Lost log books
Old January 25th 07, 04:04 AM posted to rec.aviation.piloting
Aluckyguess
Default Lost log books
I looked at an A36 and was thinking about buying it, but he lost the logs.
My question is how much does this usually decrease the value of the plane.
Old January 25th 07, 05:15 AM posted to rec.aviation.piloting
BT
he's got zero logbooks for it?
start running.. away... very far away and as fast as you can..
BT
"Aluckyguess" wrote in message
Old January 25th 07, 05:53 AM posted to rec.aviation.piloting
Jim Macklin
Without logs, how do you know the flight hours on the
airframe or engine? Without that, how do you comply with AD
notes?
But if the plane looks good and he can prove ownership, you
can re-create the logs from sources.
The FAA should have records on the airplane. Beech will
have records of manufacture and probably spare parts orders.
It is some detective work and some parts, such as engines
and props may need to be overhauled or replaced anyway.
Talk to a good A&P/AI who "knows the model" and do a little
research.
My guess is that the price should be adjusted $25,000 to
$100,000 lower than a "perfect" airplane to cover your
costs.
You will need a real annual inspection by YOUR mechanic, not
his. That will cost several thousand dollars, just for the
inspection and logbook research just to find out what MUST
be replaced or re-done.
James H. Macklin
ATP,CFI,A&P
"BT" wrote in message
can..
| BT
he lost the logs.
value of the plane.
Old January 25th 07, 03:12 PM posted to rec.aviation.piloting
Aluckyguess
"Jim Macklin" wrote in message
notes?
He can and he has one annual done on it. The A/P had the hours in his
computer.
He has that disk and the number of the guy who owned the plane before him.
He just did the prop it has 1 hour.
research.
I would do a complete annual using my mechanic as a pre buy.
That was my guess, that equates to about 20%
I dont think he will sell it at that price so it mute anyhow.
costs.
I was thinking you could have a fun summer flying to all the places that
worked on the airplane re-creating the logs.
Would this be as good as original if done?
thanks
James H. Macklin
ATP,CFI,A&P
can..
| BT
he lost the logs.
value of the plane.
Old January 25th 07, 04:20 PM posted to rec.aviation.piloting
"Aluckyguess" :
Would this be as good as original if done? be replaced or re-done.
God forbid, if anything happened while you were having that fun summer
flying all over the place re-creating logs and the plane were totaled,
would the insurance cover the full value if you the documentation was
incomplete? Why would you want to put yourself in that situation? It
isn't as if finding an A36 with complete documentation is difficult.
Old January 25th 07, 05:18 PM posted to rec.aviation.piloting
Bela P. Havasreti
On Thu, 25 Jan 2007 09:20:06 -0700, unicate wrote:
"Aluckyguess" :
While I agree having a complete set of logs for a given aircraft
is a desirable thing, in the event of a total loss, the insurance
company will pay the stated hull value regardless of whether
or not the aircraft has a "complete set of logs". The stipulations
of the policy will be followed to the letter, and typically, nowhere
in said policy does it say "we only agree to pay if you don't lose
your logs". You will have to prove the aircraft was in annual /
airworthy at the time of the loss, etc.
I'll also allow as how having logs missing on an aircraft doesn't
necessarily mean an automatic "pass" (i.e., forget it, go look for
another aircraft) but it does raise a flag while looking at an
aircraft I'm contemplating purchasing.
My "Murphy's Law" meter gets pegged over on the "what is the owner
trying to hide by claiming the logs have been lost" side of the
scale. 8^)
FWIW, my '54 C-170B had it's 1st log missing (several years worth,
from '54 to the early 60's) but had everything from then on. After
I had a look at the airplane and the rest of the logs, I reasoned that
there was sufficient documentation for decades of ownership /
operation and that I could live with not having the 1st logbook (it
was claimed to have been lost by the way).
My current aircraft ('54 C-180) has everything dating back to day
one, including the initial test flight entry by the Cessna test pilot
in 1954.
Bela P. Havasreti
Old January 25th 07, 05:39 PM posted to rec.aviation.piloting
Jim Macklin
I would see just what was required to get a valid set of
records before any money on the airplane sale changed hands.
You use all available data to create new logs, shop data and
records, parts receipts, just as long you can rely on the
data, the FAA will accept it. But sometimes you have to
re-do work and that can become very expensive.
| "Jim Macklin" wrote
in message
with AD
| notes?
you
hours in his
| computer.
orders.
plane before him.
engines
little
| research.
buy.
anyhow.
| costs.
not
MUST
the places that
| thanks
| James H. Macklin
| ATP,CFI,A&P
you
| can..
| | BT
but
| he lost the logs.
| value of the plane.
Old January 25th 07, 06:02 AM posted to rec.aviation.piloting
buttman
It's perfectly reasonable that a well maintained plane could have it's
logbooks go missing.
The flight school I work at has all the logbooks for their planes
stored in one room by the maintenance hangar. If that thing goes up in
flames, the planes are no less flyable.
Old January 25th 07, 11:57 AM posted to rec.aviation.piloting
Lou
I would hope someone was smart enough to buy a fire proof safe for that
room.
If they did go up in flames how would your student take their
checkride?
Lou
Old January 25th 07, 01:00 PM posted to rec.aviation.piloting
Peter Dohm
room.
Great idea, but that would put them on a different "plane of reality" from
most places I recall working. Admittedly, none were aircraft
operators--but...
Peter
Soaring Books Resource Paul Remde Soaring 1 August 14th 06 02:16 PM
hundreds aviation books for sale on CDs! centara Aviation Marketplace 0 March 1st 04 10:40 PM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 January 31st 04 11:39 PM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
