KY197, KY 97 what's the Difference?
Old April 1st 07, 04:21 AM posted to rec.aviation.owning
Roger[_4_]
Default KY197, KY 97 what's the Difference?
What's the difference between the KY 197 and the current KY 97?
www.rogerhalstead.com
Old April 1st 07, 05:17 PM posted to rec.aviation.owning
karl gruber[_1_]
KY97A 5Watt LCD
KY197A 10Watt LED
"Roger" wrote in message
Old April 2nd 07, 05:36 PM posted to rec.aviation.owning
On Apr 1, 11:17 am, "karl gruber" wrote:
KY97A 5Watt LCD
KY197A 10Watt LED
I was once told that the KY97A is actually an ICOM IC-A200 that is
OEM'ed for King with a different faceplate and knobs but the exact
same innards. Is this true? Those two radios sure look a lot alike.
The KY197A is one of their "Silver Crown" series radios and supposedly
a totally different design inside.
Old April 2nd 07, 06:25 PM posted to rec.aviation.owning
Tri-Pacer
That's a fact
Old April 3rd 07, 06:12 AM posted to rec.aviation.owning
Roger[_4_]
KY97A 5Watt LCD
KY197A 10Watt LED
Will they both fit the same tray?
Old April 4th 07, 01:42 AM posted to rec.aviation.owning
JGalban via AviationKB.com
Roger wrote:
KY97A 5Watt LCD
KY197A 10Watt LED
Yes. My tray is marked both KY-97A and KY-197A.
Message posted via http://www.aviationkb.com
Old April 1st 07, 05:19 PM posted to rec.aviation.owning
Dave Butler
100.
Old April 1st 07, 11:56 PM posted to rec.aviation.owning
Roger[_4_]
On Sun, 01 Apr 2007 12:19:17 -0400, Dave Butler wrote:
100.
Actually it's a bit over $1000 or there abouts.
The difference between 5W and 10 Watts should be almost insignificant
(IE 3 db) in use.
Actually all I need is to fix the orange/yellow plastic window over
the display. Some where in the past (before I purchased the Deb) I'd
guess some one used the wrong stuff to try and clean the window.
Combined with age that has rendered the plastic window almost opaque.
I wonder if the stuff they use to fix scratched plastic glasses would
work on that? Trying would certainly be cheaper than purchasing
another radio or even front panel. The KY197s are going for as much
on E-bay (yellow tagged) as a new KY97.
Old April 2nd 07, 02:43 AM posted to rec.aviation.owning
Matt Whiting
100.
(IE 3 db) in use.
Why would having twice as much power not be significant?
Matt
Clear and Amber window for KY197 Roger Owning 5 June 11th 06 10:56 PM
Clear and Amber window for KY197 Roger Home Built 5 June 11th 06 10:56 PM
What is the difference between... expresstechonsite Home Built 7 June 5th 06 03:00 PM
what a difference! Chris Piloting 3 January 12th 06 11:52 PM
Anyone know the weight difference? Lou Home Built 4 January 5th 06 09:33 PM
