Our club is looking at new tow plane. The plane has a Schweizer tow
hook with "1200 lbs max" stamped on it. Does anybody know what that relates to? Is this the max gross weight of the glider or max tow tension or...? I've tried Schweizer, but they couldn't help since they are no longer making tow hooks. Thanks for any insights. Chris |
Chris wrote:
Our club is looking at new tow plane. The plane has a Schweizer tow hook with "1200 lbs max" stamped on it. Does anybody know what that relates to? Max weight of the two pilot? :-) Jeremy |
If you check glider manufacturers weak link requirements as listed in the
respective POH's, you will find almost all are stronger than the maximum lond permitted on a Schweizer tug hook. Overload a Schweizer hook and it jams. To me, that says that all Schweizer tug hooks are dangerously obsolete and should be replaced with Tost hooks - preferably with the tow rope retract winch. Bill Daniels "Chris" wrote in message oups.com... Our club is looking at new tow plane. The plane has a Schweizer tow hook with "1200 lbs max" stamped on it. Does anybody know what that relates to? Is this the max gross weight of the glider or max tow tension or...? I've tried Schweizer, but they couldn't help since they are no longer making tow hooks. Thanks for any insights. Chris |
It is not the max weight of the glider, but the max tension applied to the
hook. That said, the "weak link" should not be stronger than 1200#. It does not take 1200# of "pull" to tow a 1200# glider. Cindy has the formula.. and I'm looking for my reference. BT "Chris" wrote in message oups.com... Our club is looking at new tow plane. The plane has a Schweizer tow hook with "1200 lbs max" stamped on it. Does anybody know what that relates to? Is this the max gross weight of the glider or max tow tension or...? I've tried Schweizer, but they couldn't help since they are no longer making tow hooks. Thanks for any insights. Chris |
Bill's data is a bit skewed. The Discus is probably
the most common single place glider in the U.S. I have flight manuals for both the Discus a and b as well as a Discus 2a and b in front of me. Per the mfg specs both manuals list the minimum weak link as 1157 lbs. His other claim that exceeding the 1200 lb limit will cause the schweizer release to jam is highly suspect. The vast majority of tows in the U.S. are done with schweizer releases with little if any actual complaints by tow pilots. Several years ago in soaring magazine there was an article about a glider kiting and the tow pilot was unable to release. However the cause was not that the schweizer release jammed, it was the result of a poorly installed and secured release cable housing. The cable ties used to secure the release cable housing to the airframe failed, which then resulted in excessive slack in the release cable. This excessive slack meant that the tow pilots release handle was incapable of pulling on the schweizer release lever. At 16:30 30 January 2007, Bill Daniels wrote: If you check glider manufacturers weak link requirements as listed in the respective POH's, you will find almost all are stronger than the maximum lond permitted on a Schweizer tug hook. Overload a Schweizer hook and it jams. To me, that says that all Schweizer tug hooks are dangerously obsolete and should be replaced with Tost hooks - preferably with the tow rope retract winch. Bill Daniels 'Chris' wrote in message roups.com... Our club is looking at new tow plane. The plane has a Schweizer tow hook with '1200 lbs max' stamped on it. Does anybody know what that relates to? Is this the max gross weight of the glider or max tow tension or...? I've tried Schweizer, but they couldn't help since they are no longer making tow hooks. Thanks for any insights. Chris |
OK, I'll accept that a Discus single place glider's minimum weak link
strength is 43 pounds less than the maximum rated strength for a Schweizer hook - but I won't take much comfort from it. A typical 2-seater is a Grob 103 with a reccomended weak link of 1650 pounds. Reccomended weak link strengths range up to 1000 kg force or 2200 pounds force. A common safety factor is 50% which brings it to 3300 pounds or more than 2.5 times the rated strength of the Schweizer hook. I think (but I don't know) the Schweizer hook wouldn't actually break at these loads but I suspect that the manufacturer had a good reason to put a 1200 pound limit on it. You don't size a tow hook for the average glider, you size it for the maximum loads it will see in normal service plus a safety factor. Common sense and good practice says don't exceed it. I'll stand by my advice - get a Tost hook. Bill Daniels "Soarin Again" wrote in message ... Bill's data is a bit skewed. The Discus is probably the most common single place glider in the U.S. I have flight manuals for both the Discus a and b as well as a Discus 2a and b in front of me. Per the mfg specs both manuals list the minimum weak link as 1157 lbs. His other claim that exceeding the 1200 lb limit will cause the schweizer release to jam is highly suspect. The vast majority of tows in the U.S. are done with schweizer releases with little if any actual complaints by tow pilots. Several years ago in soaring magazine there was an article about a glider kiting and the tow pilot was unable to release. However the cause was not that the schweizer release jammed, it was the result of a poorly installed and secured release cable housing. The cable ties used to secure the release cable housing to the airframe failed, which then resulted in excessive slack in the release cable. This excessive slack meant that the tow pilots release handle was incapable of pulling on the schweizer release lever. At 16:30 30 January 2007, Bill Daniels wrote: If you check glider manufacturers weak link requirements as listed in the respective POH's, you will find almost all are stronger than the maximum lond permitted on a Schweizer tug hook. Overload a Schweizer hook and it jams. To me, that says that all Schweizer tug hooks are dangerously obsolete and should be replaced with Tost hooks - preferably with the tow rope retract winch. Bill Daniels 'Chris' wrote in message groups.com... Our club is looking at new tow plane. The plane has a Schweizer tow hook with '1200 lbs max' stamped on it. Does anybody know what that relates to? Is this the max gross weight of the glider or max tow tension or...? I've tried Schweizer, but they couldn't help since they are no longer making tow hooks. Thanks for any insights. Chris |
Bill, I missed where the Grob 103 "recommended" weak link is 1650 lbs.
