Gettin' a bit confused here. (nothing new in that)
In the big sprawling thread I started down below, there's been a couple of themes that have come up. One is that I am pretty sure that for the same IAS (not TAS) at a higher altitude, more power is required. However, one contributor to the thread has stated that this is not the case:- "Power is net force time velocity. Thrust equals drag, net force is zero. The energy change of the airframe overtime is zero. All energy from the engine is going into the air. The power to move air to make the same thrust is the same regardless of velocity. Same IAS, same engine power requirement. Look at some aircraft performance charts." I'd always understood that power = thrust x velocity, hence the deduction that it requires more power to go the same IAS at a higher alt. At the same IAS the drag and hence the thrust is the same. Plug that into the equation and you get the power required, which is more because TAS is higher at altitude. As for aircraft performance charts, they're for the most part in TAS, not IAS. However, the same author as the snippet above says:- "The statement that power is drag time velocity is incorrect." Is it? I've seen that formula mentioned in almost every text on power that I've seen. Is there something I'm missing? Not trying to be a PITA, just seeking clarification of something I was sure was right. And I know that operationally TAS is much more important than IAS except for, say, stall speed, best glide and the like. So it's a largely an academic question, I realise. It was (sort of) started as a way of finding a plain language non-mathematical explanation for the question "why does the same IAS require more power at altitude?". I haven't found that plain language explanation yet, but now I'm getting conflicting answers as to the very definition of power. Can someone clear it up? TIA! |
"xerj" wrote
One is that I am pretty sure that for the same IAS (not TAS) at a higher altitude, more power is required. However, one contributor to the thread has stated that this is not the case:- Based on actual performance data for a Seneca II you are correct: 6000 ft 75% power (2400 rpm/32-in mp/26.3 gph) IAS 157 kts TAS 170 kts 16000 ft 75% power (2400 rpm/29.4-in mp/26.3 gph) IAS 148 kts TAS 187 kts BDS |
"BDS" wrote in message t... "xerj" wrote One is that I am pretty sure that for the same IAS (not TAS) at a higher altitude, more power is required. However, one contributor to the thread has stated that this is not the case:- Based on actual performance data for a Seneca II you are correct: 6000 ft 75% power (2400 rpm/32-in mp/26.3 gph) IAS 157 kts TAS 170 kts 16000 ft 75% power (2400 rpm/29.4-in mp/26.3 gph) IAS 148 kts TAS 187 kts BDS Thanks for the information. Danny Deger |
altitude, more power is required. However, one contributor to the thread has stated that this is not the case:- Based on actual performance data for a Seneca II you are correct: 6000 ft 75% power (2400 rpm/32-in mp/26.3 gph) IAS 157 kts TAS 170 kts 16000 ft 75% power (2400 rpm/29.4-in mp/26.3 gph) IAS 148 kts TAS 187 kts BDS Thanks for posting the excerpt. It's concise, and also gives a "feel" for the magnetude of the effect. Peter |
"BDS" wrote in message t... 6000 ft 75% power (2400 rpm/32-in mp/26.3 gph) IAS 157 kts TAS 170 kts 16000 ft 75% power (2400 rpm/29.4-in mp/26.3 gph) IAS 148 kts TAS 187 kts How come those are both 75% power? The high-altitude one seems like a richer mixture, less power. |
"Stan Prevost" wrote in message ... "BDS" wrote in message t... 6000 ft 75% power (2400 rpm/32-in mp/26.3 gph) IAS 157 kts TAS 170 kts 16000 ft 75% power (2400 rpm/29.4-in mp/26.3 gph) IAS 148 kts TAS 187 kts How come those are both 75% power? The high-altitude one seems like a richer mixture, less power. Less back pressure at altitude, less MP required for the same %power. Note the fuel burn is the same. Al G |
On Mon, 05 Feb 2007 02:18:26 GMT, "xerj" wrote:
Gettin' a bit confused here. (nothing new in that) In the big sprawling thread I started down below, there's been a couple of themes that have come up. One is that I am pretty sure that for the same IAS (not TAS) at a higher altitude, more power is required. However, one contributor to the thread has stated that this is not the case:- That would be true, but probably not doable. Besides at altitude you fly a much lower IAS with out trying to boost the power. You fly at a lower IAS due to lower air density at the higher altitudes which is also the reason for the wider spread between IAS and TAS. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
