Laminating an aileron spar
Old March 27th 07, 01:54 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default Laminating an aileron spar
I need to add about 1/4" strip to the edge of my newly purchased
spruce aileron spar, 'cause I need to add a bevel. The spar is 3" wide
so the proposed strip is only a fraction of the area.
Can anyone see a problem if I used fir instead of spruce for this
strip? Fir is more easily available locally - Mike
Old March 27th 07, 04:29 AM posted to rec.aviation.homebuilt
cavelamb himself
Mike?
You need to add a 1/4" strip - that is going to be mostly beveled off?
This is a trick question, right?
What would it matter what you used for this??
Richard
Old March 27th 07, 05:44 AM posted to rec.aviation.homebuilt
jerry wass
Mike?
Richard
I'd glue it on real good--don't depend on tacks or staples--jerry
Old March 27th 07, 08:22 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Yeah, you wouldn't want it to be "tacky." g
Jim in NC
Old March 27th 07, 10:51 AM posted to rec.aviation.homebuilt
Michael Horowitz
On Tue, 27 Mar 2007 03:29:49 GMT, cavelamb himself
Mike?
Richard
Richard - thanks for the reply. I am concerned about two things;
because pine (for example) has a different density than spruce, they
might react differently to humidity or temp change and affect the
straightness of the spar. Second; some A&P looking at it and reject
the repair.
Granted, the amount is so small, I'm probably worried about nothing,
but being part of the USG, I"ve seen minor things become bent way out
of shape just because someone got their teeth into it. - Mike
Do you think I'm being unreasonable?
Old March 27th 07, 02:22 PM posted to rec.aviation.homebuilt
cavelamb himself
Mike?
Richard
the repair.
Probably, but that's ok.
Like Jerry said, glue it on. (With a good epoxy - I'd use T-88)
The strip is so small it shouldn't cause any problems.
Richard
Old March 27th 07, 03:06 PM posted to rec.aviation.homebuilt
COLIN LAMB
"I am concerned about two things; because pine (for example) has a different
density than spruce, they might react differently to humidity or temp change
and affect the straightness of the spar."
I do not think the difference in density will be the problem. A thin piece
of dried wood, when attached to a larger piece of wood will continue to
adapt to the shape of the larger piece of wood. The larger spruce would not
be any more likely to warp - but for the fact that one side is now protected
from the moisture - and that would occur no matter what kind of wood you
use.
The completed piece should be no more likely to warp than the original
piece.
As to the second part of the concern - about the inspection - ask the
inspector in advance. Remember, it is experimental.
Colin
Old March 27th 07, 03:35 PM posted to rec.aviation.homebuilt
mhorowit
use.
piece.
Colin
Old March 27th 07, 03:36 PM posted to rec.aviation.homebuilt
mhorowit
Colin
Nope: certified
Old March 27th 07, 09:03 PM posted to rec.aviation.homebuilt
Michael Horowitz
On 27 Mar 2007 07:36:25 -0700, "mhorowit" wrote:
Colin
Nope: certified
My A&P wants spruce or fir, so fir it will be
Thanks to all - MIke
Cub aileron hinges minot piper e Aviation Marketplace 0 October 23rd 04 03:51 AM
FA: Maule M5 Aileron BFC Aviation Marketplace 0 September 24th 04 04:31 PM
Need aileron OSKI 3 Owning 0 September 15th 03 07:46 PM
Need aileron OSKI 3 Home Built 0 September 15th 03 07:45 PM
Need Aileron OSKI 3 Aviation Marketplace 0 September 15th 03 07:45 PM
