Now that winter has finally arrived in the Northeast, it is time to enjoy
the benefits of cold, dense air. wow - I wish I could see those climb rates in August. But anyway, what's the common wisdom on preheating. Granted, in an ideal world, preheating is probably a good idea anytime it's below 40, but it IS a pain for those of us who are forced to tie down outside and have no access to electricity. At what temperature point are you comfortable starting WITHOUT a preheat? (If it matters, this is for a Lyc IO360 that will start easily down to about 10 deg). Any mechanics care to comment on what they have seen happen to engines which have routinely been started cold? |
On 1/31/2007 3:31:14 PM, "pgbnh" wrote:
But anyway, what's the common wisdom on preheating. I park my aircraft in an unheated t-hangar in central NY state. Normally, I plug the Tanis heater in when temps get around 40 degrees and I will further wrap the cowling and cover the prop with an insulated cover when temps are forecasted to drop below 25 degrees F or so. Keep in mind, though, that this is a newly overhauled engine and I am simply preserving my investment. ![]() One morning a couple of months ago I arrived at my t-hangar to discover that the plug had somehow pulled out of the socket the previous evening and the engine was at ambient temperature, somewhere around 36 degrees F. I did not have the time to wait the three hours for the Tanis heater to warm the block, so I called my mechanic and asked him if it would hurt the engine to start at that temperature. This mechanic has 40-years in the business, so I trusted him when he told me that there would be no harm in starting above freezing. Being that my engine is a turbonormalized 6 cylinder, it was more important for me to wait until the oil temperature hit 120 degrees before applying full power. 36 degrees to 120 is a lot of idling. Anyway, when I asked him what temperature would be a concern, he opined that when temperatures dip into the upper 20s or lower, preheating becomes important to engine health. Then again, I have seen flight school aircraft started without preheat when temps were around 0 degrees F, but I have also heard of these same engines having stuck valves and other complications, so I wouldn't use that as a guideline. -- Peter |
In article , "pgbnh"
wrote: But anyway, what's the common wisdom on preheating. Granted, in an ideal world, preheating is probably a good idea anytime it's below 40, but it IS a pain for those of us who are forced to tie down outside and have no access to electricity. At what temperature point are you comfortable starting WITHOUT a preheat? (If it matters, this is for a Lyc IO360 that will start easily down to about 10 deg). I use a red dragon preheater. Since I own it I simply take the time and accept the hassle of preheating anytime below 40 degrees. My cherokee 140 starts a lot easier. Doing the preheat was a lot easier when I had a T-hangar, but I still preheat even though I'm on a crappy tie-down. -- Bob Noel Looking for a sig the lawyers will hate |
I believe that Lycoming recommends preheat below 20 degrees to prevent
engine damage.. |
If you are in even an unheated hangar, the OAT and the engine temperature
can be significantly different. On one of our colder days in Tucson when the air outside the hangar was 30, a thermometer showed the head fin temperature to be 45. Of course an aircraft parked outside would have been a different story. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel I'm a uniter, not a divider. - GWB, 1999. "pgbnh" wrote in message ... Now that winter has finally arrived in the Northeast, it is time to enjoy the benefits of cold, dense air. wow - I wish I could see those climb rates in August. But anyway, what's the common wisdom on preheating. Granted, in an ideal world, preheating is probably a good idea anytime it's below 40, but it IS a pain for those of us who are forced to tie down outside and have no access to electricity. At what temperature point are you comfortable starting WITHOUT a preheat? (If it matters, this is for a Lyc IO360 that will start easily down to about 10 deg). Any mechanics care to comment on what they have seen happen to engines which have routinely been started cold? |
Depends on the oil you're using, for one thing. If multi-viscosity, I
