Cloud Flying - Experimental
Old February 5th 07, 07:37 PM posted to rec.aviation.soaring
Default Cloud Flying - Experimental
Does anyone know of any Experimental - Amateur Built gliders that have
operating limitations which allow cloud flying with a Turn and Bank?
Does anyone know what many type certified designs (Schweizer 1-34
comes to mind) had to prove to be allowed to cloud fly with a Turn and
Bank installed? I have a copy of the Basic Glider Criteria Handbook
in the mail, perhaps that will provide some insight into this
question.
Shawn Knickerbocker will be presenting on cloud flying at the SSA
convention on thursday. From visiting with Shawn, it should be a
fantastic presentation and I hope to see you all there!
Old February 5th 07, 07:57 PM posted to rec.aviation.soaring
Bill Daniels
My Nimbus 2C does. It's expressly stated in the POH and the certification
(Experimentat EX&R)
Of course, getting the proper logbook signoffs for a "gyro panel" is
somethng else.
Bill Daniels
question.
Old February 5th 07, 08:40 PM posted to rec.aviation.soaring
Tim Taylor
(Experimentat EX&R)
somethng else.
Bill Daniels
But the real question is would you want to fly a Nimbus 2 in those
conditions? Mine was a handful in a spin, not sure I would want to
try it in IMC.
Tim
Old February 5th 07, 09:22 PM posted to rec.aviation.soaring
Bill Daniels
Hmm, Mine says "Spins prohibited". However, with the fixed stab, it's a
very stable, spin resistent platform so I don't see why not. Most of the
airplanes I flew IMC were "Spin prohibited" too - never spun one IMC.
Bill Daniels
"Tim Taylor" wrote in message
certification
(Experimentat EX&R)
somethng else.
Bill Daniels
try it in IMC.
Tim
Old February 5th 07, 11:19 PM posted to rec.aviation.soaring
Bill Daniels
certification
(Experimentat EX&R)
somethng else.
Bill Daniels
try it in IMC.
Tim
yea the experimental exhibition and racing is different as it has a
POH which allows cloud flying. With amatuer built I must somehow
prove that it is safe to take the glider into clouds. Finding the
standards to prove it against has proven difficult, but I got my copy
of the Basic Glider Criteria handbook and it is looking promising.
Funny how pure glider pilots seem to think that any encounter with
clouds must result in an immediate loss of control. Properly
instrumented and most importantly, properly trained, it really is no
problem. Twins, Airliners, and even many single engine planes that
are not certified for spins fly in IMC every day with no problems.
Old February 5th 07, 11:43 PM posted to rec.aviation.soaring
news.nildram.co.uk
The issue isn't spinning. In fact, holding the glider in a spin may well be
the best way of exiting a cloud after losing control. Even if the glider
isn't cleared for spinning there's a good chance you won't have a problem if
you carry out a proper spin recovery once you are well clear of the cloud.
The real danger is the combination of over-speeding and simultaneously
pulling excessive g in an attempt to recover control of the glider while
there is no pitch reference.
David Starer
Bill Daniels
certification
(Experimentat EX&R)
somethng else.
Bill Daniels
try it in IMC.
Tim
Old February 5th 07, 11:45 PM posted to rec.aviation.soaring
David Starer
David Starer
Bill Daniels
certification
(Experimentat EX&R)
somethng else.
Bill Daniels
try it in IMC.
Tim
Old February 6th 07, 03:11 AM posted to rec.aviation.soaring
Eric Greenwell
"Glider only" ratings, you mean? Usually, "pure" means no motor in the
glider.
Kind of begs the question, doesn't? "You won't have problems if you do
everything right".
it really is no
problem.
Turbulence, icing, lightning, hypoxia, other gliders and airplanes - no
problem?
How much thermalling near stall do they do ;) ? And isn't flight into
IMC where lots of those single engine planes have the most problems?
I'm looking forward to Shawn's presentation at the convention. I've read
many of the stories from the older Sailplane and Gliding magazines about
cloud flight back before GPS, and it sounded like a quite an adventure.
I particularly enjoyed the ones that had sentences like this: "As I
exited the cloud at 14,000', I looked down to see nothing but water...".
Usually meant the English Channel. Not a happy place in a 30:1 glider
with iced up wings.
* "Transponders in Sailplanes"
http://tinyurl.com/y739x4
Old February 6th 07, 01:41 PM posted to rec.aviation.soaring
Derek Copeland
Most gliders are certified for cloud flying in the
UK, but then we have much more cloud than most countries.
I used to own a Nimbus 2 (all flying tailplane version)
and cloud climbed it on a number of occasions without
difficulty, using an artificial horizon and a turn
and slip indicator. However I had been trained to blind
fly in light aircraft first. Don't do it without getting
some training first! Also don't circle within 10 knots
of the stall speed in cloud.
Derek Copeland
(Experimentat EX&R)
a 'gyro panel' is
somethng else.
Bill Daniels
2 in those
I would want to
try it in IMC.
Tim
Old February 6th 07, 03:42 PM posted to rec.aviation.soaring
Ian Cant
Tony,
I think we'd all agree that with sensible
speed control and suitable instruments, then inadvertent
spinning is not very likely or even particularly dangerous.
However, before going into that cloud I'd think twice
about other things - other gliders doing the same thing,
other power traffic flying IFR, and the possible violence
of the turbulence. Using a nice little isolated summer
CU or descending through a thin high layer is one kind
of situation, entering a large CuNim or extensive stratus
near the deck would be quite another. The FAA's opinion
in a day-VFR-only Experimental might also influence
your decisions.
Good luck,
Ian
Derek Copeland
(Experimentat EX&R)
a 'gyro panel' is
somethng else.
Bill Daniels
2 in those
I would want to
try it in IMC.
Tim
Some flying vids I made... [email protected] Piloting 40 January 31st 07 10:11 PM
Cloud Flying Shawn Knickerbocker Soaring 0 August 26th 06 03:27 PM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
the thrill of flying interview is here! Dudley Henriques Piloting 0 October 21st 03 07:41 PM
