Last week, in -22 temperatures, our nose gear drooped all the way to
the stop. Later, we were able to put some down pressure on the stabilator (in the hangar) and bring it back up a couple of inches, but made plans to have our A&P look at it. Yesterday, since he wasn't coming in the shop till afternoon, we decided to go flying first. My landing in Oskaloosa, IA (KOOA) was gingerly -- a text book soft field landing, with the nose gear staying high in the air till almost stopped. The strut stayed up around three inches all the way to parking. The temperature was about 5 above zero, and I thought that perhaps this had been a transient problem that had "fixed itself". (We always hope, no? :-) Not. Mary's landing back in Iowa City was fine, but the strut again collapsed to the stop -- so we taxied straight to the shop. My A&P told me that he could "service" it (basically, add air), but after some discussion we decided to replace the seals in the strut. He said that the O-rings were likely old (we hadn't replaced them in the 5 years we've owned Atlas), stiff, and perhaps "rolled", so that even though lubricating the strut and adding air might do the trick for a while, it would be a stop-gap measure, at best. I helped him do it, and it took about an hour. (Of course, he's done it a million times -- the job would have taken me all day, with instructions, and I might have killed myself doing it.) But now, the strut is sitting tall again, with new fluids, O-rings, and air pressure. Total: $65. Not bad at all, in aviation terms... He says that it's SOP to apply brake fluid to the struts of the DC-9s he services (at his day job) every, single time they park. It's messy, as a result, but their strut seals rarely need to be replaced. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Feb 8, 8:32 am, "Jay Honeck" wrote:
Last week, in -22 temperatures, our nose gear drooped all the way to the stop. Later, we were able to put some down pressure on the stabilator (in the hangar) and bring it back up a couple of inches, but made plans to have our A&P look at it. Yesterday, since he wasn't coming in the shop till afternoon, we decided to go flying first. My landing in Oskaloosa, IA (KOOA) was gingerly -- a text book soft field landing, with the nose gear staying high in the air till almost stopped. The strut stayed up around three inches all the way to parking. The temperature was about 5 above zero, and I thought that perhaps this had been a transient problem that had "fixed itself". (We always hope, no? :-) Not. Mary's landing back in Iowa City was fine, but the strut again collapsed to the stop -- so we taxied straight to the shop. My A&P told me that he could "service" it (basically, add air), but after some discussion we decided to replace the seals in the strut. He said that the O-rings were likely old (we hadn't replaced them in the 5 years we've owned Atlas), stiff, and perhaps "rolled", so that even though lubricating the strut and adding air might do the trick for a while, it would be a stop-gap measure, at best. I helped him do it, and it took about an hour. (Of course, he's done it a million times -- the job would have taken me all day, with instructions, and I might have killed myself doing it.) But now, the strut is sitting tall again, with new fluids, O-rings, and air pressure. Total: $65. Not bad at all, in aviation terms... He says that it's SOP to apply brake fluid to the struts of the DC-9s he services (at his day job) every, single time they park. It's messy, as a result, but their strut seals rarely need to be replaced. Problem there is the attraction of dust, which then fouls the scraper ring and eventually gets under the O-ring and abrades it. We keep ours just wiped off. The cold weather makes the O-rings shrink and grab the strut barrel, and then they roll in the groove and because their flexibility is gone in the cold, they suffer spiral fractures. It's good practice to replace them regularly. Granville Strut Seal added to the fluid will sometimes help by swelling the ring slightly and making it a bit softer. There are far better O-rings out there now. I wish someone like McFarlane would come up with an STC'd oleo kit that used fluorosilicone or EPDM or some other advanced compound rings. Tougher and with a better temperature range. There are "quad" O-rings available, too, that would do a better job. In cross-section they look like a four-leaf clover, so there's more contact area on two places and they are more flexible, too. Double the sealing capacity, and resistant to rolling. Dan |