wouldn't worry about anything down to 20 or so. Lycoming's web site says 10F is OK, but my IO360 turns over pretty slowly below 20 - that might be from a cold battery, though. I think that a good approach if you live where it's really cold for an extended period is to have both crankcase pad and electric cylinder heater. Plug both into one of those cube taps that turns on when the temp gets below 35F and just leave it on. Moisture does not form if the engine is evenly heated, so wrapping the cowl is helpful, as is wrapping the prop and spinner. |
pgbnh wrote:
Now that winter has finally arrived in the Northeast, it is time to enjoy the benefits of cold, dense air. wow - I wish I could see those climb rates in August. But anyway, what's the common wisdom on preheating. Granted, in an ideal world, preheating is probably a good idea anytime it's below 40, but it IS a pain for those of us who are forced to tie down outside and have no access to electricity. At what temperature point are you comfortable starting WITHOUT a preheat? (If it matters, this is for a Lyc IO360 that will start easily down to about 10 deg). Any mechanics care to comment on what they have seen happen to engines which have routinely been started cold? I plug in my preheater when the temperature is less that 40F. It has about 300 hours on since factory OH. I put a blanket on the cowl and seal the front openings. I also put a drop light on the rudder pedals to let the warm air heat the gyros. My plane is in an unheated hangar. -- Regards, Ross C-172F 180HP KSWI |
We've started our airplanes at ambient temps as low as -25C (-13F) without preheat, but they sure don't like it. We run Aeroshell 15W50, and it gets thick at that temperature. The battery loses most of its cranking power in those conditions. Big dangers: 1. Cranking too long, overheating the starter, maybe burning it out. Just replaced one like that. $460. Give up and go home. 2. Priming too much and too long before cranking. The fuel mists into the intake manifold, but will coalesce onto the manifold walls and run out into the airbox, creating a fire hazard. Priming too much will result in a brief run and stop, frosting those cold sparkplugs and shorting them. Whatever the order of checklist, the prime should happen immediately before start, not three or four items earlier. Remember that the vapor pressure of the fuel is really low when it's cold and won't fire consistently at all. Adding more via the primer doesn't help, it just increases the flooding problem. 3. Too low or too high revs after start. Too low and the oil won't get thrown off the crank into the cylinders. Too high and the pump will cavitate, being unable to suck that thick oil up from the case. Think McDonalds milkshake. 500-700 RPM works for us. I wouldn't even think of starting an engine at those temps if it had W100 in it. 4. Idle it for a long time to get the cylinders warmed up and the oil viscosity down. Taking off on a cold engine is false economy and will soon enough get you, either financially or fatally. Dan |
On Feb 2, 4:09 pm, Rip wrote:
According to Lycoming, an even bigger danger is that, at -10 deg. F, engine tolerances are such that there may be zero, none, nada clearance between important surfaces, like the crankshaft and it's bearings. The aluminum case shrinks more than the steel crank, and one start under those conditions will, not might but will, destroy the engine. Rip Here's Lycoming's take on it: http://www.lycoming.textron.com/main...ldWeather.html I don't see that they warn about destroying the engine. Damaging it certainly is likely if care isn't taken. The aluminum case shrinks at about twice the rate of the steel crank, but the crank's bearings are steel half-circle shells that are in crush (ends butted against each other) in the case bores. They will shrink at the same rate as the crank and prevent the case from binding the crank too much. Bigger danger in cold weather is running the engine too hard before the steel cylinder barrels have warmed up; the aluminum piston can expand enough to cause scuffing as the clearances disappear. Engine shops see that frequently enough. The two-stroke engines in ultralights are particulary fussy that way. IIRC: Coefficient of linear expansion of aluminum is .1244 units per degree F; of steel it's .0655. I'd have to look it up to get it exact. |
| Thread Tools | |
| Display Modes | |
| Cold weather starting. | Mike Noel | Owning | 17 | December 21st 05 04:24 AM |
| Warm Weather Pilots, Cold Weather Ops | john smith | Piloting | 3 | December 2nd 04 05:00 PM |
| Cold Weather Winter Flying Q's | NW_PILOT | Piloting | 20 | November 9th 04 04:32 AM |
| FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 01:07 AM |
| Cold Weather Flying | Jose Vivanco | Owning | 27 | October 16th 03 12:27 PM |
