I'd like to revisit a topic bandied about on this newsgroup many moons ago.
At the time I wasn't in the market for one of those LED gizmos that straps on the head -- now I am. I vaguely recall there being some adverse criticism about the inability to control what was perceived as "too bright." Is that still the case? Or have the devices improved since then? If you use one, do you strap it on before takeoff? Or wait until it is needed to put it on? Do you put in on under or over your headset? In either case, how long can you tolerate it? I did some unsuccessful Googling to see if I could find one that will clip onto the side or top of the headset. Anybody seen something like that? (I did find the one that will clip onto the bill of a cap, but it didn't seem like it would work on the headset.) -- Regards, Casey Wilson Freelance Writer and Photographer |
On 1/25/2007 1:05:22 PM, "Casey Wilson" wrote:
I vaguely recall there being some adverse criticism about the inability to control what was perceived as "too bright." Is that still the case? Or have the devices improved since then? I have an Eveready LED headlight that includes both a red and a white light selection. I think I paid $12 for the unit. The red light is perfect for night flight and reading approach plates. If you use one, do you strap it on before takeoff? Or wait until it is needed to put it on? I put it on before takeoff since I like it under my headset. Do you put in on under or over your headset? In either case, how long can you tolerate it? I have had no problems going 2 or 3 hours with it. Over time I have loosened the band to a very loose setting since that relieves the pressure, making it quite tolerable. -- Peter |
On Jan 25, 1:20 pm, "Peter R." wrote:
I have had no problems going 2 or 3 hours with it. Over time I have loosened the band to a very loose setting since that relieves the pressure, making it quite tolerable. I have the same one from Eveready. I too have loosened it over time as it would give me a headache after an hour or so. This model also has a "pitch" adjustment so you can have the red light shine on the approach plate with minimal head tilting. Got mine at Target for $12 and use it all the time. Like Peter, I put it under my headset band. Marco |
On 1/25/2007 1:50:09 PM, "Marco Leon" wrote:
This model also has a "pitch" adjustment so you can have the red light shine on the approach plate with minimal head tilting. Good point. I forget to mention that fact. Got mine at Target for $12 and use it all the time. Yep, that's where I bought mine, too. -- Peter |
Casey,
I went to the evil megastore known as Wal-Mart and found a headlamp that has red LED, white LED, and incandescent lights that runs on a single AA battery. It's about $11-12 and is produced by Ray-O-Vac. I've used it for a couple of years for night flying and it's not too bright or to dim. The white light also works well. It has a couple straps that holds it well on your head. It's a cheaper, better solution than I've seen in ANY aviation-related store/catalog/sales-website. This amazon link has a picture of it. http://tinyurl.com/ya94gx Chris G., PP-ASEL Salem, Oregon Casey Wilson wrote: I'd like to revisit a topic bandied about on this newsgroup many moons ago. At the time I wasn't in the market for one of those LED gizmos that straps on the head -- now I am. I vaguely recall there being some adverse criticism about the inability to control what was perceived as "too bright." Is that still the case? Or have the devices improved since then? If you use one, do you strap it on before takeoff? Or wait until it is needed to put it on? Do you put in on under or over your headset? In either case, how long can you tolerate it? I did some unsuccessful Googling to see if I could find one that will clip onto the side or top of the headset. Anybody seen something like that? (I did find the one that will clip onto the bill of a cap, but it didn't seem like it would work on the headset.) |
"Casey Wilson" writes:
I'd like to revisit a topic bandied about on this newsgroup many moons ago. At the time I wasn't in the market for one of those LED gizmos that straps on the head -- now I am. I vaguely recall there being some adverse criticism about the inability to control what was perceived as "too bright." Is that still the case? Or have the devices improved since then? If you use one, do you strap it on before takeoff? Or wait until it is needed to put it on? Do you put in on under or over your headset? In either case, how long can you tolerate it? I did some unsuccessful Googling to see if I could find one that will clip onto the side or top of the headset. Anybody seen something like that? (I did find the one that will clip onto the bill of a cap, but it didn't seem like it would work on the headset.) http://www.mypilotstore.com/mypilotstore/sep/1490 for the Pelican headset flightlight system. (I googled, this came up.) I had a head-strap LED light, but it would get bumped into the "on" position occasionally, and ran the batteries down once too many times. I never got around to needing it in the plane. The LED flashlight I have (three white LEDs, one blue, one red) gives me all the extra "aimable" light I need, so haven't replaced the head-strap light. Your mileage may, of course, vary. -Jack |
"Casey Wilson" wrote in message
news:Bj6uh.3184$R65.730@trnddc01... I'd like to revisit a topic bandied about on this newsgroup many moons ago. At the time I wasn't in the market for one of those LED gizmos that straps on the head -- now I am. I vaguely recall there being some adverse criticism about the inability to control what was perceived as "too bright." Is that still the case? Or have the devices improved since then? There is a lot of variaty in terms of brightness and color (just red, just white, both). I have one that is just white LED's, but it has three brightness settings. And it tilts to aim up and down. That works well. Red would probably be a better option in the cockpit... If you use one, do you strap it on before takeoff? Or wait until it is needed to put it on? Do you put in on under or over your headset? In either case, how long can you tolerate it? I don't fly much anymore - but I sometimes wear it all night on the boat and turn it on / off as required. Batteries last at least a year with ocassional use... The trick is to not look at people when you talk to them when you have it on :-) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() Capt. Geoffrey Thorpe wrote: There is a lot of variaty in terms of brightness and color (just red, just white, both). I have one that is just white LED's, but it has three brightness settings. And it tilts to aim up and down. That works well. Red would probably be a better option in the cockpit... Blue is actually the best. Provides bright light without destroying your night vision. |
![]() I was looking for good supplemental cockpit lighting when a friend turned me on to the Ashlight. It mounts in the useless ashtray hole and provides excellent illumination from 4 red LEDs. One on the pilot's side is plenty in my Cherokee, but I'm thinking of getting another for the passenger door, for use as a boarding/courtesy light. The main thing I like about it is that I don't have to remember to bring it with me or figure out how to clip it to my head. It runs on a couple of AA batteries, which have so far lasted over a year. John Galban=====N4BQ (PA28-180) -- JGalban Posted at www.flight.org |
Casey Wilson wrote:
I'd like to revisit a topic bandied about on this newsgroup many moons ago. At the time I wasn't in the market for one of those LED gizmos that straps on the head -- now I am. I vaguely recall there being some adverse criticism about the inability to control what was perceived as "too bright." Is that still the case? Or have the devices improved since then? If you use one, do you strap it on before takeoff? Or wait until it is needed to put it on? Do you put in on under or over your headset? In either case, how long can you tolerate it? I did some unsuccessful Googling to see if I could find one that will clip onto the side or top of the headset. Anybody seen something like that? (I did find the one that will clip onto the bill of a cap, but it didn't seem like it would work on the headset.) I have one of the Rayovac $14.00 jobs. First on is two red leds, second setting is one white led, the third setting is an incandesce bulb. I put the thing on first then head set. It is ready to go. Nice for night preflights and cockpit duties. I usually left it off until needed and the first click was the red leds. I found it brighter that I really liked, but I could point it to the shadows in my C-172. A responder commented you do not want to be moving your head during night IFR. I guess that could be a problem, but you have to move your head anyway to look at what you want. The "aviation" ones are too expensive. This works fine. My wife like to read in the plane and she has one and used the red leds to read. She said it didn't bother her at all. -- Regards, Ross C-172F 180HP KSWI |
