I hate turn coordinators
Old February 4th 07, 08:11 PM posted to rec.aviation.ifr
john hawkins
Default I hate turn coordinators
Why is the turn coordinator so popular? I find the presentation similar to
the artificial horizon is poor. The good old turn needle never leads to any
confusion. If the silly little airplane was replaced by a needle and dog
houses, I think I'd like it better. The 4 minute needle gives superior turn
rate information so you can more easily make standard of half standard rate
turns. The Turn Coordinator's ability to sense both yaw and roll doesn't
seem to be of much value to me. Overhaul Prices are higher for the TC.
While I'm at it, how about venturi tube suction. Put a heater on them so
they won't ice up and you no longer have to worry about a failing vacuum
pump. Add one as an emergency vacuum source.
Grump. Grump.
Oh well. Both are being replaced by Electronic Primary Flight Display
(Though I'll never be able to afford them)
Old February 4th 07, 09:03 PM posted to rec.aviation.ifr
Tauno Voipio
There's a difference: a needle-in-the-doghouse indicator
feels turn rate only, but a turn coordinator senses
additionally some of the roll rate to respond quicker.
Grump. Grump.
Me too - but would like to.
Tauno Voipio (PA28RT201T, OH-PYM)
tauno voipio (at) iki fi
Old February 4th 07, 11:47 PM posted to rec.aviation.ifr
Jim Macklin
The TC will run a wing leveler autopilot.
"john hawkins" wrote in message
hlink.net...
never leads to any
needle and dog
gives superior turn
half standard rate
and roll doesn't
for the TC.
heater on them so
failing vacuum
| Grump. Grump.
Flight Display
Old February 5th 07, 12:11 AM posted to rec.aviation.ifr
Ron Natalie
Which is the only reason I have one. I had a needle-ball
gauge until I put in the STEC autopilot. I think the TC
was just one of those things that people thought were a
cool idea in the 70's that turned out not to be all it was
cracked up to be.
Old February 5th 07, 01:31 AM posted to rec.aviation.ifr
Mitty
IIRC they were invented by Brittain (sp?) specifically to provide an input to
their wing levelers and, I suppose, autopilots.
On 2/4/2007 6:11 PM, Ron Natalie wrote the following:
cracked up to be.
Old February 5th 07, 02:06 AM posted to rec.aviation.ifr
Sam Spade
cracked up to be.
That would be my assessment.
Alas, some airlines hated to maintain anything they didn't absolutely
have to, so carrier TWx had their turn-and-bank indicators removed from
their 727s once they gained federal approval. There was a tiny ball
under the attidue indicator that was supposed to be "good enough" for
engine failures.
Old February 6th 07, 05:20 PM posted to rec.aviation.ifr
Michael[_1_]
On Feb 4, 6:11 pm, Ron Natalie wrote:
I think the TC
cracked up to be.
Try flying a slippery, fast, not-terribly-roll-stable airplane in
turbulent IMC on a T&S, and you will quickly change your mind. The TC
is a good idea. Not as good as a backup AI, and there is now an AC
that allows you to remove the TC (or T&S) from your airplane if you
replace it with a second AI powered from a different system than the
primary AI.
I seem to recall you fly a Navion. I've flown one. They're VERY
stable. You can keep the wings level in turbulent IMC with a T&S in a
Navion. I suspect you could probably do it with just a compass. I
know it can be done in the TriPacer on just a compass.
It's nearly impossible to keep the wings level in turbulent IMC in
something like a Bonanza, a late model Mooney, or my Twin Comanche if
all you have is a T&S. That's why your autopilot doesn't use one. By
the time you have started to actually turn (developed a yaw rate, the
only thing the T&S can sense) you already have too much roll rate
going. The TC will respond to roll rate, and that makes all the
difference.
Having actually lost my attitude gyro in turnulent night IMC in my
Twin Comanche, I am really glad I had the TC and not a T&S.
A good rule of thumb for determining if your plane really needs a TC
rather than a T&S - if, when doing partial panel work with a wet
compass and no moving map, you find you miss the HI more than the AI,
you don't need the T&S. Your plane is stable enough. If you miss the
AI more, you need a TC.
Michael
Old February 6th 07, 09:19 PM posted to rec.aviation.ifr
On Feb 6, 9:20 am, "Michael"
... and there is now an AC
primary AI.
Michael
Even knowing this, when the DE asked for required equipment for IFR
flight, I still included the TC (second R in grabcard).
ak.
Old February 7th 07, 03:47 AM posted to rec.aviation.ifr
Frank Stutzman
difference.
I own a Bonanza. I fly the Oregon/Washington Cascade mountains on a
regular basis, especially in the summer. It has a T&S. I'm not God's
gift to aviation, but the T&S does fine for me.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old February 7th 07, 06:39 PM posted to rec.aviation.ifr
Michael[_1_]
Maybe it does. If you have actually had a total attitude gyro failure
in turbulent IMC and actually had to complete an IFR-in-IMC instrument
approach in turbulent IMC with just the T&S, then I believe you - and
you're a better man than I am.
If this has not actually happened, I think you are kidding yourself.
It's a whole lot easier under the hood.
Michael
Even during sentencing, this guy is an a*hole H.P. Piloting 45 March 14th 06 11:36 PM
Procedure turn required? Yossarian Piloting 85 July 6th 05 08:12 PM
Procedure turn required? Peter Duniho Instrument Flight Rules 80 July 6th 05 08:12 PM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 01:03 AM
