a history of coming apart, getting sucked into the
carburetor, and causing blockages which results in the engine stopping.
Makes for interesting emergency landing explanations.
Old January 19th 07, 03:06 PM posted to rec.aviation.homebuilt
Thanks Dick
We've been using the Brackett foam filters on our training
airplanes for 14 years (and 13 airplanes, five or six at any one time,
hundreds of hours per year per airplane) and have had no trouble
whatever. The filters work well enough that the engines reach TBO with
the compression still in the high 70s, even though we do a lot of
training off dirt strips, and are cheap to replace. It's not an oil in
the Brackett filter, its a glycerine or silicone goop of some sort.
Can't try to wash and re-oil it. It needs to be replaced yearly in any
case to prevent decaying foam getting into the intake.
There have been a couple of ADs against the Bracketts: one
involved the rear screen (aluminum) vibrating and flexing then breaking
and entering the engine; it was superceded by a steel-screened frame.
The other was to do with the filter frame/airbox gasket on some models
getting sucked in; another revision fixed that.
Every time we get another airplane it gets a Brackett.
Dan
Old January 18th 07, 11:39 PM posted to rec.aviation.homebuilt
Scott[_1_]
Cripes! How cheap is cheap?! A replacement Brackett air filter is only
about 6 bucks and you replace it at each annual (unless you live in a
particularly dirty and dusty area)...
Scott
Thanks Dick
Dick[_1_]
ordered 2, thanks
"Scott" wrote in message
Scott
Thanks Dick
Century IIIB Rate Filter Parts and Schematics PilotMike2004 Owning 1 January 10th 05 12:01 PM
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Naval Aviation 5 August 21st 04 12:50 AM
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Military Aviation 3 August 21st 04 12:40 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Filter element for Frantz filter Philippe Owning 1 April 20th 04 08:23 PM
