Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Thanks for the Spins Rich
Old October 12th 03, 03:00 AM
David B. Cole
Default Thanks for the Spins Rich
Today I had an opportunity to fly with Rich Stowell as part of his
annual Emergency Maneuver Training Clinic in NJ. Yesterday we
experienced low viz and fairly low ceilings the entire day with even
worse forecast for today, so it didn't look good for us. But today
turned out to be an almost perfect Fall day with temperatures in the
high 60's to lower 70's.
When I arrived at the airport I was greeted by Rich, the airport
owners and clinic hosts Linda and Corky, and two other students that
had flown with Rich earlier and were going up again for a second
session. After chatting for awhile he started the ground school where
we discussed the maneuvers we would do, how to operate the parachute,
and a host of other questions on emergencies. One of the guys who had
gone in the morning was scheduled to fly first after the ground
school, but he was willing to give up his spot to me. As reality
started to set in about what was soon to happen I became a little
anxious, but took his offer to go up first.
After getting acquainted with the Super Decathlon, which is a great
plane, and getting strapped in, we started up and he allowed me to
taxi to the active, do the runup, and takeoff. They aren't kidding
when they say you have to be constantly on your toes in a taildragger.
After takeoff we climbed to about 4000' to do some dutch rolls.
Initially I was a little timid with the ailerons, but eventually got
it together although my feet were still slower than I would have
liked. After the dutch rolls we moved on to a few power-off stalls.
Again, you have to be on your toes as the nose has more of a tendency
than the 172 to drop off to either side if you're too slow on the
rudder.
After a few power-off stalls performed while looking straight ahead,
we did a series where I had to pick an object off to the side and
focus on it throughout the entire stall. The tendency was to stop
looking at the selected object and to look toward the nose as the
stall broke, which causes even more disorientation and
overcontrolling. But after awhile you can not only sense what the
nose is doing by looking at that object, but you can also feel what
corrections need to be made during the recovery without looking out
over the nose. Following this we did the same exercise with power on
stalls, followed by a falling leaf where Rich kept the plane stalled
and I attempted to keep the wings level with the rudder.
Then he asked if I was ready for a couple spins, to which I anxiously
said yes. No demonstration needed, he talked me through the first
spin and I did it myself. Power back, 5 knots above stall kick in the
rudder and continue pulling. All I can say is "Wow!", the quickness
which with you go from looking at the sky to looking at ground is
incredible. Again Rich talked me through the recovery and before I
knew it we were straight and level and I was asking for more. Don't
get me wrong, the remaining three were still somewhat disorienting
because everything happens so quickly and the world is spinning around
pretty fast, but the actual departure wasn't a surprise anymore.
After the second spin Rich told me that I had as many spins as most
instructors, which I found to be very sad. On the third spin I
released the elevator backpressure just a bit too quickly and the
rotations sped up briefly, which was wild. On the way back to the
airport we did both an aileron roll and a loop and I was as giddy as a
schoolgirl. I was surprised that I didn't have any reservation with
just cranking the aileron full left and watching us go from upright
to inverted, then back to upright. And the loop, that was a total
thrill. I had a little more reservation with pulling the stick all
the way back for the loop than I had with the ailerons in the roll,
but before I knew it the sky disappeared, I was looking out over the
wing, and then the ground came back into view. No discomfort, and
although the G-meter registered about 3.5G's, I didn't really notice
it. Now my landing back at the field, that I'll keep to myself.
I would have to say that with the exception of becoming a pilot in the
first place, this was probably the best money I've spent since
beginning flying. While I certainly plan to exercise the same caution
I always have, my confidence has certainly increased since the specter
of the unknown is no longer there. But my respect for spins has also
increased, especially seeing the amount of altitude that we lost in
that one turn. I hope to make it to Cali to work with Rich more, but
also plan to pursue some additional aerobatic training here in the
area. I know some of you have already flown with Rich, but if you
haven't then do whatever you can to get some time with him. Not only
is he a great guy, but he is a great instructor that will make you
feel at ease. And if you're in the Jersey area, try to get on the
list for next year's clinic at Alexandria Field (N85). It's an
absolutely beautiful airport and I found myself there for a few hours
afterwards because of the fascinating backdrop of mountain ridges and
the amazing Fall colors.
Dave
Old October 12th 03, 12:55 PM
Kevin Horton
On Sat, 11 Oct 2003 20:00:31 -0700, David B. Cole wrote:
After takeoff we
climbed to about 4000' to do some dutch rolls. Initially I was a little
timid with the ailerons, but eventually got it together although my feet
were still slower than I would have liked. After the dutch rolls we
moved on to a few power-off stalls. Again, you have to be on your toes
as the nose has more of a tendency than the 172 to drop off to either
side if you're too slow on the rudder.
Great write up.
One very small nit to pick - I know a lot of people think a dutch roll is
a manoeuvre where the pilot it actively making the aircraft roll back
and forth around a point. But the term properly means a combined yawing
and rolling oscillation that the aircraft does all by itself.
It is hard to have clear communication when we have words that
mean different things to different people.
For a rant on the mis-use of the term dutch roll, see:
http://www.douglasdc3.com/sohn/41.htm
For what Bill Kershner thinks about it:
http://pulsar.westmont.edu/aeronca/d...ques/0080.html
For descriptions of what dutch roll is:
http://www.rmcs.cranfield.ac.uk/aeroxtra/dtcstab7.htm
http://www.av8n.com/how/htm/equilib.html
And to show that dutch roll is not just an issue with swept-wing jets:
http://www.berkutengineering.com/pag...rtav898-3.html
Kevin Horton
Ottawa, Canada
e-mail: khorton02(_at_)rogers(_dot_)com
http://go.phpwebhosting.com/~khorton/rv8/
Old October 15th 03, 08:23 PM
Rich Stowell
Kevin Horton wrote in message ...
