North Aire floats.
Old February 4th 07, 06:43 PM posted to rec.aviation.homebuilt
Fortunat1[_8_]
Default North Aire floats.
Anyone have experience with these? Wag Aero are selling plans for these
still. Anyone know of their history? were they always a homebuilt design?
Are they compartmentalised like Edos? Performance? ease of building,
expense?
TIA!
F1
Old February 4th 07, 11:04 PM posted to rec.aviation.homebuilt
Drew Dalgleish
expense?
TIA!
F1
They're not very big. Only about 1400# IIRC what are you putting them
on?
Old February 5th 07, 03:34 AM posted to rec.aviation.homebuilt
Morgans
"Fortunat1" wrote
Big enough, Junior Ace or Cub... Off the top of my head Wag Aero
mentioned up to 1500..
I'm not too enthusiastic about wood floats and I would like to scratch
build them as opposed to going for one of the (expensive) foam options
or the even more expensive second hand edo option..
Why is it that you are not enthusiastic about wood floats? Something about
using them, or building them?
Jim in NC
Old February 5th 07, 05:20 PM posted to rec.aviation.homebuilt
Fortunat1
"Morgans" wrote in
scratch build them as opposed to going for one of the (expensive)
foam options or the even more expensive second hand edo option..
about using them, or building them?
Well, I imagine that metal floats might be more maintenence free and
easier to repair, not to mention more impervious to getting water
logged. having said that, I don't know enough about either to make an
informed decision there, but more than that I just want to try something
in sheet metal, never having made more than cowlings and covers out of
the stuff before..
Old February 5th 07, 09:29 PM posted to rec.aviation.homebuilt
Morgans
the stuff before..
Understood...
Although, metal corrodes, especially in sal****er.
Wood does not. It also does not matter to wood one little bit if the water
is salt or fresh.
Wood boat has been done for many years. Epoxy coatings make wood
practically immune to rot. Some also use wood as a core, and a very thin
fiberglass coating inside and out to protect the wood. Some of the best
looking and best performing homebuilts are built that way.
You have to follow your own heart with a material choice, of course, but
don't write off wood. I have never looked for wood float plans, and don't
know how well they hold up, or how heavy they turn out.
It does sound interesting, enough so that I may poke around a little, now
that my interest has be peaked! g
Jim in NC
Old February 5th 07, 03:32 AM posted to rec.aviation.homebuilt
Morgans
on?
Dang, those are some heavy floats!!! g
Really though, if you are talking about how much gross weight they will
handle, that fits very nicely for the LSA, don't you think?
Jim in NC
Old February 5th 07, 06:53 AM posted to rec.aviation.homebuilt
John P Kimmel
expense?
TIA!
F1
I have the drawings, they have water tight compartments. They are built
a lot like Edos or Wiplines or PeeKays, except whithout the fluted
bottoms. They are definitely not for sheetmetal beginners. They
also look extremely heavy. If you want metal kit floats, I recommend
Zeniths based on having seen a set under construction. I'll sell you my
drawings for half of whatever Wag-Aero's selling theirs for, if you want
to look at them.
John Kimmel
GET YER STINKING PAWS OFF ME YOU DAMN DIRTY APE!
Old February 5th 07, 04:53 PM posted to rec.aviation.homebuilt
Fortunat1
John P Kimmel wrote in
these still. Anyone know of their history? were they always a
homebuilt design? Are they compartmentalised like Edos? Performance?
ease of building, expense?
TIA!
F1
built a lot like Edos or Wiplines or PeeKays, except whithout the
fluted bottoms. They are definitely not for sheetmetal beginners.
Ok, that's a bit discouraging since I've done very little riveting.
They also look extremely heavy.
Mm, don't want that either...
recommend Zeniths based on having seen a set under construction. I'll
sell you my drawings for half of whatever Wag-Aero's selling theirs
for, if you want to look at them.
Well, I wanted to build them from scratch. Do no harm to look at the
North Aire drawings to see what I might see. I'll drop you a line OK?
Iran is preparing for an underground nuclear test with North Korean help before year's end AirRaid Mach 2.5 Naval Aviation 19 March 19th 07 04:21 AM
Air Ops North Atlantic - Ron Knott Greasy Rider© @invalid.com Naval Aviation 1 June 4th 05 06:52 PM
Death On The North Sea Gunnery Range Keith Willshaw Military Aviation 38 August 14th 04 07:19 PM
N. Korea Agrees to Nuke Talks Dav1936531 Military Aviation 1 August 2nd 03 06:53 AM
North Island completes 5-year Spanish F/A-18 program Otis Willie Naval Aviation 0 July 11th 03 09:26 PM
