Here's one that may seem silly: to what height, precisely, is an
altimeter calibrated to? The bottom of the landing gear? The height of the static port? the chord line of the fuselage? In a Cessna, the difference between these is minimal, but on an airliner, you're talking about a possible +/- 10-15 feet (even discounting the radar altimeter). What is the answer, o Swammi of Salami? TheSmokingGnu |
the wheels.
"TheSmokingGnu" wrote in message ... | Here's one that may seem silly: to what height, precisely, is an | altimeter calibrated to? | | The bottom of the landing gear? The height of the static port? the chord | line of the fuselage? In a Cessna, the difference between these is | minimal, but on an airliner, you're talking about a possible +/- 10-15 | feet (even discounting the radar altimeter). | | What is the answer, o Swammi of Salami? | | TheSmokingGnu |
When you dial in the altimeter setting, don't you check the altimeter
readout against the field elevation? That's what it's set to, whatever is the datum for the field elevation. I do think the only fields that are flat to within 10 feet might be places like the seaplane airport in San Diego. Or maybe airports in Florida -- there just aren't many hills there. On Mar 8, 2:36 am, "Jim Macklin" wrote: the wheels. "TheSmokingGnu" wrote in ... | Here's one that may seem silly: to what height, precisely, is an | altimeter calibrated to? | | The bottom of the landing gear? The height of the static port? the chord | line of the fuselage? In a Cessna, the difference between these is | minimal, but on an airliner, you're talking about a possible +/- 10-15 | feet (even discounting the radar altimeter). | | What is the answer, o Swammi of Salami? | | TheSmokingGnu |
TheSmokingGnu wrote:
Here's one that may seem silly: to what height, precisely, is an altimeter calibrated to? The bottom of the landing gear? The height of the static port? the chord line of the fuselage? In a Cessna, the difference between these is minimal, but on an airliner, you're talking about a possible +/- 10-15 feet (even discounting the radar altimeter). What is the answer, o Swammi of Salami? TheSmokingGnu When doing the bi-annual? the calbration is at the height of static port. Michelle |
On Mar 8, 6:56 am, Michelle P
wrote: TheSmokingGnu wrote: Here's one that may seem silly: to what height, precisely, is an altimeter calibrated to? The bottom of the landing gear? The height of the static port? the chord line of the fuselage? In a Cessna, the difference between these is minimal, but on an airliner, you're talking about a possible +/- 10-15 feet (even discounting the radar altimeter). What is the answer, o Swammi of Salami? TheSmokingGnu When doing the bi-annual? the calbration is at the height of static port. Michelle But a static port at a lower level won't result in a higher static pressure at the altimeter. There's a pressure drop with altitude inside the line, too, just as there is in a water-filled tube. I would imagine the pilot of a machine with its altimeter 20 feet off the ground would note a 20-foot discrepancy with the field elevation once the altimeter has been set to the controller's numbers. Dan |
On Mar 9, 12:24 pm, Michelle P
wrote: wrote: On Mar 8, 6:56 am, Michelle P wrote: TheSmokingGnu wrote: Here's one that may seem silly: to what height, precisely, is an altimeter calibrated to? The bottom of the landing gear? The height of the static port? the chord line of the fuselage? In a Cessna, the difference between these is minimal, but on an airliner, you're talking about a possible +/- 10-15 feet (even discounting the radar altimeter). What is the answer, o Swammi of Salami? TheSmokingGnu When doing the bi-annual? the calbration is at the height of static port. Michelle But a static port at a lower level won't result in a higher static pressure at the altimeter. There's a pressure drop with altitude inside the line, too, just as there is in a water-filled tube. I would imagine the pilot of a machine with its altimeter 20 feet off the ground would note a 20-foot discrepancy with the field elevation once the altimeter has been set to the controller's numbers. Dan that is why they allow a 75ft deviation. Michelle Thats what we need deviant altimeters :-) |
They go with deviant pilots, no? Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
... Here's one that may seem silly: to what height, precisely, is an altimeter calibrated to? The bottom of the landing gear? The height of the static port? the chord line of the fuselage? In a Cessna, the difference between these is minimal, but on an airliner, you're talking about a possible +/- 10-15 feet (even discounting the radar altimeter). What is the answer, o Swammi of Salami? TheSmokingGnu The altitude of the bench in the avionics shop. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
altimeter calibrated to? The bottom of the landing gear? The height of the static port? the chord line of the fuselage? In a Cessna, the difference between these is minimal, but on an airliner, you're talking about a possible +/- 10-15 feet (even discounting the radar altimeter). Good question. In practice, it would depend on the mechanic, and whether he cares enough to fine-tune the altimeter that much. The actual altimeter test is described in FAR 43 CFR Appendix E, and allowable error varies from 20' at sea level, to much more at higher altitudes. http://www.flightsimaviation.com/dat...t_43-appE.html The oft-quoted "75" feet error check is just a rule of thumb from the FAA Instrument Flying Handbook, Chapter 3, page 3-4: http://www.faa.gov/library/manuals/a...ying_handbook/ Now for a bit of weird history. I don't have the reference handy, but one common atmospheric formula used for converting between indicated altitude and outside pressure, includes a .01" Hg correction between the altimeter and the ground, or about 10 feet. This was apparently the most common instrument position some 70 years ago when it was created (!!) Cheers, Kev |
| Thread Tools | |
| Display Modes | |
| Deck height | Sean Trost | Home Built | 5 | July 16th 04 04:46 AM |
| Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 05:56 PM |
| Height records? | Paul Repacholi | Soaring | 2 | September 7th 03 04:14 PM |
| Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 08:42 AM |
| Seat height problem | Slav Inger | Piloting | 7 | July 22nd 03 03:31 PM |