After takeoff we
Great write up.
Hi Kevin,
Pilots picking nits? Who would have guessed ; )
The English language is very colorful, and many terms have multiple
meanings depending on the context. In the context of the aerobatic
environment, Dutch Roll (note the capitalization, which is customary
in this context) is well understood by aerobatic pilots to describe a
specific coordination maneuver as opposed to the inherent instability
dutch roll common in swept wing aircraft.
While it is true that sometimes the use of certain terms can lead to
confusion, we nevertheless frequently use terminology that has
multiple meanings. For example, ask the airline pilot who is strapping
into his aerobatic mount on his day off from his flying job to explain
and perform a Dutch Roll, and he will know exactly what is being asked
of him. However, ask him to define dutch roll while he's at 35,000
feet in the left seat of his airliner, and he'll likely delve into the
aerodynamic issues involved with dutch roll instability.
Yes, context is important; but to imply that a particlar phrase or
word can and must have one and only one meaning might be a fruitless
exercise indeed! Consider the following:
We'd have to find another word for "stall" since it means something
totally different to me when I'm in my car versus when I'm in my
airplane (and there are far more drivers than pilots, so we'd probably
lose the battle for exclusive use of that term);
We'd have to find another name for "flaps" because, frankly, they
don't;
The "elevator" does not elevate;
"Adding more throttle" or "increasing throttle" doesn't throttle
anything;
"Snap Rolls" have nothing to do with the roll control.
Anyone want to add to this list?
Rich
http://www.richstowell.com
Old October 15th 03, 09:04 PM
Kevin Horton
is a manoeuvre where the pilot it actively making the aircraft roll back
It is hard to have clear communication when we have words that mean
Hi Kevin,
environment, Dutch Roll (note the capitalization, which is customary in
confusion, we nevertheless frequently use terminology that has multiple
meanings. For example, ask the airline pilot who is strapping into his
aerobatic mount on his day off from his flying job to explain and perform
a Dutch Roll, and he will know exactly what is being asked of him.
However, ask him to define dutch roll while he's at 35,000 feet in the
left seat of his airliner, and he'll likely delve into the aerodynamic
Yes, context is important; but to imply that a particlar phrase or word
can and must have one and only one meaning might be a fruitless exercise
Rich,
Yeah, I was probably a bit over-the-top with my post. And my perspective
is perhaps clouded by my military and flight test background.
I guess the important point to reel in is that we need to be aware of
when a term could have more than one meaning, and provide enough context
to make the intended meaning clear. I first heard the term Dutch Roll
used to describe a coordination manoeuvre a couple of months ago. Before
that, if I went flying with you and you asked me to do a Dutch Roll, you
would have been baffled to watch me do a rudder doublet and count the yaw
overshoots.
Poor lateral-directional dynamic stabilty (a.k.a. dutch roll) is not
just an issue with swept-wing yets. I've heard many a V-tail Bonanza
driver complain about the tail wag, which is just a variant of dutch roll.
I'd tell you to keep the blue side up, but you probably don't want to do
that
Fly safe,
Kevin Horton
Ottawa, Canada
Old October 17th 03, 02:38 AM
Andrew Gideon
The preflight checklist for the newer Cessna 172s requires that the fuel
shutoff be on. If the shutoff were on, wouldn't the fuel [flow] be shut
off?
- Andrew
P.S. See you in a couple of days.
Old October 26th 03, 08:37 AM
Hilton
don't;
anything;
"World Series"?
BTW: I too am a 'graduate' of a Rich Stowell weekend of spins, or more
correctly EMT. I also own his EMT book (www.amazon.com) and videos (books
and videos available from http://www.richstowell.com/shop.htm). It was an
excellent learning experience. My opinion is that (some amount of) spin
training should be part of the pilot certificate training - but that's for
another thread. Rich's does great FAA Wings Seminars too. Did I mention
Rich is a great guy? Check him out at http://www.richstowell.com
Hilton
Old October 12th 03, 07:17 PM
Andrew Gideon
beginning flying.
Wow. Thanks, David. I'm eager for my slot next weekend.
- Andrew
Old October 12th 03, 10:44 PM
David B. Cole
You should be my friend. I'm actually on the waitlist just in case
any additional spots open during the week. Hopefully the weather will
be as nice next weekend as it was this weekend, that way you can
really enjoy the character of the airport. You should definitely take
the family with you. Call me if you want to catch up and make sure
you ask for a roll and a loop. Funny, sounds like a fast food order.
"Would you like a roll and a loop with your spins?"
Dave
Andrew Gideon wrote in message gonline.com...
beginning flying.
- Andrew
Old October 13th 03, 12:20 AM
Andrew Gideon
Why? What would they be doing aside from waiting around during the lecture,
while others were flying, and - eventually - when I'm flying?
- Andrew
Old October 13th 03, 06:31 AM
David B. Cole
Ok, then don't.
- Andrew
Better URL for the "Unrecoverable Spins" Article Jay Aerobatics 0 August 29th 03 06:53 AM
An Article on Unrecoverable Spins Dave Swartz Aerobatics 0 August 16th 03 06:49 AM
