Another newbie question for the group:
(I feel like this MUST have been discussed here before, but my search came up empty--if I need to work on my USENET search skills, try to be gentle with me....) Can anyone help me decode what's going on with Lycoming's SB 569? It seems like all the airplanes I'm looking at use Lycoming IO-540 engines, which I understand are, possibly, subject to that service bulletin. I've read that the FAA is considering making that an AD, meaning that the crankshaft would need to be replaced at the next overhaul or other case opening. There's something like a three-year window in order to get the new shaft at 2AMU, after which it will go to 16AMU(?). So--if that's a mandatory replacement, it seems like there'd be a strong economic argument to overhaul before the window closes, whether it needs it or not. - Is there any easy way to tell whether a given airplane has an affected crankshaft? I'm a newbie, inexperienced (to put it politely) with reading logs. Of course, I would expect that to turn up in any pre-buy, but I'm thinking along the lines of maybe there are some other factors that would let me know "there's no way this plane is affected, because _________"--save a lot of trouble trying to verify that there's no issue. - Anyone know the status of the AD? Anyone have opinions on what to do w/ the SB if it does NOT become an AD? I see AOPA is opposed to the AD, for what that's worth.... - While shopping, any suggestions on how to value/devalue a given airplane based on its status with this? Thanks! -- Doug "Where am I to go/Now that I've gone too far?" -- Golden Earring, "Twilight Zone" (my email is spam-proofed; read the address and make the appropriate change to contact me) |
Look up AD 2006-20-09, I believe this may be the latest in a series of ADs
about the crankshaft in referenced (started by) that SB569 (you know there is a new SB569a). There is an extensive list of serial numbers that it applies to, you need to know the serial number in the engine you are looking at to know if the AD applies. Lycoming had a "bad batch", of cranks produced, it's a metallurgy thing. Our older (much older) crank is doing just fine, built previous to this AD, and keeps on going... and going.. and going. Good Luck BT "Douglas Paterson" wrote in message . .. Another newbie question for the group: (I feel like this MUST have been discussed here before, but my search came up empty--if I need to work on my USENET search skills, try to be gentle with me....) Can anyone help me decode what's going on with Lycoming's SB 569? It seems like all the airplanes I'm looking at use Lycoming IO-540 engines, which I understand are, possibly, subject to that service bulletin. I've read that the FAA is considering making that an AD, meaning that the crankshaft would need to be replaced at the next overhaul or other case opening. There's something like a three-year window in order to get the new shaft at 2AMU, after which it will go to 16AMU(?). So--if that's a mandatory replacement, it seems like there'd be a strong economic argument to overhaul before the window closes, whether it needs it or not. - Is there any easy way to tell whether a given airplane has an affected crankshaft? I'm a newbie, inexperienced (to put it politely) with reading logs. Of course, I would expect that to turn up in any pre-buy, but I'm thinking along the lines of maybe there are some other factors that would let me know "there's no way this plane is affected, because _________"--save a lot of trouble trying to verify that there's no issue. - Anyone know the status of the AD? Anyone have opinions on what to do w/ the SB if it does NOT become an AD? I see AOPA is opposed to the AD, for what that's worth.... - While shopping, any suggestions on how to value/devalue a given airplane based on its status with this? Thanks! -- Doug "Where am I to go/Now that I've gone too far?" -- Golden Earring, "Twilight Zone" (my email is spam-proofed; read the address and make the appropriate change to contact me) |
Yeah, pretty much what BT said. If you get a .pdf version of the AD,
you can quickly search for the engine serial number in question. Been there/done that a couple of times in reference to our IO-360. So far, no hits! :-) -- Jack Allison PP-ASEL-Instrument Airplane "To become a Jedi knight, you must master a single force. To become a private pilot you must strive to master four of them" - Rod Machado (Remove the obvious from address to reply via e-mail) |
On Sun, 28 Jan 2007 20:58:26 -0800, Jack Allison
wrote: Yeah, pretty much what BT said. If you get a .pdf version of the AD, you can quickly search for the engine serial number in question. Been there/done that a couple of times in reference to our IO-360. So far, no hits! :-) AAUI, it's only counterweighted crankshafts so unless your engine has a counterweight you'll likely never see it show up on the list. I know of 2 182s which got hit with 566 and one turbo 182 which got hit with 569A. |
| Lycoming SB569 - how many changing cranks as a precaution? | Ross Richardson | Owning | 0 | April 24th 06 07:15 PM |
| Dodged Lycoming SB569 | Jack Allison | Owning | 0 | March 13th 06 02:35 AM |
| How many Lycomings built? | Ben Hallert | Home Built | 6 | January 30th 06 03:50 AM |
| Airboat Lycoming's | Lou | Home Built | 14 | December 11th 05 08:04 PM |
| Lycoming's views on best economy settings | [email protected] | Piloting | 37 | July 8th 04 05:00 PM |
