Transfer of IGC log for contest scoring
Old February 11th 07, 08:59 PM posted to rec.aviation.soaring
Tom N.
Default Transfer of IGC log for contest scoring
Hello all,
I plan to fly in my first contest this summer. What is the best
(easiest) way to transfer my IGC flight log to the scorer? I use a
Cambridge 302 and IPAQ 3955. For the OLC, I download the file to my
IPAQ using ConnectMe and the take the IPAQ home and connect it to my
PC and then upload to the OLC. Would contest scoring be something
similar to this? Thanks. Tom N.
Old February 11th 07, 09:16 PM posted to rec.aviation.soaring
Marc Ramsey
Stick an SD card in the iPAQ, copy the IGC file there, and hand the card
to the scorer. To reduce confusion, make sure the IGC to be scored is
the only file on the card, or at least the only obvious IGC file in the
top level directory.
Make sure you bring along a USB SD card reader (the one I have in my
soaring kit is barely larger than the SD card and cost me all of $8US),
in the unlikely event the scorer does not have one...
Marc
Old February 12th 07, 12:52 AM posted to rec.aviation.soaring
ContestID67
I agree with the SD (or CF) card approach. Cambridge makes a small
piece of software for the iPAQ that makes copying the flight log to
the card very simple. Then hand the card to the scorer. Make sure to
write your name, tail number, contest number on the card. Also make
sure that you configure the Cambridge (with the same piece of
software) with your name, glider info, etc. The software also
confirms the validity of the FAI log file after the download.
I wouldn't worry to much about having the day's log file being the
only one on the card. The naming convention for the log file contains
the date and the recorder manufacturer and serial number.
Finally, Glide Navigator II (for one) seamless handles the task of
copying the log file from the 302 to the card. When you quit GNII
after landing, it automatically asks you if you want to copy the
file. Cool! Thanks to Chip.
Enjoy, John
Old February 12th 07, 05:59 AM posted to rec.aviation.soaring
kirk.stant
Tom,
SD cards are the way to go with a PDA. Good idea to have a couple of
them (they don't have to be big - 64 or 32mb work fine if you can find
them!) and put your contest ID and name on them (of course, your
logger file in it also has that info). You may have to leave it with
the scorer if he's swamped, and that makes it easier to get it back
later or the next morning.
That's the only problem I see with the new EW logger - you either
leave the whole logger in the box with the rest of the SD cards and
floppies, or you drag along you notebook and download it and transfer
to another format.
Ideally, a logger should transfer it's files directly to a USB
thumbdrive or SD card (directly or via reader connected via USB
port). Lot cheaper to misplace than a logger! Doesn't the latest
Colibri do that?
Kirk
Old February 13th 07, 12:59 AM posted to rec.aviation.soaring
Tom N.
On Feb 11, 11:59 pm, "kirk.stant" wrote:
Tom,
to another format.
Colibri do that?
Kirk
Thanks Mark, John, and Kirk.
Tom
Old February 19th 07, 11:54 PM posted to rec.aviation.soaring
Paul Remde
Hi Kirk,
2 comments
It is my belief that contest scorers will love the EW microRecorder because
you just plug it into the USB port on any PC and it looks like a memory card
reader or hard drive. Very simple. No software required.
EW is working on a slightly more expensive version of the microRecorder that
will include an SD card slot. To be honest, I don't think it is necessary
or worth the extra money.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
"kirk.stant" wrote in message
Tom,
to another format.
Colibri do that?
Kirk
Old February 20th 07, 04:16 AM posted to rec.aviation.soaring
kirk.stant
Hi Paul,
No doubt, the new EW logger looks like a great bit of kit, and will be
convenient for most of the poeple most of the time. Just depends on
how you use and download a logger. I have been at contests where the
scorer was real busy, so we just dropped off the SD card. With an EW,
you would have to wait around a little longer. In 99% of the times,
probably not an issue.
I just wish you could leave it installed in the glider and download
into a PDA/SD card. One less thing to take out and replace - not
always easy to do in some gliders, especially if it's buried and the
antenna connector is hard to get to. But that is entirely due to how
my glider is setup and obviously does not mean the EW Micro logger
isn't the perfect device for someone else. In particular, it seems
like a perfect club logger.
It's nice to have a choice of options - I think all loggers should
allow the option of downloading to a PDA, transferring via USB, or
transferring TO a USB thumb drive or SD via reader. And only cost
$99.95, of course!
Cheers,
Kirk
Old February 20th 07, 01:42 PM posted to rec.aviation.soaring
Richard[_1_]
Contests that I have competed in, over the last 5 years the scorer
wants nothing to do with a flight recorder, they would not accept
them. They required SD Card, USB sticks. disk etc.
I sell a nice Colibri with a mini SD Card.
Richard
www.craggyaero.com
On Feb 19, 3:54 pm, "Paul Remde" wrote:
Hi Kirk,
2 comments
Good Soaring,
Paul Remde
Tom,
to another format.
Colibri do that?
Kirk- Hide quoted text -
- Show quoted text -
Old February 20th 07, 02:04 PM posted to rec.aviation.soaring
01-- Zero One
That's interesting, because _every_ contest that I have competed in for
years has accepted flight recorders... especially Cambridge that will
automatically download directly.
Larry Goddard
"01" USA
"Richard" wrote in message
oups.com:
Richard
www.craggyaero.com
Hi Kirk,
2 comments
Good Soaring,
Paul Remde
Tom,
to another format.
Colibri do that?
Old February 20th 07, 02:15 PM posted to rec.aviation.soaring
Richard
www.craggyaero.com
I don't see why a EW miroRecorder would be less convenient that a USB stick.
Maybe the technology associated with the ON/OFF switch is too much for the
scorer to handle.
OLC Scoring [email protected] Soaring 2 June 13th 06 03:01 AM
OLC scoring - USA Ian Cant Soaring 18 November 29th 05 07:43 PM
OLC scoring - USA Ian Cant Soaring 0 November 28th 05 03:09 AM
Inaccurate Contest Scoring Bill Feldbaumer Soaring 21 June 14th 04 02:56 PM
History of Contest Scoring Bill Feldbaumer Soaring 8 October 8th 03 02:14 PM
