As I sadly announced a couple of days ago, a friend of ours was killed
in a plane wreck west of Iowa City. He (and a buddy) were ferrying something called a "Spencer Air Car" back from Seattle, for a third- party buyer. According to eye-witnesses, the engine failed. (They had been stuck in Idaho for five days, waiting for parts -- so apparently this plane was giving them some problems along the way.) Here's a picture of a similar plane: http://dougnlinap.home.mindspring.com/Home.html It's basically a homebuilt Republic Seabee, but with one important difference: It's apparently all-wood construction. Looking at the design, I'd say an off-airport landing in anything less than ideal conditions will be fatal, since that big engine and prop is hanging right above and behind your head. Hit anything moderately hard on the ground, and you'll have an O-360 with a pair of Ginsu knives coming right through the cockpit. No one really knows what happened, yet -- and maybe we never will know. But in this plane, if you got slow during an engine-out landing, or tried to pull up over that last fence and stalled, a hard landing that would be survivable in a spam can would result in a very bad day in this particular aircraft. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In a previous article, "Jay Honeck" said:
Looking at the design, I'd say an off-airport landing in anything less than ideal conditions will be fatal, since that big engine and prop is hanging right above and behind your head. Hit anything moderately hard on the ground, and you'll have an O-360 with a pair of Ginsu knives coming right through the cockpit. The other factor with these high engined seaplanes is that if the engine fails, you've got to push the nose down *immediately* because they naturally want to pitch up into an immediate stall. Normal planes have the thrust line a little below the center of drag so that when the thrust is removed it pitches down naturally, but these types of planes have the opposite arrangement. -- Paul Tomblin http://blog.xcski.com/ [Hunt for Red October] also passed the "Is this believable" test. Such as, software that classes unknown sounds as sea animals mating ... -- rwp |
"Jay Honeck" wrote in message
ps.com... party buyer. According to eye-witnesses, the engine failed. (They Here's a picture of a similar plane: http://dougnlinap.home.mindspring.com/Home.html It's basically a homebuilt Republic Seabee, but with one important difference: It's apparently all-wood construction. Looking at the design, I'd say an off-airport landing in anything less than ideal conditions will be fatal, since that big engine and prop is What happened is yet to be determined and I won't comment on the accident itself. I'm responding to Jay's comments in general. An off-airport landing is quite doable and probably more survivable in an amphibious flying hull, pusher design. First, if the engine has stopped, then the prop is just another hunk of metal. The design of the Seabee has the engine mounted pretty low and pretty solidly. It's not going to simply slide forward dragging the spinning prop through the cabin. Plus, since the hull is designed to take the punishment of a water landing in waves, it tends to be beefier than the typical land plane. Wood construction or not, it has to be solid enough to take a water landing. Land it gear up in a field and there will be very little damage to repair. ------------------------------- Travis Lake N3094P PWK |
Republic SeeBees (basically the same airplane) had a bad record with
inflight fires. A friend bought one back in the late 70's. He was aware of the problems and checked everything. Had it less than a month when his caught fire. He set it down and walked away, but the aircraft was a total loss. |
amphibious flying hull, pusher design. Agreed. And the fact that we've got a nice blanket of snow around here (albeit frozen solid, with high temperatures barely above zero) *should* have made it even easier. Blane was an experienced CFII, who was taught to fly by his dad in a Pietenpol. He was a real stick and rudder guy, who (according to friends who flew with him) during BFRs always stressed off-airport landing survivability. Therefore, many in our local pilot community are leaning toward something other than a simple engine failure as a cause of this tragedy. Blane was just too experienced, and the terrain was just too benign, for this to have been a simple "engine out -- glide into a field and walk away" scenario. But, again, we may never know. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
("Jay Honeck" wrote)
Here's a picture of a similar plane: http://dougnlinap.home.mindspring.com/Home.html It's basically a homebuilt Republic Seabee, but with one important difference: It's apparently all-wood construction. (Great site) http://www.seabee.info/ "The unique Seabee amphibian was a product of legend aircraft designer Percival H. Spencer selling his Air Car design to Republic Aviation Corporation, to be their contribution for the expected post WW2 booming personal airplane market." (Great site) http://www.seabee.info/seabee.htm Look under Timeline: "After the USA is at war, from the Pearl Harbor attack on 1941-12-07, Spence put the Air Car in storage and starts working with Republic Aviation Corporation as a test pilot on their P-47 Thunderbolt fighters." Homebuilt project: http://www.whitealbatross.com/plane/DPAIRCAR.html "The following chapters are a basic attempt to re-document almost ten years and over 7500+ hours of building, I have had a lot of encouragement and positive feedback about this website. But the truth is I really prefer NOT to spend the free time at the computer." 7,500+ hours ...what free time??? Montblack Add an hour, I just now spent on his website, to that total. :-) |
"Jay Honeck" wrote Looking at the design, I'd say an off-airport landing in anything less than ideal conditions will be fatal, since that big engine and prop is hanging right above and behind your head. Hit anything moderately hard on the ground, and you'll have an O-360 with a pair of Ginsu knives coming right through the cockpit. That could be said of many, many amphibious designs, as far as getting an engine in the back of your head. This time, the Ginsu knives were not running, though. -- Jim in NC |
| Flying on the Cheap - Instruments | [email protected] | Home Built | 24 | February 27th 06 03:30 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 02:54 AM |
| Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 09:48 PM |
| ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 05:30 AM |
