Had a major radio install on my Baron- a Garmin 530W and 430W. As part of
the install the avionics shop moved the radar display. On the trip home (the same trip where in IMC the alternator quit) I turned the radar on, since there were some storms over my home airport as indicated by the nexrad. Of course, the radar unit was completely dead. When I called the shop, they said that they moved the unit, but that no one had checked its operation. Now, I have to fly an hour each way to the avionics shop to fix the problem. Who should pay for the gas? I realistically don't expect them to pay for two hours of Baron flying time (which would probably negate any profit they made on the installation). However, is it unreasonable to expect them to pay for some of the gas? |
On Mar 28, 10:14 am, "Viperdoc" wrote:
Had a major radio install on my Baron- a Garmin 530W and 430W. As part of the install the avionics shop moved the radar display. On the trip home (the same trip where in IMC the alternator quit) I turned the radar on, since there were some storms over my home airport as indicated by the nexrad. Of course, the radar unit was completely dead. When I called the shop, they said that they moved the unit, but that no one had checked its operation. Now, I have to fly an hour each way to the avionics shop to fix the problem. Who should pay for the gas? I realistically don't expect them to pay for two hours of Baron flying time (which would probably negate any profit they made on the installation). However, is it unreasonable to expect them to pay for some of the gas? If they moved the radar display and didn't check it operation I would think twice before using them again. MHO. |
No way the shop should pay the gas. You didn't test it and it is part of the
pre-takeoff checklist. Karl Had a major radio install on my Baron- a Garmin 530W and 430W. As part of the install the avionics shop moved the radar display. On the trip home (the same trip where in IMC the alternator quit) I turned the radar on, since there were some storms over my home airport as indicated by the nexrad. Of course, the radar unit was completely dead. When I called the shop, they said that they moved the unit, but that no one had checked its operation. Now, I have to fly an hour each way to the avionics shop to fix the problem. Who should pay for the gas? I realistically don't expect them to pay for two hours of Baron flying time (which would probably negate any profit they made on the installation). However, is it unreasonable to expect them to pay for some of the gas? |
Since when is operating the radar on the ground with people around part of a
pre-flight check list? It certainly isn't in my POH. Don't you think the installer should have at least checked the operation prior to releasing the plane? |
pre-flight check list? It certainly isn't in my POH. Don't you think the installer should have at least checked the operation prior to releasing the plane? The problem with avionics shops is that they seem to use installers who couldn't cut it at Best Buy installing car stereos. I've watched 'em work on my plane (three different shops, in three different states) and in every instance the guy who was doing the actual work, hanging upside down from the seats, was a real mouth-breather who may have been a good bench-tech, but appeared to have little experience or common sense. I always assumed that I got those guys working on my plane because I fly a lowly Cherokee -- "Hey, let's let Bob learn the ropes on that guy's plane!" -- but maybe it's universal? Of course, at some shops a Baron would be considered "entry level" -- so it's all relative. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Mar 29, 9:30 am, "Jay Honeck" wrote:
Since when is operating the radar on the ground with people around part of a pre-flight check list? It certainly isn't in my POH. Don't you think the installer should have at least checked the operation prior to releasing the plane? The problem with avionics shops is that they seem to use installers who couldn't cut it at Best Buy installing car stereos. I've watched 'em work on my plane (three different shops, in three different states) and in every instance the guy who was doing the actual work, hanging upside down from the seats, was a real mouth-breather who may have been a good bench-tech, but appeared to have little experience or common sense. I always assumed that I got those guys working on my plane because I fly a lowly Cherokee -- "Hey, let's let Bob learn the ropes on that guy's plane!" -- but maybe it's universal? Of course, at some shops a Baron would be considered "entry level" -- so it's all relative. -- Jay Honeck Iowa City, IA Pathfinder N56993www.AlexisParkInn.com "Your Aviation Destination" Ok, Jay, I gotta axe, what is a " real mouth- breather"? Jus curious and all... |
It is always on the "lineup" (pre-takeoff) checklist of every RADAR equipped
airplane I've flown. What airplanes have you flown with RADAR? RADAR systems have a POH supplement. It's in there. Karl "Curator" N185KG Try and read posts more slowly so you can understand better. At your airport do you have people walking on the runway while you take off? "Viperdoc" wrote in message ... Since when is operating the radar on the ground with people around part of a pre-flight check list? It certainly isn't in my POH. Don't you think the installer should have at least checked the operation prior to releasing the plane? |
... Who should pay for the gas? I realistically don't expect them to pay for two hours of Baron flying time (which would probably negate any profit they made on the installation). However, is it unreasonable to expect them to pay for some of the gas? I think asking to pay for the gas would be a very equitable request. If they push back, just remind them that they put you in a potentially dangerous situation of flying near weather with an inop radar. Marco |
On Mar 28, 9:14 am, "Viperdoc" wrote:
Had a major radio install on my Baron- a Garmin 530W and 430W. As part of the install the avionics shop moved the radar display. On the trip home (the same trip where in IMC the alternator quit) I turned the radar on, since there were some storms over my home airport as indicated by the nexrad. Of course, the radar unit was completely dead. When I called the shop, they said that they moved the unit, but that no one had checked its operation. Now, I have to fly an hour each way to the avionics shop to fix the problem. Who should pay for the gas? I realistically don't expect them to pay for two hours of Baron flying time (which would probably negate any profit they made on the installation). However, is it unreasonable to expect them to pay for some of the gas? That's one of those tough situations. I don't think it would be reasonable to ask them for gas though. I've certainly never heard of that being done. -Robert |
On Wed, 28 Mar 2007 11:14:42 -0500, "Viperdoc"
wrote: Had a major radio install on my Baron- a Garmin 530W and 430W. As part of the install the avionics shop moved the radar display. On the trip home (the same trip where in IMC the alternator quit) I turned the radar on, since there were some storms over my home airport as indicated by the nexrad. Of course, the radar unit was completely dead. When I called the shop, they said that they moved the unit, but that no one had checked its operation. Now, I have to fly an hour each way to the avionics shop to fix the problem. Who should pay for the gas? I realistically don't expect them to pay for two hours of Baron flying time (which would probably negate any profit they made on the installation). Did your sales contract cover these kind of details? I would think an avionics shop must run into these issues frequently, and hence their contracts would be written in a manner to address repair of adjacent avionics systems and transportation costs. Of course, that's probably asking too much - it seems to me that many companies in the aviation field simply 'wing' their operations vs being professional. Having said that, if the radar was working when you dropped it off, I would they pay at least the gas price for the trip. For your sake (and the avionics shop), I hope it is a simple fix, and they did not fry the radar. Dealing with these types of issues are certainly a major downside to going 'remote' for aircraft/avionics work. I find it an incredible pain to have major work done at airports that are 15nm away, let alone 100s. This is not a knock on those shops, just the logistics of getting to/from without the plane, or having a friend follow you there. |
Who pays? | Viperdoc[_4_] | Owning | 15 | March 30th 07 04:31 AM |
It Pays to be a Pilot | Seth Masia | Piloting | 5 | November 23rd 05 10:46 AM |
Reading R.A.O. pays off | The Weiss Family | Owning | 23 | September 14th 04 03:02 PM |
Black Hawk unit pays tribute to aviators | Otis Willie | Military Aviation | 0 | June 26th 04 10:31 PM |
Israel pays the price for buying only Boeing (and not Airbus) | Tarver Engineering | Military Aviation | 57 | July 8th 03 12:23 AM |