![]() wrote in message ups.com... On Feb 8, 8:32 am, "Jay Honeck" wrote: Last week, in -22 temperatures, our nose gear drooped all the way to the stop. Later, we were able to put some down pressure on the stabilator (in the hangar) and bring it back up a couple of inches, but made plans to have our A&P look at it. Yesterday, since he wasn't coming in the shop till afternoon, we decided to go flying first. My landing in Oskaloosa, IA (KOOA) was gingerly -- a text book soft field landing, with the nose gear staying high in the air till almost stopped. The strut stayed up around three inches all the way to parking. The temperature was about 5 above zero, and I thought that perhaps this had been a transient problem that had "fixed itself". (We always hope, no? :-) Not. Mary's landing back in Iowa City was fine, but the strut again collapsed to the stop -- so we taxied straight to the shop. My A&P told me that he could "service" it (basically, add air), but after some discussion we decided to replace the seals in the strut. He said that the O-rings were likely old (we hadn't replaced them in the 5 years we've owned Atlas), stiff, and perhaps "rolled", so that even though lubricating the strut and adding air might do the trick for a while, it would be a stop-gap measure, at best. I helped him do it, and it took about an hour. (Of course, he's done it a million times -- the job would have taken me all day, with instructions, and I might have killed myself doing it.) But now, the strut is sitting tall again, with new fluids, O-rings, and air pressure. Total: $65. Not bad at all, in aviation terms... He says that it's SOP to apply brake fluid to the struts of the DC-9s he services (at his day job) every, single time they park. It's messy, as a result, but their strut seals rarely need to be replaced. Problem there is the attraction of dust, which then fouls the scraper ring and eventually gets under the O-ring and abrades it. We keep ours just wiped off. The cold weather makes the O-rings shrink and grab the strut barrel, and then they roll in the groove and because their flexibility is gone in the cold, they suffer spiral fractures. It's good practice to replace them regularly. Granville Strut Seal added to the fluid will sometimes help by swelling the ring slightly and making it a bit softer. There are far better O-rings out there now. I wish someone like McFarlane would come up with an STC'd oleo kit that used fluorosilicone or EPDM or some other advanced compound rings. Tougher and with a better temperature range. There are "quad" O-rings available, too, that would do a better job. In cross-section they look like a four-leaf clover, so there's more contact area on two places and they are more flexible, too. Double the sealing capacity, and resistant to rolling. Dan If I had a certified airplane and knew of better O-rings out there, it wouldn't surprise me if the hangar elves (elfs?) mysteriously installed a set of the improved O-rings. I, of course, would never do such a thing on a certified airplane, but mysterious things sometimes happen behind closed hangar doors. Fortunately, I have an experimental aircraft and can install whatever O-rings I want... KB |
![]() .lots of stuff snipped There are far better O-rings out there now. I wish someone like McFarlane would come up with an STC'd oleo kit that used fluorosilicone or EPDM or some other advanced compound rings. Tougher and with a better temperature range. There are "quad" O-rings available, too, that would do a better job. In cross-section they look like a four-leaf clover, so there's more contact area on two places and they are more flexible, too. Double the sealing capacity, and resistant to rolling. Dan Cherokee strut seals are quad 0-rings (or at least they are square-ish). Typically they last 20+ years and start to leak fluid. That can continue for many years. When I replaced all mine, the nose immediately started leaking. Took 2-4 days to deflate. After a couple of ounces of Granville, it stopped. Not sure if we bunged up the install or the ring had a defect. Still up after a year. Oddly, I thought the new seals would make the struts move more freely. That was not the case with mine. They still have a healthy amount of "stick". Good luck, Mike |
![]() "Mike Spera" wrote in message link.net... .lots of stuff snipped There are far better O-rings out there now. I wish someone like McFarlane would come up with an STC'd oleo kit that used fluorosilicone or EPDM or some other advanced compound rings. Tougher and with a better temperature range. There are "quad" O-rings available, too, that would do a better job. In cross-section they look like a four-leaf clover, so there's more contact area on two places and they are more flexible, too. Double the sealing capacity, and resistant to rolling. Dan Cherokee strut seals are quad 0-rings (or at least they are square-ish). Typically they last 20+ years and start to leak fluid. That can continue for many years. When I replaced all mine, the nose immediately started leaking. Took 2-4 days to deflate. After a couple of ounces of Granville, it stopped. Not sure if we bunged up the install or the ring had a defect. Still up after a year. Oddly, I thought the new seals would make the struts move more freely. That was not the case with mine. They still have a healthy amount of "stick". Good luck, Mike I hate that in a piper when a strut sticks and 1/2 your landing roll is lop sided! |
