Question for the helicopter fans???
Old December 10th 06, 08:42 AM posted to alt.binaries.pictures.aviation
Andrew-S
Default Question for the helicopter fans???
The other day one of the police departments that I work with mentioned that
another PD aviation section had an "overspin" on their helicopter.. I was
going to ask at the time what an overspin was but I forgot... So my
question is what exactly is an overspin??? I checked the web and the
answers I found where not exactly enlightening...
Many thanks,
Andrew
Old December 10th 06, 09:05 AM posted to alt.binaries.pictures.aviation
Luke
"Andrew-S" I-Still-Hate-Spammers@Sorry-I had-to-leave-for-bit.com wrote in
message ...
that
Rotor RPM limit exceeded.
Luke
Luke
message ...
that
Luke
Old December 10th 06, 09:10 AM posted to alt.binaries.pictures.aviation
alf blume
"Andrew-S" I-Still-Hate-Spammers@Sorry-I had-to-leave-for-bit.com skrev i
en meddelelse ...
that
I'll venture a guess:
The rotor presumably has a maximum rpm. It is possible to overspin the rotor
if you decend very rapidly . .
A Police-helicopter can do that when they decend to check occupants in cars
they are persuing - or if they have an engine failure, in which case you
spin-up the rotor during the decend to make sure you have lift enough for
the landing.
It's called "autorotation" - I've tried it as a passenger in a Hughes OH-6
during a training flight, pretty scary.
Regards Alf
Click image for larger version
Name:	Hughes 500M  (OH-6A) H-201 Danish Army.1973.15_2.jpg
Old December 10th 06, 09:26 AM posted to alt.binaries.pictures.aviation
Andrew-S
Many thanks...
Alf
"alf blume" wrote in message
i en meddelelse ...
that
was
rotor if you decend very rapidly . .
cars they are persuing - or if they have an engine failure, in which case
you spin-up the rotor during the decend to make sure you have lift enough
for the landing.
OH-6 during a training flight, pretty scary.
Regards Alf
Old December 10th 06, 09:45 AM posted to alt.binaries.pictures.aviation
Conscious Pilate
G'day All,
this occurs only if the main rotor blades are not correctly aligned &
tracked - I have had it occur once when after many hours of boring
tracking - i.e. they put strobe reflecting bits on the end of the blades -
for say a 3 bladed job the strobe thingos are sorta like this - | _ / - you
as a pilot pull it into a 3' hover & hold it - the maintenance bloke aims
his strobe gun on the main rotors usually sitting on the top of a ladder -
notes stuff arcane stuff in his little book - sees which one of the 3 is
higher or lower. Then we land the helicopter - shut it down & the LAME makes
adjustments to all the nuts & bolts on the main rotor hub & the process is
repeated - sometimes for an agonising period.
Then ya go out & fly it - with the LAMe sitting in with ya - you then put it
into an autorotation & if the blades have been tracked successfully then the
main rotor RPM should stabilise at the max RPM red line.
So I suppose what I am trying to say is that if you experience a main rotor
overspeed then the maintenance of the machine is a bit of a worry. I still
have the bolt that was removed from the offending blade - it was cracked all
the way through - so it is really a very serious problem to experience a
main rotor overspeed.
see ya
Conscious Pilate
P.S. Your total logged time for about 3 hrs work is usually about 15mins!!
Conscious Pilate
G'day All,
see ya
Conscious Pilate
Andrew-S
Many thanks...
Alf
i en meddelelse ...
that
was
for the landing.
Regards Alf
Old December 10th 06, 04:26 PM posted to alt.binaries.pictures.aviation
Aree on the Rotor RPM limit exceeded.
But practice autos are a kick in the ass for fun. Best e ticket ride
you can ge as a helo crewman.
On Sun, 10 Dec 2006 10:10:45 +0100, "alf blume"
en meddelelse ...
that
the landing.
Regards Alf
en meddelelse ...
that
the landing.
Regards Alf
FA: 1-Day-Left: Aviation Scanner Fans, Flight Sim Fans - Maps, Charts, JEPPS, DOD, FAA, VFR, IFR, etc. Pete Aviation Marketplace 0 April 10th 06 01:37 PM
Jet Helicopter Question Dick Rotorcraft 0 April 7th 06 11:30 PM
FA: Aviation Scanner Fans, Flight Sim Fans - Maps, Charts, JEPPS, DOD, FAA, VFR, IFR, etc. Ed Aviation Marketplace 0 April 4th 06 08:34 PM
Helicopter Question Jay Honeck Piloting 49 December 5th 05 05:41 AM
Helicopter "imcident" question Chuck Piloting 10 October 19th 04 12:33 AM
