Test flight ballast ideas?
Old January 28th 07, 05:05 PM posted to rec.aviation.homebuilt
Default Test flight ballast ideas?
Can anyone give me some ideas for temporary, but securable weight
ballasts? The situation is we're preparing for FAA required test
flights on our FIRST production aircraft. Weight will most likely need
to be positioned in the right seat area, and/or in the limited baggage
area behind the two seats. Wing bladders are not an option, nor is
anything requiring a permanent mount. A non-U.S. built model of this
aircraft has already been certified for U.S. flight. This is the first
built here; but is not a prototype or "test model". This aircraft will
be sold to a private buyer once it passes flight tests. This is the
reason for the ballasts needing to be "non-invasive". I was thinking
of something that could be bolted to the right seat mounts and/or
strap secured in the baggage compartment.
Any suggestions or sources?
Thanks,
DocS
Old January 28th 07, 05:16 PM posted to rec.aviation.homebuilt
Carl Ellis
One, three, or five gallon water jugs filled with sand, lead shot, or water.
You might even be able to borrow (buy or rent) lead shot bags from a
scuba diving shop. They could be easily secured in a small duffel.
- Carl -
Old January 28th 07, 05:24 PM posted to rec.aviation.homebuilt
Vaughn Simon
I assume that you need something less than 200# in the front seat. It
would be nice if you could find a container about the diameter of a human torso
(trash can?), fill it with heavy "stuff" and strap it in place right on the seat
to avoid building something special. If necessary, remove the seat cushions to
make more room and use just the seat frame. Borrow some scrap lead from a tire
shop? It it possible to strap a suitcase in the luggage area?
Use your imagination! I once made a glider seat ballast by sewing $20.00
worth of penny rolls into an old pillow case.
Vaughn
Old January 29th 07, 12:49 AM posted to rec.aviation.homebuilt
Bob Upp
How about 1 to 3 sandbags depending on your requirement. They don't take
lunch breaks and no workers comp claims. If you are good with a sewing
machine you can sew up a human shaped torso and limbs from 1000D Cordura
and pour the sand into it. Make in the anatomically correct female form
and call her (it) Sandy.
Thanks,
DocS
Old January 29th 07, 02:30 AM posted to rec.aviation.homebuilt
Doug Palmer
Fine lead shot can be bought - sometimes borrowed from a good gun suplier.
the bags are small, about the size of a standard red brick, well
packaged/secured, and weigh 20 lbs each. Stuffed into a army issue canvass
duffle bag, the type with the hook NOT the zipper, then lashed down, should
be about as secure as you will get, and you don't have to move 200 lbs at
one time.
Thanks,
DocS
Old January 29th 07, 04:31 PM posted to rec.aviation.homebuilt
Don W
Thanks,
DocS
Be very careful to make sure that the ballast
cannot shift in flight (of course). You may be
required to demonstrate fairly abrupt manuevers
(Stalls, etc) at full gross weight, and any shift
in the ballast location could be fatal.
My suggestion would be to obtain or build a sturdy
box such as a small lockable metal toolbox. The
box can be filled with lead shot bags to bring it
up to any desired weight.
The ballast box(es) should be securely fastened to
the aircraft at the appropriate locations for the
particular flight test.
For example, to simulate flight with a right seat
passenger, you could remove the right seat, and
fasten the ballast box to the seat mounts. You
would then ballast the box to include the weight
of the removed seat plus the maximum intended
passenger weight.
For the luggage compartment, you could use a small
suitcase weighted with lead shot bags, and secured
using luggage straps.
Good luck with it,
Don W.
Old February 4th 07, 03:58 PM posted to rec.aviation.homebuilt
wright1902glider
ballasts?
Ever heard of Tubesand? Nothing more than a 60lb. sandbag that's about
8" dia. and about 30" long. They're made by Quickcrete and sell for
about $3 each at the local BOX store. Availability is regional though,
since they're intended as ballast for us 2WD truck drivers.
Harry
flying low...military video gatt Piloting 60 January 8th 07 01:43 AM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
