Ping Sam Spade: DA versus DH on an ILS?
Old February 27th 07, 11:06 PM posted to rec.aviation.ifr
Peter R.
Default Ping Sam Spade: DA versus DH on an ILS?
Sam and others, I have about 1,100 hours now with about 700 of those flown
after getting my instrument rating in the US back in 2003. Since then I have
flown IFR almost twice per week.
On a web-based aviation forum there is a general disagreement of the terms DA
(decision altitude) versus DH (decision height) when talking about an ILS
approach.
For those approaches that have published altitude minimums (typically ILS CAT
I or CAT II in the US), I was taught that the point at which one would begin
the missed approach is the decision height, or DH. However, in that aviation
forum there are a few who insist that this point is called the decision
altitude, or DA, and that DH is not valid for aircraft not equipped with
radar altimeter.
I did note that the current Pilot/Controller's glossary defines both DA and
DH as the point at which a missed does begin on a precision approach, but the
DA definition also includes the note about it being an ICAO definition.
Is this a case of semantics? Are DA and DH interchangeable when discussing
the point at which a missed begins? Or is there a more important distinction
between the two and I was simply taught inadequately?
Peter
Old February 27th 07, 11:21 PM posted to rec.aviation.ifr
Mark Hansen
approach.
radar altimeter.
I was taught that for instrument charts, "Altitudes" refer to MSL altitudes
and "Heights" refer to height above the ground. This means that DA refers to
the MSL altitude where the decision is made.
I think I read in the Jeppesen materials (or maybe it was a Rod Machado book)
that this terminology is the direction where things are going, but not everyone
agrees with this (yet). For example, the NACO Terminal Procedures Publication
still uses DH.
If you look at the Jeppesen charts, they use DA(H) to indicate that
this is the Decision Altitude MSL, with the height above the ground
shown in parenthesis.
I don't know from whom you can get a definitive answer.
Hope that helps,
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old February 28th 07, 06:02 AM posted to rec.aviation.ifr
Mike Young
"Mark Hansen" wrote in message
discussing
distinction
altitudes
to
book)
everyone
Publication
still uses DH.
In the TPP frontal matter, of course.
Landing minima are given as DA, decision altitude in feet MSL; RVR in 100's
of feet or whole and fraction statute mile; HAT (feet height above
threshold); and parenthetic equivalents for military. Circling minima
specify HAA (feet height above airport) rather than HAT. All four elements
are always present in NACO TPP landing minima.
Old February 27th 07, 11:59 PM posted to rec.aviation.ifr
kevmor
I think I've heard that DH is the newer term for DA and they are for
the same thing...
approach.
radar altimeter.
Peter
Old February 28th 07, 12:08 AM posted to rec.aviation.ifr
Ron Natalie
the same thing...
DH is AGL.
DA is MSL.
DH is actually the older terminology and people tend to use it
for both concepts.
Old February 28th 07, 01:49 AM posted to rec.aviation.ifr
kevmor
Would you use DH with a radar altimeter?
On Feb 27, 4:08 pm, Ron Natalie wrote:
the same thing...
DH is AGL.
DA is MSL.
for both concepts.
Old February 28th 07, 02:42 AM posted to rec.aviation.ifr
Sam Spade
the same thing...
DH is AGL.
DA is MSL.
for both concepts.
DH is MSL just as is DA. The only altitude you will see that is AGL is
RA on a CAT II ILS and that is AGL above the DA/DH point.
Old February 28th 07, 02:38 AM posted to rec.aviation.ifr
Sam Spade
There is no difference between DA and DH.
DH is old FAA
DA is ICAO.
DA is new FAA. ;-)
Old February 28th 07, 01:45 PM posted to rec.aviation.ifr
Peter R.
DH is old FAA
DA is ICAO.
DA is new FAA. ;-)
Sorta like the transistion from SID to DP....
Thanks, Sam.
Peter
Old February 28th 07, 03:11 PM posted to rec.aviation.ifr
Sam Spade
You mean SID to DP to SID in FAA-land. ;-)
C-172 versus Sundowner [email protected] Owning 30 July 23rd 06 03:34 PM
Garmin 480 versus 530 Paul Tomblin Owning 6 January 3rd 06 09:07 PM
F-8 versus F-4 Doug \Woody\ and Erin Beal Naval Aviation 43 October 12th 05 08:49 PM
F-8 versus F-100 Doug \Woody\ and Erin Beal Naval Aviation 6 May 16th 05 10:01 PM
"zero" versus "oscar" versus "sierra" Ron Garret Piloting 30 December 20th 04 08:49 AM