"xerj" wrote in message ... Gettin' a bit confused here. (nothing new in that) In the big sprawling thread I started down below, there's been a couple of themes that have come up. One is that I am pretty sure that for the same IAS (not TAS) at a higher altitude, more power is required. However, one contributor to the thread has stated that this is not the case:- "Power is net force time velocity. Thrust equals drag, net force is zero. The energy change of the airframe overtime is zero. All energy from the engine is going into the air. The power to move air to make the same thrust is the same regardless of velocity. Same IAS, same engine power requirement. Look at some aircraft performance charts." I'd always understood that power = thrust x velocity, hence the deduction that it requires more power to go the same IAS at a higher alt. At the same IAS the drag and hence the thrust is the same. Plug that into the equation and you get the power required, which is more because TAS is higher at altitude. As for aircraft performance charts, they're for the most part in TAS, not IAS. I found an aircraft performance chart and I stand corrected. At 75% power the aircraft flies 140 TAS at sea level and 150 TAS at 8K feet. This is 140 IAS at sea level and 124 IAS as 8K feet. I am very surpprised, because I always thought you would get the same IAS for the same power. So for the same power, the IAS is less at altitude. I do know that the calculations from engine power to thrust and power effect to the overall system is more of an art than I science. I do stand by my statement that for the purpose of using the fact that force times velocity is power , it is not correct to say trust times velocity is power. The net force on the airframe is zero, thrust equals drag so net force is zero. All of the energy is going into the air, not the airframe. But it looks like due to the higher velocity of the airstream at altitude (higher TAS) the power requirement to move the air for a given IAS is greater. Keep in mind the energy/power from the engine is going into moving the air, not accelerating the airframe. As an example of the problem of using thrust time velocity as power, calculate the power being generated by engines doing a runup on the runway before takeoff. Velocity is zero, thus "power" is zero. The equation brakes down. Live and learn though. IAS does drop with altitude for the same power out of the engine. This effect may be one reason jets are inherently faster at altitude. While thrust of a jet does drop with altitude, this drop is not as bad on aircraft speed as the drop in power in a piston or turbo prop. Thanks xerj. Even on old engineer can learn a few new things :-) Danny Deger However, the same author as the snippet above says:- "The statement that power is drag time velocity is incorrect." Is it? I've seen that formula mentioned in almost every text on power that I've seen. Is there something I'm missing? Not trying to be a PITA, just seeking clarification of something I was sure was right. And I know that operationally TAS is much more important than IAS except for, say, stall speed, best glide and the like. So it's a largely an academic question, I realise. It was (sort of) started as a way of finding a plain language non-mathematical explanation for the question "why does the same IAS require more power at altitude?". I haven't found that plain language explanation yet, but now I'm getting conflicting answers as to the very definition of power. Can someone clear it up? TIA! |
Danny Deger wrote: I found an aircraft performance chart and I stand corrected. At 75% power the aircraft flies 140 TAS at sea level and 150 TAS at 8K feet. This is 140 IAS at sea level and 124 IAS as 8K feet. I am very surpprised, because I always thought you would get the same IAS for the same power. Every pilot is taught that in private pilot training. Those of us that live at higher altitudes really know this because we deal with reduced power every day. |
"Newps" wrote in message . .. Danny Deger wrote: I found an aircraft performance chart and I stand corrected. At 75% power the aircraft flies 140 TAS at sea level and 150 TAS at 8K feet. This is 140 IAS at sea level and 124 IAS as 8K feet. I am very surpprised, because I always thought you would get the same IAS for the same power. Every pilot is taught that in private pilot training. Those of us that live at higher altitudes really know this because we deal with reduced power every day. I remember being taught that TAS would be higher at altitude, but don't remember what was said about IAS for a given power level as you climb. Most cruise charts just have TAS (IIRC). I moved to jets in the Air Force and for the same engine thrust the IAS is the same for any altitude in a jet. Like I said, live and learn. That one reason I frequent this group. Danny Deger |