Our Grob 103 POH does say "max" rating of 1662 lbs. at Max Gross weight of 1279 lbs, perhaps we have different models of the G-103? Based on FARs, 80-200% factor for weak links, that makes it as low as 1032 lbs or as high as 2558 lbs, much higher than Grob recommends. We run a weak link that is "about" 1200 lbs when brand new, after a few flights it is lower from initial use. This allows us to tow most everything on the same weak link material. Yes we have them built up for both Tost and Schweizer rings. Have you seen an approved STC or Form 337 to put a TOST tow assembly on a Pawnee? I would be interested, as our last Schweizer hook wears out. BT "Bill Daniels" bildan@comcast-dot-net wrote in message . .. OK, I'll accept that a Discus single place glider's minimum weak link strength is 43 pounds less than the maximum rated strength for a Schweizer hook - but I won't take much comfort from it. A typical 2-seater is a Grob 103 with a reccomended weak link of 1650 pounds. Reccomended weak link strengths range up to 1000 kg force or 2200 pounds force. A common safety factor is 50% which brings it to 3300 pounds or more than 2.5 times the rated strength of the Schweizer hook. I think (but I don't know) the Schweizer hook wouldn't actually break at these loads but I suspect that the manufacturer had a good reason to put a 1200 pound limit on it. You don't size a tow hook for the average glider, you size it for the maximum loads it will see in normal service plus a safety factor. Common sense and good practice says don't exceed it. I'll stand by my advice - get a Tost hook. Bill Daniels "Soarin Again" wrote in message ... Bill's data is a bit skewed. The Discus is probably the most common single place glider in the U.S. I have flight manuals for both the Discus a and b as well as a Discus 2a and b in front of me. Per the mfg specs both manuals list the minimum weak link as 1157 lbs. His other claim that exceeding the 1200 lb limit will cause the schweizer release to jam is highly suspect. The vast majority of tows in the U.S. are done with schweizer releases with little if any actual complaints by tow pilots. Several years ago in soaring magazine there was an article about a glider kiting and the tow pilot was unable to release. However the cause was not that the schweizer release jammed, it was the result of a poorly installed and secured release cable housing. The cable ties used to secure the release cable housing to the airframe failed, which then resulted in excessive slack in the release cable. This excessive slack meant that the tow pilots release handle was incapable of pulling on the schweizer release lever. At 16:30 30 January 2007, Bill Daniels wrote: If you check glider manufacturers weak link requirements as listed in the respective POH's, you will find almost all are stronger than the maximum lond permitted on a Schweizer tug hook. Overload a Schweizer hook and it jams. To me, that says that all Schweizer tug hooks are dangerously obsolete and should be replaced with Tost hooks - preferably with the tow rope retract winch. Bill Daniels 'Chris' wrote in message egroups.com... Our club is looking at new tow plane. The plane has a Schweizer tow hook with '1200 lbs max' stamped on it. Does anybody know what that relates to? Is this the max gross weight of the glider or max tow tension or...? I've tried Schweizer, but they couldn't help since they are no longer making tow hooks. Thanks for any insights. Chris |
Talk to Tom Knauff, he recently put a Tost on his Pawnee and Scout
"BT" wrote in message ... Bill, I missed where the Grob 103 "recommended" weak link is 1650 lbs. Our Grob 103 POH does say "max" rating of 1662 lbs. at Max Gross weight of 1279 lbs, perhaps we have different models of the G-103? Based on FARs, 80-200% factor for weak links, that makes it as low as 1032 lbs or as high as 2558 lbs, much higher than Grob recommends. We run a weak link that is "about" 1200 lbs when brand new, after a few flights it is lower from initial use. This allows us to tow most everything on the same weak link material. Yes we have them built up for both Tost and Schweizer rings. Have you seen an approved STC or Form 337 to put a TOST tow assembly on a Pawnee? I would be interested, as our last Schweizer hook wears out. BT "Bill Daniels" bildan@comcast-dot-net wrote in message . .. OK, I'll accept that a Discus single place glider's minimum weak link strength is 43 pounds less than the maximum rated strength for a Schweizer hook - but I won't take much comfort from it. A