![]() Oddly, I thought the new seals would make the struts move more freely. That was not the case with mine. They still have a healthy amount of "stick". Try smearing STP (Moto-Honey to some.....) on the exposed strut. It helps elastomeric seals break in - even to the point that it will migrate into the strut interior. Don't laugh - I have done this on hydraulic actuators to temporarily reduce the rod friction in a cyclic applications. It was absolutely amazing what it would do with the effects lasting for maybe an hour or so. These were actuators that cycled maybe 5 Hz or more. I suspect the technique may be quite effective in a simple strut application. |
Jay Honeck wrote:
He says that it's SOP to apply brake fluid to the struts of the DC-9s he services (at his day job) every, single time they park. It's messy, as a result, but their strut seals rarely need to be replaced. Interesting as we did just the opposite with exposed cylinders on the logging equipment I operated many moons ago. Any oil just collected dust and formed an abrasive slurry that wass very hard on the seals. I guess most airplanes probably don't pick up that much dirt normally, but if I operated from a gravel or dirt strip I'd think twice before oiling the strut cylinder. Matt |
Well..
That's .065 AMU's.... I have always found that having the "naughts" in FRONT of the real numbers was better than having the "naughts' (0's) AFTER the real numbers... ![]() Dave On 8 Feb 2007 07:32:25 -0800, "Jay Honeck" wrote: Last week, in -22 temperatures, our nose gear drooped all the way to the stop. Later, we were able to put some down pressure on the stabilator (in the hangar) and bring it back up a couple of inches, but made plans to have our A&P look at it. Yesterday, since he wasn't coming in the shop till afternoon, we decided to go flying first. My landing in Oskaloosa, IA (KOOA) was gingerly -- a text book soft field landing, with the nose gear staying high in the air till almost stopped. The strut stayed up around three inches all the way to parking. The temperature was about 5 above zero, and I thought that perhaps this had been a transient problem that had "fixed itself". (We always hope, no? :-) Not. Mary's landing back in Iowa City was fine, but the strut again collapsed to the stop -- so we taxied straight to the shop. My A&P told me that he could "service" it (basically, add air), but after some discussion we decided to replace the seals in the strut. He said that the O-rings were likely old (we hadn't replaced them in the 5 years we've owned Atlas), stiff, and perhaps "rolled", so that even though lubricating the strut and adding air might do the trick for a while, it would be a stop-gap measure, at best. I helped him do it, and it took about an hour. (Of course, he's done it a million times -- the job would have taken me all day, with instructions, and I might have killed myself doing it.) But now, the strut is sitting tall again, with new fluids, O-rings, and air pressure. Total: $65. Not bad at all, in aviation terms... He says that it's SOP to apply brake fluid to the struts of the DC-9s he services (at his day job) every, single time they park. It's messy, as a result, but their strut seals rarely need to be replaced. |
I helped him do it, and it took about an hour. And if you hadn't helped him, it might have taken, what? a half-hour? :-)) --ron |
:-)) Probably. Actually, as I've gotten more experience (I'm into my 9th year of aircraft ownership now -- dang, how did THAT happen?) I've grown more competent at helping my A&P. Mostly that means I now know when to stay the hell out of his way... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Granville's Strut Seal - Or Other Strut Maintenance Techniques | zatatime | Owning | 4 | August 31st 05 04:30 PM |
slow roll in a super decathlon | Nobody | Aerobatics | 4 | August 24th 05 02:36 AM |
Cherokee Strut Lower Strut Seal Replacement Report | Mike Spera | Owning | 3 | July 23rd 05 07:07 PM |
Three more newbie Qs, if you don't mind :) | Ramapriya | Piloting | 17 | November 7th 04 05:03 AM |
VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 05:22 AM |
