annual - hartzell AD
Old February 17th 07, 02:21 AM posted to rec.aviation.owning
Doug Vetter
Default annual - hartzell AD
Hi all,
With the recent topics on Annuals hitting the group, I figured I'd
relate my own, indulge myself in a short rant, and ask a question of you.
Just got the call from our A&P today and our 172 w/180HP Avcon
Conversion came through the annual in pretty good shape. Unfortunately,
we did manage to get caught on one thing -- in spite of having spent
almost $3K to overhaul our Hartzell CS prop in 2003, we just learned
that it was hit with an AD issued in September 2006 for hub cracks.
We have to fly out to our prop shop and have them do an eddy current
inspection within the next few flight hours to determine if the hub can
remain airworthy (ironic that they ask us to FLY it there), and then we
have two choices:
1) Do the inspection again every 100 hours or 12 months, whichever comes
first. It costs about $200 + the flight time to go out there, or about
$400.
or
2) Spend about $2500 to replace the hub to terminate the reoccurring
inspection.
When I read the service bulletin on which the AD is based, it looks like
some kind of CYA letter. They provide specific technical information
and examples of WHY the SB has been issued (that I can't debate since
I'm not an aeronautical engineer), but then they go on to declare that
"all pre-1991 hubs" are suspect. In my opinion, that's a bit of a broad
stroke.
Of course, we have to comply with the AD terms, so we will. But it
comes to mind that if our prop was truly susceptible to this condition I
figure it would have thrown a blade in the first 30 years and 2000 hours
in service -- or at the very least failed the inspection at the recent
overhaul. I have the distinct feeling that this is just another way for
Hartzell's attorneys to cover their ass and to make a few bucks for the
company at our considerable expense.
Our prop shop empathized and said that this is a common problem with
Hartzell. They like to write service bulletins and appear all too happy
to help the Feds issue ADs to force owners to clean up their messes.
Then when owners bitch about the lack of data to support the
manufacturer's claims, the ADs are eventually rescinded. This rang true
with me because an earlier AD on this prop that involved the blade
shanks was in effect for almost 10 years before the Feds rescinded it
due to a lack of supporting data. I can't help but think the new AD is
another example of this brain-dead approach to airworthiness.
The shop also said the AD was issued due to "several" blade separations
in the field. This is news to me. I mean, I haven't been living under
a rock the last 10 years. I know full well, for example, that neither
Lycoming nor Continental's low-bid manufacturers can make a crankshaft
to save anyone's life and I recall hearing about several catastrophic
engine failures that resulted from those defects, but I haven't heard
anything about these alleged blade separations.
Anyone else affected by this AD?
http://tinyurl.com/v68jk
-Doug
Doug Vetter, ATP/CFI
http://www.dvatp.com
Old February 17th 07, 02:37 AM posted to rec.aviation.owning
Travis Marlatte
"Doug Vetter" wrote in message
Hi all,
Me. Although, I've done such little flying lately that I have yet to come
close to 50 hours since the AD became effective. But, since I'm planning to
cross the threshold before my annual in May, I was just thinking of finding
a prop shop in the area. Anyone have a good recommendation in the Chicago
area?
Travis
Lake N3094P
PWK
Old February 17th 07, 05:49 AM posted to rec.aviation.owning
Robert M. Gary
I'm in the same boat. We overhauled the prop on our Mooney in 2005,
just before the AD. We're going for the $5500 option of replacing the
entire prop. Its a good deal, the blades alone would normally cost
that. Do you recall how much was left on the blades after your 2003
OH?
-Robert, CFII
Old February 17th 07, 04:16 PM posted to rec.aviation.owning
Doug Vetter
OH?
I don't happen to have the specs (mechanic still has the airplane and
the logbooks -- sorry) but when I called the prop shop while it was in
for overhaul they commented that both blades were in very good shape and
near "new" specs. He expected that both would have good life left in
them after the overhaul. No sense in tossing what works, right?
-Doug
Old February 18th 07, 04:28 AM posted to rec.aviation.owning
Robert M. Gary
Yea, sounds like in your case the new hub is the way to go. Send your
old blades in and have them attach them to the new hub. I believe they
are required by the FAA to reoverhaul the blades again but it
shouldn't be a big deal.
I know that some people who live in the South have gotten really good
deals on the eddie inspection and will just do that. I live in
California and pay up to $400 each time so its a no-brainer to dump
the old hub.
-Robert
Old February 18th 07, 03:50 PM posted to rec.aviation.owning
Doug Vetter
My prop shop only said that as long as the blades are within TBO (flight
and calendar time), all they'd have to do is a reseal.
the old hub.
Total costs for us will be around $350 (including flight time out
there), but it still makes sense for us to get another 5 years or so out
of things as they are. By that time it will either be someone else's
problem or it will be ready for another overhaul.
Who knows...next year we might change our mind, but for now it's
inspections for us.
-Doug
Old February 17th 07, 07:56 AM posted to rec.aviation.owning
Thomas Borchert
Doug,
Yup, our Tobago is. Apparently, one can negotiate discounts with
Hartzell for the replacement. Also, there has been at least one fatal
crash in the UK, IIRC.
Thomas Borchert (EDDH)
Old February 17th 07, 12:29 PM posted to rec.aviation.owning
Ron Rosenfeld
On Fri, 16 Feb 2007 21:21:03 -0500, Doug Vetter wrote:
Hi all,
have two choices:
$400.
or
inspection.
Just went through it with my Mooney. I opted for the hub replacement.
By the way, IF you opt for the hub replacement, you won't necessarily have
to do that first eddy current inspection you mentioned above, unless you
want to wait to do the replacement. And your regular shop can pull the
prop and send it off to the shop (that's what we did).
Also, Hartzell, in their infinite wisdom, would send ME a hub, but would
not send it to my prop shop. Fortunately, the shop had a post-AD new hub
on the shelf; so we were able to do a swap with minimum down-time.
--ron
Old February 17th 07, 04:32 PM posted to rec.aviation.owning
Doug Vetter
Good point, however we've decided to go the inspection route for now as
we don't know how much longer we'll have the airplane, and it would be
6+ years before we'd pay as much in inspections as we would in the case
of hub replacement.
And in a strange sense, I think I'll feel safer doing the routine
inspection. No matter whether the part is new or old, affected by an AD
or not, they can all develop cracks, and the ones you don't find in time
are the ones that will kill you.
My prop shop told me I could buy the hub directly from Hartzell at the
shop's price and that way they wouldn't mark it up. That struck me as a
bit strange, but I bet has something to do with the burden of liability
shifting to the owner or to Hartzell for the owner-supplied part.
-Doug
Old February 18th 07, 02:09 AM posted to rec.aviation.owning
Ron Rosenfeld
of hub replacement.
For my amount of flying, I'd be doing a few inspections per year. And I
did not want to deal with the down time for that.
Interesting. My prop shop (and also Hartzell themselves) told me that
Hartzell would not sell them a hub.
--ron
Hartzell 2 blade Prop for PA24-250 kontiki Aviation Marketplace 1 August 14th 11 10:21 PM
What an annual.... The Visitor Owning 20 February 19th 07 10:32 AM
Hartzell prop hub AD 2006-18-15...results and our options Jack Allison Owning 10 December 27th 06 06:51 PM
Out of annual.... A Lieberman Owning 7 October 31st 05 02:47 AM
Off I go to help with my first annual on my C-150 NW_PILOT Owning 22 October 26th 04 11:39 PM