typical 2-seater is a Grob 103 with a reccomended weak link of 1650 pounds. Reccomended weak link strengths range up to 1000 kg force or 2200 pounds force. A common safety factor is 50% which brings it to 3300 pounds or more than 2.5 times the rated strength of the Schweizer hook. I think (but I don't know) the Schweizer hook wouldn't actually break at these loads but I suspect that the manufacturer had a good reason to put a 1200 pound limit on it. You don't size a tow hook for the average glider, you size it for the maximum loads it will see in normal service plus a safety factor. Common sense and good practice says don't exceed it. I'll stand by my advice - get a Tost hook. Bill Daniels "Soarin Again" wrote in message ... Bill's data is a bit skewed. The Discus is probably the most common single place glider in the U.S. I have flight manuals for both the Discus a and b as well as a Discus 2a and b in front of me. Per the mfg specs both manuals list the minimum weak link as 1157 lbs. His other claim that exceeding the 1200 lb limit will cause the schweizer release to jam is highly suspect. The vast majority of tows in the U.S. are done with schweizer releases with little if any actual complaints by tow pilots. Several years ago in soaring magazine there was an article about a glider kiting and the tow pilot was unable to release. However the cause was not that the schweizer release jammed, it was the result of a poorly installed and secured release cable housing. The cable ties used to secure the release cable housing to the airframe failed, which then resulted in excessive slack in the release cable. This excessive slack meant that the tow pilots release handle was incapable of pulling on the schweizer release lever. At 16:30 30 January 2007, Bill Daniels wrote: If you check glider manufacturers weak link requirements as listed in the respective POH's, you will find almost all are stronger than the maximum lond permitted on a Schweizer tug hook. Overload a Schweizer hook and it jams. To me, that says that all Schweizer tug hooks are dangerously obsolete and should be replaced with Tost hooks - preferably with the tow rope retract winch. Bill Daniels 'Chris' wrote in message legroups.com... Our club is looking at new tow plane. The plane has a Schweizer tow hook with '1200 lbs max' stamped on it. Does anybody know what that relates to? Is this the max gross weight of the glider or max tow tension or...? I've tried Schweizer, but they couldn't help since they are no longer making tow hooks. Thanks for any insights. Chris |
there was an article about a glider kiting and the tow pilot was unable to release. However the cause was not that the schweizer release jammed, it was the result of a poorly installed and secured release cable housing. The cable ties used to secure the release cable housing to the airframe failed, which then resulted in excessive slack in the release cable. This excessive slack meant that the tow pilots release handle was incapable of pulling on the schweizer release lever. Many years ago there were tests of Schwiezer releases that showed that they did, indeed jam. These should all be replaced ASAP. Anyone with a brain can look at a Schwiezer release and see why it will jam under high loads. 2c |
wrote in message oups.com... Several years ago in soaring magazine there was an article about a glider kiting and the tow pilot was unable to release. However the cause was not that the schweizer release jammed, it was the result of a poorly installed and secured release cable housing. The cable ties used to secure the release cable housing to the airframe failed, which then resulted in excessive slack in the release cable. This excessive slack meant that the tow pilots release handle was incapable of pulling on the schweizer release lever. Many years ago there were tests of Schwiezer releases that showed that they did, indeed jam. These should all be replaced ASAP. Anyone with a brain can look at a Schwiezer release and see why it will jam under high loads. 2c I'll bite....why will it jam under high loads? |
| Thread Tools | |
| Display Modes | |
| Tow Hook on Cessna 180 - Update | Stuart Grant | Soaring | 13 | April 10th 20 11:48 AM |
| Nose hook addition | Jack | Soaring | 2 | April 29th 06 09:08 AM |
| SZD55 Launch hook info | Sleigh | Soaring | 3 | December 28th 05 09:57 PM |
| Weight Limitation for the Front seats of a C172 | Brad Zeigler | Piloting | 3 | August 15th 05 03:43 AM |
| Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 10:32 PM |
