Well, I finally made it out to the airport (3BS) today.
With the 4-Runner in 4WD I managed to get within about 10 feet of the man door. That's where those big tires dropped through the ice and snow to the sod underneath. sigh at least the ground is still frozen but I think we may be missing a bit of grass next spring. At least the snow wasn't up against that door. OTOH walking across about 16" of snow with an icy crust is interesting. Things were as I left them. No one had stolen the Deb and the cowl on the port side was still unfastened for the checking of the fouled plugs. So I jumped in, hit the switches and was greeted by...silence. Now with a foot to two feet of snow on the ramp I hadn't planned on going any where except to maybe warm up the engine and make sure the plugs were no longer fouled, but I hadn't expected silence. I probably should have brought the battery home and let it warm up out in the shop, but I wasn't thrilled about the idea of a frozen battery in the back seat even if it was on the floor. So, I'll take a battery box back out tomorrow and set the battery in the warm terminal building while I clean plugs, but I hold little hope for a battery that has gone dead in temperatures we had over the last month. Speaking of cold temps and a warm shop. I pulled quite a few "all nighters" working on the G-III this past month. Well that and a sick computer. (latest and greatest state-of-the-art dual core, high speed system that ended up trashed due to a wayward application...even took out the boot sectors on the drives. Now it's a month old and out dated) Sooo... that puts me in the shop for long hours during the coldest part of day during the coldest weather we've had in some time. There are 11 fluorescent light fixtures, ceiling mounted in there with each sporting two 75 watt, 8' long tubes for a total of 1650 watts. On top of that I had to put some heat in the generator shed as the thing just didn't want to start at those temperatures. So I put a little automated ceramic heater out there. The shed is small and reasonably well insulated except for the floor. I turned the thermostat all the way down as I figured keeping it a little above freezing should be enough. Next day I was able to start the generator even if it was a tad chilly in there. I then promptly forgot about it. That is until last week when I noticed a deep depression in the snow between the shop and shed right where I figured the heavy duty extension cord ran. After discovering the *heavy duty* multiple outlet plug at the end of the cord was pretty much fried I quickly replaced the little heater and outlet plug with a single 100 watt heat lamp in a reflector and plugged that into the cord. Note that the heater on high (when the temps was low) would draw 1500 watts or about 12 amps. The outlet was rated for 20 amps, but with a 1500 watt heater on 24 X 7 and that 1650 watts of light on for about 12 hours a day I was drawing 40 KWH per day, not counting heat and equipment in the shop, or gas for heating. Needless to say, last month was a wee bit on the pricey side. I sure am glad electric rates here, top out at just over 8 cents per KWH. At-any-rate, (no pun intended) I hope the guy who cleans the ramp gets mine done in the morning and the battery can be salvaged as they are kinda difficult to find around here on a week end. I'll probably stick that little heater under the instrument panel with the fan on and a blanket over the cabin. OTOH the hangar doesn't have enough capacity to run the heater AND the Tanis heater at the same time. I think it's time to start neglecting the G-III for a while and tend to my own proficiency and working the kinks out of the Deb. Weather doesn't look great, but I might be able to fly around snow storms for an hour or two if the ceiling is high enough. Looks like 2000 and 5 with occasional 1500 and 1. Breaking action...None. Eh! sounds like good VFR although a bit drafty for most of the day and those slippery runways make for good practice at landing at the slowest speed possible. OTOH they don't add much wear to the tires. then again I may have to tie the plane to the snow plow or tree so I can do a run-up. On the positive side, if the wheels freeze due to slush you can taxi all the way to the hangar and never notice. Of course if the gear wells freeze shut it can be a bit of an inconvenience. Then too these conditions are prime for chasing ice fishermen around on Saginaw Bay. Strong winds from 240 means a few of them may find themselves headed for Canada.:-)) Happens every year. Fly around out there and you will see ice fishing within 10 feet of open water. :-)) Just remember the clearance rules. Did I mention that not having been able to fly for over 6 weeks I'm beginning to suffer from withdrawal? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() Rog, I have a 35AH battery you can borrow if you need it... I would even bring it over for a look at the G3... I won't be back in the office but you can ping me through my naswering service... Call the office and the machine will give you the answering service number... Tell them I asked you to call me... Doubt you will be flying today, but ya never know... denny |
On 3 Mar 2007 05:50:43 -0800, "Denny" wrote:
Rog, I have a 35AH battery you can borrow if you need it... I would even bring it over for a look at the G3... I won't be back in the office but you can ping me through my naswering service... Call the office and the machine will give you the answering service number... Tell them I asked you to call me... Doubt you will be flying today, but ya never know... denny Thanks Denny, I appreciate the offer. I did get out to the hangar at a reasonable time. I brought the battery home to a nice warm shop. After stabilizing at room temperature I found no leaks and it looks like it's taking a charge. The guy who cleans the ramp (north side of hangar) for me has it clean and I made it within about 6 feet of the man door on the south side with the aid of 4WD:-)). Bout busted my ahhh... butt going in the man door. The bottom seal is gone and there is a patch of nice smooth ice about 6 feet across, just inside the door. So there I stood with a box full of tools...momentarily...as one foot decided to go north and the other south. Sorta like going out on the ice with the guards still on the blades of the ice skates. Well, not quite that bad. :-)) All is well..."I think" even if I did stop with my right shin on the raised metal door jam and my left upper thigh against the leading edge of the door. The door is hinged on the left and swings in. (I know, that position is about as hard to visualize as it is to get into) I now have the right length socket and adapter to the torque wrench, but discovered I need a needle or even paper clip to pick the lead out of the plugs. Some of it's in there pretty solid so when I go back out I'll take a "darning needle". (and my shop lights) . It was getting late and with plugs to clean as well as a tractor that didn't want to start I decided to make sure I had every thing handy when I go back out. Besides it's probably a whole lot better for that battery to warm up slowly before I tried charging it. I have a heavy duty battery to use as a jumper to start the tractor. Wednesday is supposed to be warmer and with sunshine so I should have everything ready by then. I'm really learning to dislike snow, but OTOH it sure beats super hot summers and hurricanes although we do get the occasional tornado. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
LS4 1/2 Share For Sale (Michigan) | Juliet11 | Soaring | 0 | January 23rd 07 06:01 PM |
Michigan Rental? | Arnold Sten | Piloting | 2 | April 5th 05 12:36 PM |
Winter in Michigan | Roger | Owning | 8 | January 28th 05 06:24 PM |
Winter in Michigan. | Denny | Owning | 2 | January 28th 05 04:47 AM |
Michigan (UP) KSAW winds ?? | Mitty | Instrument Flight Rules | 14 | September 8th 04 12:54 AM |
