King autopilot and GPS approaches
Old April 1st 07, 01:31 PM posted to rec.aviation.ifr
Viperdoc[_4_]
Default King autopilot and GPS approaches
I went and did some LNAV/VNAV approaches yesterday with a King KFC 200
autopilot. Looking for some tips with these autopilots on GPS approaches.
1. In NAV or APP mode the commanded rate of turn appears slower than in
HEADING mode. Spinning the HSI to the desired heading (often 90 degree
turns) caused the plane to try to go in the wrong direction, or the rate of
turn (slightly less than standard) caused an overshoot and didn't capture
the new course.
2. If flying in APP mode, and then making a step down in altitude, the AP
would not capture the glideslope (I've noticed this with ILS approaches as
well, even if intercepting the GS from below)
3. Of course, roll steering would be ideal, but barring this, is there a
better way to utilized the autopilot to fly these approaches?
4. Would it be better to fly in heading mode, and then engage approach mode
just prior to the FAF?
Old April 1st 07, 09:19 PM posted to rec.aviation.ifr
Matt Barrow[_4_]
"Viperdoc" wrote in message
of turn (slightly less than standard) caused an overshoot and didn't
capture the new course.
One problem that's endemic to an analog autopilot (IMOHO)
Intercepting from above or below?
mode just prior to the FAF?
If you want a significantly increased workload, but no, it's not better.
Have you run all the self tests? Sounds like the AP controller is not
working at 100%.
Old April 6th 07, 12:33 AM posted to rec.aviation.ifr
Bill
the new course.
It's true. The rate of turn is somewhat reduced. Shouldn't turn the
wrong
direction unless turning 180 degrees. If you start the turn as
commanded by
the GPS, it will make it. If it goes the wrong way on a 90, there is
something
wrong with it.
If it's working right, it should intercept the gs from either attitude
mode or
altitude mode. The gs must pass thru center in either case and it may
be
slightly misadjusted. Descending onto it from above requires a
serious rate
of descent and it could be argued as unsafe.
Most of the dozens of KFC200s I've run into at BPPP clinics track just
fine
by turning the course arrow as commanded by the GPS. If you have a
sandel,
this is done automatically for you. Note that in strong winds, after
a 90
degree turn your ap will have to re-psych the wind; if you use APR
mode this will
be fairly rapid.
That would work. There are a lot of features in the coupling modes of
the 200.
In some cases if something isn't working right it would be really hard
to detect.
It's all analog switches driven by combinational logic. I'm sure that
some I've
seen aren't working correctly because the vast majority of them do the
problem
correctly.
Bill Hale BPPP instructor
Old April 6th 07, 03:51 AM posted to rec.aviation.ifr
Viperdoc[_4_]
My understanding is that at least the KAP 200 and 225 will not track a
glideslope (either from an LNAV+V, an LPV, or an ILS) approach when
intercepting from above, which is also my experience.
I also observed that adjusting the altitude with the autopilot up/down
switch will negate the glideslope intercept even from below while in
approach mode. Have you seen this behavior as well?
Old April 6th 07, 08:55 PM posted to rec.aviation.ifr
Bill
The 200 should intercept from above if in attitude mode. Does not
know what glideslope is in use.
You can demonstrate this: but it takes a whale of a descent to set it
up.
You need to pass thru the gs center to make it couple. It's a bad
idea
in any event.
The 225 will do the same thing on ILS but not sure about GPS
approaches.
Bill Hale
Old April 8th 07, 01:19 PM posted to rec.aviation.ifr
Viperdoc[_4_]
My experience is that the GS has to be intercepted from below in order to
couple (also true for the 225). Also, it seems like use of the pitch toggle
while in approach mode will prevent the AP from capturing the GS.
This has happened on multiple occasions when given a late vector to
intercept, along with an altitude change, while already in NAV or HEADING
mode, with the APP mode armed. In other words, using the toggle switch for
pitch on the AP master panel while in APP mode seems to prevent the AP from
sensing and capturing the GS. This has been true for ILS as well as GPS
(LNAV/VNAV or LPV) approaches.
My only thought was to not engage the APP mode until the final altitude is
attained for GS intercept.
So, the main question is: with a King 200 AP, does the use of the pitch
toggle switch on the master panel while in APP mode negate GS tracking? How
about the CWS?
Does a switch from APP to NAV and back to APP then allow GS tracking?
Old April 10th 07, 10:17 PM posted to rec.aviation.ifr
Bill
about the CWS?
Use of the rocker does cancel GS tracking. I wonder if it also
cancels
GS intercept if operated before the GS intercepts? I'd hope not.
For example: Say you are in the alt mode before GS intercept. You
use the rocker to change altitude 100'. Shouldn't affect the
intercept.
Say you are in att mode, = not altitude. You haven't intercepted
yet.
Seems you could change the intercept attitude before the intercept.
After it couples, seems you can't use the rocker (or cws) without
decoupling the GS. The message then is that you want some other
attitude than that selected by GS couple.
I'll believe these statements are correct. I'll have to verify them
next
time I'm in a plane with a 200. The thing is full of combinational
logic--you are on your own!!
Bill Hale
Old April 2nd 07, 02:50 PM posted to rec.aviation.ifr
Jose
What the KFC225 won't do is
a) intercept a GS from above - I was given a dodgy final vector
yesterday which led to that
Isn't that generally a bad idea anyway? I was taught that false lobes
could lead you to grief and a GS should always be intercepted from below.
Jose
Get high on gasoline: fly an airplane.
Old April 2nd 07, 03:47 PM posted to rec.aviation.ifr
Tauno Voipio
Jose
That's right - due to inevitable ground reflections, there
are always false glideslopes above the correct one. The
ICAO planning instructions require the procedure to be
planned so thet the GS is captured from below.
In the same way, the localizer capture planning rules
require an intercept angle below 45 degrees, preferably
30 degrees.
Tauno Voipio (avionics engineer, CPL(A))
tauno voipio (at) iki fi
Old April 3rd 07, 02:30 PM posted to rec.aviation.ifr
Matt Barrow[_4_]
"Tauno Voipio" wrote in message
Would you be so kind as to explain that one? False glidescopes?
Autopilot [email protected] Piloting 40 January 5th 06 09:12 PM
King KLX 135 and TruTrak "Digitrak" autopilot... [email protected] Home Built 3 August 31st 05 05:28 AM
IMC without an autopilot Jon Kraus Instrument Flight Rules 101 April 18th 04 07:17 PM
King Videos: Jeppesen Chart Review (2 tapes on eBay) Approaches & Enroute, Departures, & Arrivals Cecil E. Chapman Products 0 November 11th 03 05:14 PM
Autopilot Hankal Owning 1 November 10th 03 02:21 AM
